m2eclipse fails to go through HTTP proxy [message #528247] |
Mon, 19 April 2010 19:38 |
Alexander Shenker Messages: 2 Registered: April 2010 |
I am using Eclipse 3.5, with the m2eclipse plugin, all the latest versions downloaded today from the official eclipse and sonatype sites. Eclipse works through my company's firewall proxy, because I can see it downloading plugins. However, the Maven plugin can not run properly, as it fails to download any required plugins from the central repo. In fact, it can not even update the repo1.maven.org index. Our proxy server does not require authentication. I setup the settings.xml file in my ~/.m2/settings.xml location as follows:
<settings>
<localRepository>C:\Documents and Settings\...\.m2\repository</localRepository>
<proxies>
<proxy>
<id>main</id>
<active>true</active>
<protocol>http</protocol>
<host>...</host>
<port>80</port>
<nonProxyHosts>....com,....com,127.0.0.1,localhost</nonProxyHosts>
</proxy>
</proxies>
</settings>
I see this exception in the .log file:
!SESSION 2010-04-19 15:23:11.366 -----------------------------------------------
eclipse.buildId=M20090211-1700
java.version=1.6.0_16
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ui 4 4 2010-04-19 15:23:26.428
!MESSAGE Invalid preference page path: Integrated Agent Controller
!ENTRY org.maven.ide.eclipse 4 0 2010-04-19 15:23:34.444
!MESSAGE Unable to update index for central|http://repo1.maven.org/maven2
!STACK 0
java.io.IOException: Authorization exception retrieving nexus-maven-repository-index.properties
at org.sonatype.nexus.index.updater.DefaultIndexUpdater$WagonFetcher.retrieve(DefaultIndexUpdater.java:681)
at org.sonatype.nexus.index.updater.AbstractResourceFetcher.retrieve(AbstractResourceFetcher.java:22)
at org.sonatype.nexus.index.updater.DefaultIndexUpdater.downloadIndexProperties(DefaultIndexUpdater.java:493)
at org.sonatype.nexus.index.updater.DefaultIndexUpdater.access$100(DefaultIndexUpdater.java:74)
at org.sonatype.nexus.index.updater.DefaultIndexUpdater$IndexAdaptor.setProperties(DefaultIndexUpdater.java:780)
at org.sonatype.nexus.index.updater.DefaultIndexUpdater.fetchAndUpdateIndex(DefaultIndexUpdater.java:954)
at org.sonatype.nexus.index.updater.DefaultIndexUpdater.fetchAndUpdateIndex(DefaultIndexUpdater.java:138)
at org.maven.ide.eclipse.internal.index.NexusIndexManager.updateRemoteIndex(NexusIndexManager.java:1060)
at org.maven.ide.eclipse.internal.index.NexusIndexManager.updateIndex(NexusIndexManager.java:1013)
at org.maven.ide.eclipse.internal.index.NexusIndexManager$1.run(NexusIndexManager.java:624)
at org.maven.ide.eclipse.internal.index.IndexUpdaterJob.run(IndexUpdaterJob.java:71)
Is this related to any issues to the running of m2eclipse plugin with NTLM proxies? Again, this proxy does not require authentication.
FUDForum. Page generated in 0.03473 seconds
