Re: Gray ExpandBar on Vista [message #530152 is a reply to message #529887] |
Wed, 28 April 2010 15:51 |
Ken Messages: 36 Registered: July 2009 |
Member |
------=_NextPart_000_0015_01CAE6C9.3272A6B0
Content-Type: text/plain;
format=flowed;
charset="iso-8859-1";
reply-type=original
Thanks for your replay Grant and for clarrifying that you see the same
results. I agree, I guess I shouldn't assume it's wrong. Whatever the
ExpandBar widget is using as the color from the Vista theme seems odd to me.
I've attached what it looks like in XP. Is it just me, or does that look way
better? Anway, it would be nice if this the gradient colors could be set
somehow. I tried the switch -Dorg.eclipse.swt.internal.win32.OS.NO_MANIFEST
but it didn't seem to change anything for me. Oh.. and on Ubuntu is has no
color at all. Seems like the Eclipse Form UI theme works much better and
happens to use blue for Vista..
- Ken
"Grant Gayed" <grant_gayed@ca.ibm.com> wrote in message
news:hr6u38$sd6$1@build.eclipse.org...
> Hi, sorry for the late response,
> I've checked on Vista here and I see the same thing, so you're not doing
> anything to cause this. I don't see a reason to assume that it's
> displaying
> "wrong", unless you have an example of this native control being used in
> another app and appearing differently on Vista (I went through Vista's
> Control Panel items but could not find a use of it).
> The only way for you to change the theme that controls are drawn with is
> to
> revert to the Windows 2000 theme, which is probably not what you had in
> mind. This is done by launching your app with VM
> switch -Dorg.eclipse.swt.internal.win32.OS.NO_MANIFEST .
> Grant
> "Ken Prole" <kennyp@avi.com> wrote in message
> news:hqn02t$r9m$1@build.eclipse.org...
>> I created a simple SWT Shell application with an ExpandBar and
>> ExpandItems
>> and it renders in a gray theme as shown in attachment.
>> I was expecting it to look more like below from what I see online:
