NullPointer Exception During initializeGraphicalViewer [message #528126] |
Mon, 19 April 2010 12:52 |
Chris Messages: 44 Registered: April 2010 |
Member |
I'm currently working on a graphical editor for Eclipse (surprise!).
I tried to follow Elias Volanakis' ShapeEditor example as close as applicable for my task.
I wanted to have a very simple basis on which to expand later on:
The editor (simple window, no pallette required), the document model, one dummy document element and the corresponding EditPart and View. For reasons of simplicity, I did not concern myself with connections, yet. In my model there is only a list of rectangles with position and size, nothing else.
I set up the Model/EditPart/View infrastructure to the best of my knowlegde and then wanted to integrate it all into the editor. But during the initializeGraphicalViewer method there happens a nullpointer exception when registering the loaded diagram model to the viewer using setModel().
protected void initializeGraphicalViewer() {
GraphicalViewer viewer = getGraphicalViewer();
viewer.setContents(getModel()); // set the contents of this editor
//TODO: listen for dropped stuff
The stack trace is the following:
Quote: |
at org.eclipse.gef.editparts.AbstractEditPart.registerModel(Abs tractEditPart.java:777)
at org.eclipse.gef.editparts.AbstractEditPart.register(Abstract EditPart.java:757)
at org.eclipse.gef.editparts.FreeformGraphicalRootEditPart.regi ster(FreeformGraphicalRootEditPart.java:233)
at org.eclipse.gef.editparts.ScalableFreeformRootEditPart.regis ter(ScalableFreeformRootEditPart.java:150)
at org.eclipse.gef.editparts.AbstractEditPart.addNotify(Abstrac tEditPart.java:229)
at org.eclipse.gef.editparts.AbstractGraphicalEditPart.addNotif y(AbstractGraphicalEditPart.java:219)
at org.eclipse.gef.editparts.AbstractEditPart.addChild(Abstract EditPart.java:198)
at org.eclipse.gef.editparts.SimpleRootEditPart.setContents(Sim pleRootEditPart.java:101)
at org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents( AbstractEditPartViewer.java:601)
at org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents( AbstractEditPartViewer.java:610)
at edu.rwth.hci.codegestalt.editor.CgtEditor.initializeGraphica lViewer(CgtEditor.java:69)
at org.eclipse.gef.ui.parts.GraphicalEditor.createGraphicalView er(GraphicalEditor.java:153)
at org.eclipse.gef.ui.parts.GraphicalEditor.createPartControl(G raphicalEditor.java:163)
at org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:662)
at org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:462)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:595)
at org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:271)
at org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito rManager.java:1417)
at org.eclipse.ui.internal.EditorManager$5.runWithException(Edi torManager.java:942)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3885)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3506)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$28.runWithException(Workbe nch.java:1384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2316)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
As far as I can determine, the document was loaded fine and the model looks ok in the debugger (empty as the document, but not null).
I checked the model and the Editor in both my plug-in and the sample during runtime in the various stages of initialization (constructor, configureGraphicalViewer, initializeGraphicalViewer) and I could not find anything suspicious until the exception hits me.
It would be great to get any tips and insight on how to proceed from here.
Chris
FUDForum. Page generated in 0.04314 seconds
