Home » Eclipse Projects » Rich Client Platform (RCP) » IFile Open Listener(Problems listening to an open event!)
IFile Open Listener [message #528578] Wed, 21 April 2010 03:23 Go to next message
Hello @ all,
I have got a problem concerning IFIles:
If I open an IFile in my own view I have to do xy.
The problem is, I need to do xy if I am opening the IFile outside of my view, too.
Example:
Open IFile via MyView should call the method xy.
Open File via PackageExplorer should call the same method.
Is this possible?
I tried to add a ResourceChangeListener with an IResourceDeltaVisitor but it seems that the IResourceDelta.OPEN flag is never in use.
The delta visitor will not get called if I open the file!?
I would appreciate any help, because atm I have no idea how to solve that problem!
Thanks in advance.
Alex
Re: IFile Open Listener [message #528595 is a reply to message #528578] Wed, 21 April 2010 04:37 Go to previous message
Hi Alex,
Add an org.eclipse.ui.IPartListener to the active workbench page(IWorkbenchPage) and implement the partOpened method like this
public void partOpened(IWorkbenchPart part) {
		if (part instanceof IEditorPart) {
			IEditorInput editorInput = ((IEditorPart) part).getEditorInput();
			if (editorInput instanceof IFileEditorInput) {
				IFile file = ((IFileEditorInput) editorInput).getFile();
				if (file.getName().endsWith(".xml")) { // replace this with desired condition
					System.out.println("Xml file openend ");// call xy method here
Previous Topic:Contribution Item on status line still visible if status line is set invisible
Next Topic:Multilanguage Preferences -> Help page
Current Time: Sun Nov 09 21:31:23 EST 2025
Powered by FUDForum. Page generated in 0.02760 seconds