>> http://www.javalobby.org/java/forums/t66195.html
>> I understand this is based on the operating system. But I am running
> Windows
>> Vista and have not modified my theme. Any idea what is going on here? The
>> gray looks horrible in comparison. I have not set any additional
> properties.
>> And my Eclipse UI Forms look fine, so I don't get it.
>> I cannot image this was the desired look by SWT developers; it does not
>> go
>> with the OS theme at all.
>> Any pointers or workarounds is greatly appreciated!
>> Thanks!
>> - Ken
Content-Type: image/png;
name="expandbar.png"
filename="expandbar.png"
iVBORw0KGgoAAAANSUhEUgAAASUAAADDCAYAAADEDQdcAAAABmJLR0QA/wD/ AP+gvaeTAAAACXBI
WXMAAAsTAAALEwEAmpwYAAAAB3RJTUUH1gIYFSQroGcA/wAAH1ZJREFUeNrt nXuIJNe937/17OrH
vGdHu+ORpdWVFNnyWi+jKxns2M6VhIl0xQVhuDdEgZA/LopjTMAQkz+uQxwI JPnzYv0lE8skEAQG
YxIQV/4jAq2zKz9lSbt7pZWuNLPTu/Pq2X7U+1T+6K6e6uqqfk1Pv+b7gZru OlWnzvmdqvrO75yu
Oj8pCIIAhBAyIchsAkIIRYkQQihKhJBpQB3GQTgsRQgBAEmSxidKSUJEcSLk dItRVAMGFai+RCla
4DBEiSJGyGx7PYMcS+r1kYBwtyRh6iZWFCVCZleUovuF37ulHVuU4uITBEHq d4oNIadPuKKfad97
Faau3be4+ITrQoiWz/h2ChMhp0eQogIky3LzMwiClv2i6wOJUpIghYsQouUz vvQiTBQuQqaz+5Yk
SOESF6J4vm7CpPYjSE/8699HDh6rZPhXiq63JCXklerbOuSRpJajt+4rtZYr IWlb/SBSrOyWfSQp
MV9Yduu+0e0J+SJ1apbVVqbUmi4dtUZbWmRbxzq01btT/VLK71I3JJYxpDZK O2dJZXY6Z5E/7ceM
XovtZSdfg1L69Z6Q56gFTxf/8s8ykGW5xTsKgqCZ1o8w9eUpEUJIEq7rNgVI UZQ2IQrXB/aUuv3C
RgghURzHaQqSEAKKorR5R3FBShOnnrpvQojmgDYhhMSxbRuqqjbHmOPjTqF+ yLLM7hshZDSekhAC
qqq2iJIkSfB9vylEnTykVFGKd92iv7YRQkgnUYoLkiRJkGUZQogWYerUhevp OSV6SoSQXkQpFJzo
oLcQovmr3MBjSnERoigRQrqJEoCmGEUFKfosY1RTBh5TGuTXt0s/epRnifRE 9LIKIglBJDGI7Rvu
F6Rtjx4jaP08up6PjhXN1y1PanrKMY6T3rHMhHqGbZK4LdpmbW2Z3v5vvV/r 6Tx6ntcmRr7vtwlS
3FtKQu5+0fTXfaMgETI7fPmBXM+iFC6+7zcFKemNj270PPNkLwe79DIFiZBJ w3YFbEfAcgPYjcXx
Anh+b/mf7EGYuglRPz2tnuZT4ngSIdOHaQuYtg/T9uD5AXwhoMgSggAQIoCq ysgbKvKGClU53ssx
UUFKEqZ+dKSn55QoTIRMFxXTx2HVQdXyMJdTcXbFQN6QoWsyhAhQsXzslRzc OjCR0RWszBvIGcrA
5SV5Rmn60W1cqesT3YSQ6aJqChyUHViOh7vPZXHnmSwMvXWkZnUB+OxaFrcO bFz7tIrifg1nl3PI
