Re: adding markers to eugenia based editor after applying evl constraints to emfdiff model [message #528123 is a reply to message #527995] |
Mon, 19 April 2010 12:29 |
Dimitrios Kolovos Messages: 1776 Registered: July 2009 |
Hi Saad,
The namespace uri of *.emfdiff models is
http://www.eclipse.org/emf/compare/diff/1.1 As you're running this
through a standalone Java application, please make sure that the EMF
diff EPackage is actually in the EPackage registry before trying to load
the model.
Dimitris
saad bin abid wrote:
> Hello Dimitrios,
> thanks again for the reply. yes i changed the Jre version and it started
> working now. I have one more question regarding
> models.add(createEmfModel("Model", "models/result.emfdiff", "x", true,
> true));
> when i am trying to load the models both the instance and the meta
> model, I want to know what should i put in "x", which has to be the meta
> model for the emfdiff model? any ideas how can i actually load the
> models before i apply the constraints on results.emfdiff?
> best regards
> saad
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: adding markers to eugenia based editor after applying evl constraints to emfdiff model [message #528679 is a reply to message #528673] |
Wed, 21 April 2010 13:06 |
Hi Saad,
You'll need to add the org.eclipse.emf.compare.diff and
org.eclipse.emf.compare.match plugins to the dependencies of your
project and add these two lines at the beginning of your getModels() method:
EPackage.Registry.INSTANCE.put(DiffPackage.eNS_URI,
DiffPackage.eINSTANCE);
EPackage.Registry.INSTANCE.put(MatchPackage.eNS_URI,
MatchPackage.eINSTANCE);
Dimitris
> Hello Dimitrios,
> Thank you again. I used the following code in EvlStandaloneExample.java
> class to upload the models
> @Override
> public List<IModel> getModels() throws Exception {
> List<IModel> models = new ArrayList<IModel>();
> String file="
> C:/eclipse-Galileo/eclipse/Sciaml-Test/ie.lero.helloworld.de
> mo.compare/diffmodel/result.emfdiff ";
> models.add(createEmfModelByURI("Model", file,
> "http://www.eclipse.org/emf/compare/diff/1.1", true, true));
> return models;
> @Override
> public String getSource() throws Exception {
> return "
> mo.compare/diffmodel.evl ";
> where "result.emfdiff" and "diffmodel.evl" are in runtime enviornment.
> When i run the code using incremental plug-in i get the following error
> at org.eclipse.epsilon.examples.standalone.EpsilonStandaloneExa
> mple.getFile(EpsilonStandaloneExample.java:98)
> mple.execute(EpsilonStandaloneExample.java:45)
> at ie.lero.scicalc.emfdiffmarkers.builder.SampleBuilder.checkXM
> L(SampleBuilder.java:113)
> at ie.lero.scicalc.emfdiffmarkers.builder.SampleBuilder$SampleR
> esourceVisitor.visit(SampleBuilder.java:62)
> at org.eclipse.core.internal.resources.Resource$2.visit(Resourc
> e.java:108)
> at org.eclipse.core.internal.resources.Resource$1.visitElement(
> Resource.java:60)
> at org.eclipse.core.internal.watson.ElementTreeIterator.doItera
> tion(ElementTreeIterator.java:82)
> tion(ElementTreeIterator.java:86)
> at org.eclipse.core.internal.watson.ElementTreeIterator.iterate
> (ElementTreeIterator.java:127)
> at org.eclipse.core.internal.resources.Resource.accept(Resource
> .java:70)
> .java:106)
> .java:90)
> at ie.lero.scicalc.emfdiffmarkers.builder.SampleBuilder.fullBui
> ld(SampleBuilder.java:124)
> at ie.lero.scicalc.emfdiffmarkers.builder.SampleBuilder.build(S
> ampleBuilder.java:93)
> at org.eclipse.core.internal.events.BuildManager$2.run(BuildMan
> ager.java:627)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui
> ldManager.java:170)
> ldManager.java:201)
> at org.eclipse.core.internal.events.BuildManager$1.run(BuildMan
> ager.java:253)
> ldManager.java:256)
> at org.eclipse.core.internal.events.BuildManager.basicBuildLoop
> (BuildManager.java:309)
> at org.eclipse.core.internal.events.BuildManager.build(BuildMan
> ager.java:341)
> at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBu
> ildJob.java:140)
> at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJ
> ob.java:238)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> it is not getting the files to load. could you please help me with this?
> best regards
> saad
Re: adding markers to eugenia based editor after applying evl constraints to emfdiff model [message #588377 is a reply to message #588370] |
Hi Saad,
the model.
Dimitris
> Hello Dimitrios,
> true));
> best regards
> saad
Re: adding markers to eugenia based editor after applying evl constraints to emfdiff model [message #588509 is a reply to message #588493] |
Hi Saad,
Dimitris
> Hello Dimitrios,
> @Override
> String file="
> return models;
> @Override
> return "
> e.java:108)
> Resource.java:60)
> .java:70)
> .java:106)
> .java:90)
> ager.java:627)
> ldManager.java:170)
> ldManager.java:201)
> ager.java:253)
> ldManager.java:256)
> ager.java:341)
> ildJob.java:140)
> ob.java:238)
> best regards
> saad
FUDForum. Page generated in 0.04208 seconds
