Home » Archived » Maven Integration (M2E) » HTTP Proxy issues
HTTP Proxy issues [message #527315] Wed, 14 April 2010 15:13
I am behind a non-authenticated proxy, Maven 2.2.1 works fine with the following settings.xml:
settings>
<localRepository>C:\.m2\repository</localRepository>
<proxies>
<proxy>
<id>main</id>
<active>true</active>
<protocol>http</protocol>
<host>primary-proxy</host>
<port>8080</port>
</proxy>
</proxies>
</settings>
Installed Galileo, and Maven M2E. Galileo proxy setting works fine, I can update and download packages.
On startup, Maven console complains:
Unable to update index for central|http://repo1.maven.org/maven2
The workspace/metadata/.log file shows:
!SESSION 2010-04-14 14:53:55.932 -----------------------------------------------
eclipse.buildId=M20100211-1343
java.version=1.6.0_16
Command-line arguments: -os win32 -ws win32 -arch x86 -debug
!ENTRY org.eclipse.core.net 1 0 2010-04-14 14:54:24.589
!MESSAGE System property http.proxyHost is not set but should be primary-proxy.
!MESSAGE System property http.proxyPort is not set but should be 8080.
!ENTRY org.maven.ide.eclipse 4 0 2010-04-14 14:54:29.667
!MESSAGE Unable to update index for central|http://repo1.maven.org/maven2
!STACK 0
java.io.IOException: Authorization exception retrieving nexus-maven-repository-index.properties
at org.sonatype.nexus.index.updater.DefaultIndexUpdater$WagonFe tcher.retrieve(DefaultIndexUpdater.java:681)
at org.sonatype.nexus.index.updater.AbstractResourceFetcher.ret rieve(AbstractResourceFetcher.java:22)
at org.sonatype.nexus.index.updater.DefaultIndexUpdater.downloa dIndexProperties(DefaultIndexUpdater.java:493)
at org.sonatype.nexus.index.updater.DefaultIndexUpdater.access$ 100(DefaultIndexUpdater.java:74)
at org.sonatype.nexus.index.updater.DefaultIndexUpdater$IndexAd aptor.setProperties(DefaultIndexUpdater.java:780)
at org.sonatype.nexus.index.updater.DefaultIndexUpdater.fetchAn dUpdateIndex(DefaultIndexUpdater.java:954)
at org.sonatype.nexus.index.updater.DefaultIndexUpdater.fetchAn dUpdateIndex(DefaultIndexUpdater.java:138)
at org.maven.ide.eclipse.internal.index.NexusIndexManager.updat eRemoteIndex(NexusIndexManager.java:1060)
at org.maven.ide.eclipse.internal.index.NexusIndexManager.updat eIndex(NexusIndexManager.java:1013)
at org.maven.ide.eclipse.internal.index.NexusIndexManager$1.run (NexusIndexManager.java:624)
at org.maven.ide.eclipse.internal.index.IndexUpdaterJob.run(Ind exUpdaterJob.java:71)
Previous Topic:m2e not showing up in menus
Next Topic:not able to see download source context menu
Current Time: Thu Nov 06 14:55:13 EST 2025
Powered by FUDForum. Page generated in 0.03354 seconds