ZQaLJZI0Y0hUgPpBHXmDbR+i9OEuKvs1lEwfv722j32nPlK/upbHAxfuwEOP fAbLyzleXYT03WUL
UDFdWI6L8+sFnD+XhZzSM5Ml4OxyBnlDwe8+uI2dkon11Ty0ARymYc7ZP9IQ S3vvF1HeLCHI6thV
Nfxh18FNS6BquTisWvjjlSJe/ekl/PiVt3DlSnFqL4x7XryIe168ODMX+qzZ M8t4vkCl5mJtKYO7
zhptgrT67GtteeZyKh48Pwc/qAvaMLpvx2FknlJ5q4TqjUNk1goQhgG35MLI a7AdF47jwLLri2na
ePPNayhXqnjppa9jbW2+480S5/pPnpzomzte1zDtpOudJirxOgy7PqOyj9Rx PAFJBtZXDagxRQoF
afXZ17D7ixdati3NaVhfMbBTcjCf11K9q1EwMlHaf3cbbs3BbVVFRfVhWS7M mg3bcWDbDkzLgWlZ
ME0bNcvGG798D/f/ozX81V92v5in5YIfpQiltVFS+SdVF3pXo8f3Axi6gvm8 lihIu794AavPvtYm
TBKAtSUdN/dtCAHIyikQJbtsQp/LwmxM6adqMgpzGu69fxWu68J2wsWB0/i+ f1Adyn/nJE8gTdSS
vJlevLLj3oBpde61HtH0fkUmSag6iWda3brVi4wGXZWgqVKiIHUSplxGgarI je6XNPuiJATwsz1A
CKv+HEMgIHwFfiYLX9MhMj48T0AIHxACqi9wvRr0dVP1c0NGb/J7XrzYXI/f mNFtafm6CUo/9UkT
qF7qkbbvcTyrXsRzGOWR4RGXlKjwhEIU774BgCRLkOXx179nUTru4FUA4Ini Nl4v2ihbLiy73k0z
zXq3rWbaqDU+TcuCaTnIF3Tge9/o+wYKhWIQsZqk/+yT7GXQA5pMJAmw3QCe CPoaUwq7fifxJFC/
D1COzFMKAuBXZ8+hcIdAXgSNF/bqjwL4QsD3/Ja0ccx2OQyP5yTGgSZ1fIxM HoosoWZ5KNc8LBW0
nseUAKBq+RBi/M8njkyU9IUsvrJ5gF9f38elrRJqlgPTtFAzLdQsu+4hmRYs 24Zlu7BsBz/8wQtD
Exd2McipGE/SFAQBsLVjYbGgQepxTMkTAYr7NmRZgiKPNx7LyETpzIPnUD00 cdeZPD7cvY29g7DL
Zh912RqPBTi2h2eeuoDnn/vSiY0pJeVJ6vb16jX0ki+6PRTJeN6ktFF6J0n1 6cXWbgPi/KcwGgpZ
GfN5DVs7FpbnNKyvGoldtXhacc/B/qGDhYIORY5MdzKOLmg8bHd0+ttw8TwP juPg6e9/1NJ3bTkQ
gEsvP9axsM3fbaJ47Ra2imVcvHoDb1/dxP5hBaZlw7TqgmTbLp556gv47ne+ iScev/fEu2hkvHA+
peHPp1S1BG7um/B8gc/fXcD6qpHe/gC2dy1c/bQKCRLWlrLQlPb2v3il87xK 92UuI5PJwDAMGIaB
bDbb/K7renNRFKUZgikMItD3dLjDZOPhDeRWC9De2cLcYhaPfu4cXv35ZXxc tKGrMh66cB5PP/VF
PP/cY9jYWOYdS8gA5AwZZxYN7JQsvHO9jIopsH6m/jpJePuLAKiaHooHNj65 aUKRZKwsZAZ6xWRq
u28hyxuLWN5YbK5/69tfG2n59JDI6ejGKZDlLA7KNj7armJ7z0Qhq0LX6r/5 O55A1fRhuwJ5Q8V8
XkdGk4HgFA10E0JGSzYjI6tnUc5psB0Bz68vTY8qo2GxUJ/ORJUlTMq8IBQl Qmbea1JRyAKO2yo7
qtI6R/ekQFEi5JSgq+0/CkwiMk8VIYSiRAgho+i+vf+xxRYlJBGpz/TGVqmx hzTu+tdGVhI9JUII
u2+EEDKS7luUJf3vUT28Dc+zIU5wqN+uVYZ6vEyucKTYkgRJVqDIKvIL8zhw 7qN9tG8q7KMoJVA9
vI2MnsF//fkHeP3tT3C9eHvqGmd1MYs/e+RO/Ld/9SX4jkP7aN/U2EdRSsAX Hv7Tax9gryrjlX//
z/CPH75n6hrnvY9v4gevvI7/+D/fwd/880cAh/bRvumwb5o50TGl19/+BC/9 xZfx1YfOp0bQnOTl
c3edwUt/8SRef/sfkNFztI/2TZV99JRiBMLH9eJtfPWhuxEEovEE6XRF3Q2C AH96/x24XrwNVcvS
Pto3NfZRlBKQGjFafF9M3clunHK4jgPXsRr2SLSP9k2NfRSlDgjhT+VJD4IA wvfge154GdM+2jd1
9lGUUk/6dLrGIvAhhEf7aN/U2kdRSnEzo5+5XGsY7lqt80+xudx8yz7x9eMS rU/rcYPIQvsm1b70
486OfWGdBrOPopR40uODiNXqYUuDR9fT/it0Wh+UfH4htS7RXzlo32TaF7Uz ftxZsS96Dgezj6KU
esLiDRrfp1BYRKVSaqZF18OLLm29UDiaXjcpLZre6wV1dNKn175KpTTT9kXL KRQWU27a6bUvLCNJ
eHq1j6LU40mPnpBy+SA1ema4Xi4fpK7PzS0118Njh+tp6f2JUjDV9oWEx5kl +5Js6teTmPTzF68L
PaUTGFOqN+5+7MLaTxlsDLqk45j5uuXtf0xi8uwD5uaWG3UIjj3mMmn2zc0t dajL9NvXuS4cUzrR
7tsg6YMe76Q9pUmyb35+Bbdv7yXuO+323b69l2rnrJy/416fFKXEk976Gf+e tk8v6YMer9e80SCD
02jfwsIKDg/3Uu2edvs6nctZse+41ydFqUf3eGFhpfn98HAXQIDDw92W9DBP NP3wcLfjevR4vbjH
3fMO5v5Pin3xuhzlnx370rdPv33DuT4pSl3d41JpJ9U9TdsWpndbj6fFj53k 6iblrX8XA7n/k2Rf
vLzW+k6/fXFbZ+38DeP6pCilnvQpbLggQCAEAoTB+yTaR/umzj6KUgKe6yJo nHRpShovQP29Itex
4bluo9YS7aN9U2cfRSmCDAmri1m888Em/uRsASIQkCBBkqbgpAcBhPDhuS7+ /kYJq4tZKKpO+2jf
1NhHUUo6sKbjnzx8J/7L//p/+MuvnMdj9yxNj2eM+s8aHxTL+NH/uYZ/+qfn oSg67aN9U2MfRSmB
TC6Lv/03X8V/+Oll/M3/+M3UzoH850/+Cf723z4PWVZaxh5oH+2bZPumGSmI Dd+HI/pCiObieR4c
x8HT3//oKGPMy5UA/Pd/92Bz/WxhE6qWg67noaiZult8Aq6xLA9XV6NTQUiQ AaneJrXKTWwerNI+
2jcV9g2b/335oOP2+zKXkclkYBgGDMNANpttftd1vbkoigJFUSDLMmRZhiS1 d5lPzFMqVjbanM6T
UfKTnC1dRP8v0T7aNzX2TTMMRkkIoSgRQkgajJAbgxFWad8s2EdRSoARVmkf 7RuffRSlBBhhlfbR
vvHZN80wQi4jrNI+Rsg9HZ4SI6zSPto3PvsoSgkwwirto33js4+i1AFGWKV9 tG989lGUUk/6dLrG
jLBK+6bdPopSipsZ/ZzUCKTtx2SE3Em3L16X1vrQPopSh5M+6RFI08pghNzJ P3/xsvuP9jG59sXL
zecXGM1kWG5m/ERNUoTVpOiqrSd9eu07DRFy027KWbEvXl6/54+i1ONJn8QI ssOMizZp9oUBG2ct
Qm5SXWbx/CVdo/SUhjimVD8ZkxVBNn3f2YiQG5Y/axFko/WYRfuO6nCcCMcU pYHd40HSBz3eSXtK
k2jfoGMutG+6r0+KUmJjtn7Gv6ft00v6oMfrVM/o+qxEyE3LS/sm//pMi3LM CLlD7r5NVgTZ1cjJ
3x1K940RgGnfsK7P9HR234bWfWOEXNpH+/qzLymdEXKPLUqMsEr7aN847KMo JcAIq7SP9o3PPopS
BEZYpX20b3z2UZSSDswIq7SP9o3NPopSAoywSvto3/jsm2YYITcGI6zSvlmw b9gwQm5fMMIq7aN9
jJBLCCEUJUIIRYkQQihKhBCKEiGEUJQIIYSiRAiZcIb6nNK/+M/vNd9nbD4O JbW/4ihFNkqRnZPy
SJEd2vaVIluieeLlSlLseLF9JCkxX1h2677R7Qn5InVqltVWptSaLh21Rlta ZFvHOrTVu1P9Usrv
UjckljGkNko7Z0lldjpnkT/tx4xei+1lJ1+DUuya7Zxntl6NpadECCEUJUII RYkQQihKhBCKEiGE
UJQIIRQlQggZGicyn9KlHz3KliU90RIEMpIQRBKD2L7hfkHa9ugxgtbPo5BK R8eK5uuWJzU95RjH
Se9YZkI9wzZJ3BZts7a2TG//t96vTb+nREEiZHb48gO56RalSy9TkAiZNGxX wHYELDeA3VgcL4Dn
95b/yRELk8pTRshsYtoCpu3DtD14fgBfCCiyhCAAhAigqjLyhoq8oUJVJufl GIoSITNIxfRxWHVQ
tTzM5VScXTGQN2TomgwhAlQsH3slB7cOTGR0BSvzBnKGQlEihAyfqilwUHZg OR7uPpfFnWt5GFrr
PqsLwGfXsrh1YOPap1UU92s4u5xDLjP+H+RHLkrV7UOUPtxFZb+Gkunjt9f2 se8I+L6P1bU8Hrhw
Bx565DNYXs7x6iKk7y5bgIrpwnJcnF8v4Py5LOSUnpksAWeXM8gZCn7/wW3s lEysr+ahjdlhGqks
7r1fRHmzhCCrY1fV8IddBzctgarl4rBq4Y9Xinj1p5fw41fewpUrxam9MO55 8SLuefHizFzos2bP
LOP5ApWai7UlA3edNVIFKcp8TsWD5+fgB3VBOzWeUnmrhOqNQ2TWChCGAbfk wshrsB0XjuPAsuuL
adp4881rKFeqeOmlr2Ntbb7jzRLn+k+enOibO17XMO2k650mKvE6DLM+SfaS k8XxBCQZWF/NQG0o
0uqzrwEAdn/xwlH3LZa2NKdhfcXATsnBfF7rScym3lPaf3cbTtnCzr6FG7eq sCwXZs2G3RAk03Jg
mhZM00LNsvHGL9/D373xbk/Hvv6TJ5vLJBOt36jrGm+f6PpJtF1U3MJj09s6 eXw/gKErmM8fDSKF
whMKUZJISQDWlnQIEUCIU+Ip2WUT+lwWZmNKP1WTUZjTcO/9q3BdF7YTLg6c xvf9g+qxb4j4ejfv
Ku2/e7/5hlXnXusRTe9XYJK8o04eUy8eEL2i8aGrEjS11dXZ/cULWH32tURB CslmFKiK3HhqfHyu
0sg8JSGAn+0B/3fTwpsf3saviyb+wVOwl8niIJdHZW4O5sIivJUV4I41qOvn cL0q93xT9TvukfYf
PO51Jd2A8W1JXsFxPJlevIz4tmF7JGm2DOIBjaqLSuqkSUooREmCBACyLEGe gLdh1VE21BPFbbxe
tFG2XFi2jZplwzQdmJaFmmmj1vg0LQum5SBf0IHvfaOvblHUcxjEe5ikLsYk d3d6rRsFabRIEmC7
ATwRJI4pxbtyUYESImh5F3H2RSkAfnX2HAp3CORFACEEfL/+KIAvBHzPb0kT QkCMuHPbrQs1zjGo
SR4foyBNDoosoWZ5KNc8LBW0tq5b+D3JY6qYPoQYvyqNTJT0hSy+snmAX1/f x6WtEmqNge1aY2C7
ZtowTQuWbcOyXVi2gx/+4IWhiUvYxSHjEXgyovtMUxAEwNaOhcWC1uzGdRtT 8kSAmwc2ZFmCIo/3
lZORidKZB8+hemjirjN5fLh7G3sHYZfNPuqyNR4LcGwPzzx1Ac8/96W+uxKD dNOiv0IN8kxOr/mi
26PjQNG8SWmj9JyS6tOLrWl142MBo6WQlTGf17C1Y2F5TsP6qtEyphR6S3GK ew72Sg4WCjoUOTLd
yTi6oEHQ2osMggBBEDS7T0IIeJ4Hx3Hw9Pc/aum7thwIwKWXH+tY2ObvNlG8 dgtbxTIuXr2Bt69u
Yv+wAtOyYVp1QbJtF8889QV89zvfxBOP38v/4DMO51Ma/nxKVUvg5r4Jzxf4 /N2FFmFqa38A27sW
rn5ahQQJa0tZaEp7+1+80nlepfsyl5HJZGAYBgzDQDabbX7Xdb25KIoCRVEg yzJkWYYkSc3YgCP3
lABg4+EN5FYL0N7ZwtxiFo9+7hxe/fllfFy0oasyHrpwHk8/9UU8/9xj2NhY 5h1LyADkDBlnFg3s
lCy8c72MiimwfiaDvKE0u3MiAKqmh+KBjU9umlAkGSsLmbG/YjJyUQKA5Y1F LG8sNte/9e2vjbR8
ekjkdHTjFMhyFgdlGx9tV7G9Z6KQVaFr9d/8HU+gavqwXYG8oWI+ryOjyZiE n984SwAhM0o2IyOr
Z1HOabAdAc+vL02PKqNhsVCfzkSVJQQTUm+KEiEz7zWpKGQBx22VHVVpnaN7 UqAoEXJK0NX2HwUm
EYZYIoRQlAghZCTdt8f/+jfNNwGbTx5I7S8HSpGNUmTnpDxSZIe2faXIlmie eLmSFDtebB9JSswX
lt26b3R7Qr5InZpltZUptaZLR63RlhbZ1rEObfXuVL+U8rvUDYllDKmN0s5Z UpmdzlnkT/sxo9di
e9nJ16AUu2Y75zlqQUJPiRBCUSKEEIoSIYSiRAghFCVCCEWJEEIoSoQQEuFE XjO59KNH2bKkJzif
0vDnU0rcFm2ztrZMb/+33q9Nv6dEQSJkdvjyA7npFqVLL1OQCJk0bFfAdgQs N4DdWBwvgOf3lv/J
EQsTZwkgZEYxbQHT9mHaHjw/gC8EFFlCENTDKamqjLyhIm+oUJXJeTmGokTI DFIxfRxWHVQtD3M5
FWdXDOSN+oRuQgSoWD72Sg5uHZjI6ApW5g3kDGUi6k5RImTGqJoCB2UHluPh 7nNZ3LmWh6G17rO6
AHx2LYtbBzaufVpFcb+Gs8s55DLj/0F+5KJU3T5E6cNdVPZrKJk+fnttH/tO PQDl6loeD1y4Aw89
8hksL+d4dRHSd5ctQMV0YTkuzq8XcP5cFmlh3GQJOLucQc5Q8PsPbmOnZGJ9 NT/24AEjlcW994so
b5YQZHXsqhr+sOvgpiVQtVwcVi388UoRr/70En78ylu4cqU4tRfGILHjaA8Z Bp4vUKm5WFsycNdZ
A73ElZzPqXjw/Bz8oC5op8ZTKm+VUL1xiMxaAcIw4JZcGHkNtuPCceox3yzb gWnaePPNayhXqnjp
pa9jbW2+480SZ5KjlSQFZhxVHLo0UYnXYZj1YSDK0eN4ApIMrK9moDYUKSkq bjxtaU7D+oqBnZKD
+byGcQbJHZmntP/uNpyyhZ19CzduVWFZLsyaDbshSGYjjLfZCOP9xi/fw9+9 8W5Pxw6jyk76RR+t
36jrGm+f6PpJtF084m8nYSTDw/cDGLqC+fzRIFIoPKEQJYmUBGBtSYcQAYQ4 JZ6SXTahz2VhNqb0
UzUZhTkN996/Ctd1YTvh4sBpfN8/qB77hoivd/Ou0v6795tvWHXutR6DhC5P KzstrR8PiF7R+NBV
CZra6uqEIbuTBCkkm1GgKnLjqXFp9kVJCOBne4AQVj0ceCAgfAV+Jgtf0yEy PjxPQAgfEAKqL3C9
GvR1U/VzM0Rv8ntevNjiNcTHUpI8nOi2boLSrxeVdLxe6pG273G9um7i2am8 44glGYw0SQmFKUmQ
AECWJcgT8DasOsqGeqK4jdeLNsqWC8u2UbNsmKYD07JQM23UGp+mZcG0HOQL OvC9b/R9A4VCMcgN
MUldjEnu7vRat2GLJemMJAG2G8ATQeKYUrwrFxUoIYKJCL00OlEKgF+dPYfC HQJ5EUAIAd+vPwrg
CwHf81vShBAQI+7cDsPjOakxqEkeHyOTgyJLqFkeyjUPSwWtresWfk/qwlVM H0KcorDd+kIWX9k8
wK+v7+PSVgm1xsB2rTGwXTNtmKYFy7Zh2S4s28EPf/DC0MSF/6XH40mxzUc8 nqQpCAJga8fCYkFr
duO6jSl5IsDNAxuyLEGRx/vKych6kGcePAdtzsBdZ/JYycgNQbKPBMmyYNoO TNuBbbt45qkLeP65
L/V8A/T7LE10//h4Ur/H6jVfdFuacCaljfI5oW629Fq3TnaRk6OQlTGf17C1 Y2F712obU0oSJAAo
7jnYKznIGSqUMY8rSUHQ2osMggBBEDS7T0IIeJ4Hx3Hw9Pc/aum7thwIwKWX H+tY2ObvNlG8dgtb
xTIuXr2Bt69uYv+wAtOyYVr1RwPqgvQFfPc738QTj9/L/+AzDudTGv58SlVL 4Oa+Cc8X+PzdBayv
GuntD2B718LVT6uQIGFtKQtNaW//i1c6z6t0X+YyMpkMDMOAYRjIZrPN77qu NxdFUaAoCmRZhizL
kCSpGRtw5N03ANh4eAO51QK0d7Ywt5jFo587h1d/fhkfF23oqoyHLpzH0099 Ec8/9xg2NpZ5xxIy
ADlDxplFAzslC+9cL6NiCqyfySBvKM3unAiAqumheGDjk5smFEnGykJm7K+Y jFyUAGB5YxHLG4vN
9W99+2sjLZ8eEjkd3TgFspzFQdnGR9tVbO+ZKGRV6Fq9b+Z4AlXTh+0K5A0V 83kdGU3GJPz8xlkC
CJlRshkZWT2Lck6D7Qh4fn1pelQZDYuF+nQmqiwhmJB6U5QImXmvSUUhCzhu q+yoSusc3ZMCRYmQ
U4Kutv8oMIn0/ONffIScEEJ61Y5QP3rREcZ9I4TMbvft8b/+TfNNwKYeSu0v B0qRjVJk56Q8UmSH
tn2lyJZonni5khQ7XmwfSUrMF5bdum90e0K+SJ2aZbWVKbWmS0et0ZYW2dax Dm317lS/lPK71A2J
ZQypjdLOWVKZnc5Z5E/7MaPXYnvZydegFLtmO+c5akFy4t03QgihKBFCpoJw 3CjpCW2KEiFkLKLU
S9qxRIm/thFC+hGl6Lts0V/b+tUSuVf1o0gRQnrtvsXFKP69k57IvRZICCGp QtJ46z+6DDq+xIcn
CSHHRlXVxClJ4t26oYjSsEbUCSGzLUrhkjZnUq86kjrJW3SyN8/z4Ps+XNeF 69aDR9q2DcdxWhbP
85r7hhPEhccJj00ImT7iA9eh4CiK0hSj6GRuuq4jk8lA13VomgZN05r7dhMq tVMFQhGJV0SWZaiq
2jI7ZbifLMtNUYqKG0WJkOkXJQBNUQlFSVEUaJrW4i2F4pM2vtTJY1J7qUyS OgohoKpqU2jCbb7v
w/f9ppcVFSKKEiHTL0rRcaJQlEIhCsWpUxeumzCpSYVHPaRoJYIggKIobR5Q VLCi3hO9JEJmvwsX
9pySFkVRUp9hShMmtVslgiBI9JSSBCmpSxcVJkLI9AtTKCTxRwBCEYoKUqgX /UxfovYiSHIjlm/o
KcUrGBbMsSRCTpe3FL3/o2NM0SXquPQiTGonQUoTp7gohWNMoSDRSyLk9HhL 8a5cVKA6iVHPY0pp
3lJYgSjxcaT44wTdvCQKFiGT7xX14i3FhSlpfajdt7gQhQVEPah+BYmiRMh0 ilInYYoOaic9jzRw
962bMCW5YBxHIuR0ilZccMIeVfjZjyABCU90d/Joop/dvvcChYuQ6fSU4vsl TVWSJEQDvWbSqzB1
S6MoEXJ6RCnJe+qUNhRR6kV8+hUZihIh0y9KafsOOh+belKVHMfxCCGTI2CD 3t99eUr0eAghJ+1o
qJNSEUIIARjNhBBCUSKEEIoSIWRK+P/chajG9EWVmAAAAABJRU5ErkJggg==
------=_NextPart_000_0015_01CAE6C9.3272A6B0--
FUDForum. Page generated in 0.05152 seconds
