Home » Eclipse Projects » Rich Client Platform (RCP) » How to show a job's progress within a wizard
How to show a job's progress within a wizard [message #527030] Tue, 13 April 2010 14:25 Go to next message
Hello again,
my problem is as follows:
I have several wizards with pages calling methods with long running
opearations (implemented as Jobs) for which I want to show a progress
bar without knowing, that they are Jobs.
I'll try to build an example:
public class SomeWizard extens Wizard implements INewWizard {
void refreshPage(IItemProvider provider) {
Set<Item> items = provider.getItems();
public class ItemProvider implements IItemProvider {
public Set<Item> getItems() {
ItemJob itemJob = new ItemJob();
itemJob.setUser(true);
itemJob.schedule();
itemJob.join();
return itemJob.getResult();
If I call these methods from a command handler, the usual progress
dialog is raised. But if I call these methods within a wizard or wizard
page, the progress dialog (and also the indicator in the trim) does not
show, probably because the wizard is already a dialog.
Does anyone know, how either force the progress dialog to be shown or
how to integrate any job's progress into a wizard's progress bar.
The following things I've tried already:
- Extends WizardDialog setting it to non-modal:
no effect except the dialog isn't modal anymore :)
- Providing the wizards progress monitor in a custom service and
obtaining it within the (subsequent) executed job from the service:
modification of the obtained mointor results in an "invalid thread
access" (which makes sense afterwards)
Hope anyone has an idea.
Thanks in advance.
Best regards
Sascha
Re: How to show a job's progress within a wizard [message #527213 is a reply to message #527030] Wed, 14 April 2010 09:45 Go to previous messageGo to next message
This code exits in org.eclipse.egit.ui.internal.clone.GitCloneWizard
In your wizard you can do this:
op = your runner with monitor.
try {
// Perform clone in ModalContext thread with progress
// reporting on the wizard.
getContainer().run(true, true, new IRunnableWithProgress() {
public void run(IProgressMonitor monitor)
throws InvocationTargetException,
InterruptedException {
op.run(monitor);
Best Regards,
Wim Jongman
-- Does fuzzy logic tickle?
(Eclipse Old Skool Quote Service)
> Hello again,
> @Override
> itemJob.schedule();
> itemJob.join();
> Thanks in advance.
> Best regards
> Sascha
Re: How to show a job's progress within a wizard [message #527273 is a reply to message #527213] Wed, 14 April 2010 11:54 Go to previous messageGo to next message
Hi Wim,
thanks for your hint, however this is not what I wanted, because
I have no Runnable within my wizard but a Job subsequently scheduled.
Now I found out, that my solution to publish the monitor from the wizard
to a service and implementing the job to call the service looking for
any provided monitors (and use them) DOES work, if the monitor is
accessed within the UI thread (which can be done the usual way).
I think that's not as clean as could be but for my developer nose it
smells not too strong :)
So this is just another question I've answered myself :)
Thanks anyway.
Best regards
Sascha
Am 14.04.2010 15:45, schrieb Wim Jongman:
> try {
> op.run(monitor);
Re: How to show a job's progress within a wizard [message #527282 is a reply to message #527273] Wed, 14 April 2010 12:04 Go to previous messageGo to next message
Hi Sascha,
> for my developer nose it smells not too strong :)
I think you have a cold... ;-)
The job has a run(monitor) method. Why not call that in the wizard like this:
op = your job
try {
op.run(monitor);
That really smells like roses!
Best Regards,
Wim Jongman
-- ... File not found. Should I fake it? (Y/N)
> Hi Wim,
> Thanks anyway.
> Best regards
> Sascha
>> try {
>> op.run(monitor);
Re: How to show a job's progress within a wizard [message #527362 is a reply to message #527282] Wed, 14 April 2010 23:53 Go to previous messageGo to next message
Hi Wim,
thanks for nose-caring :)
I agree with you, but my wizard also doesn't know that there's a job,
that's why I said 'subsequently'.
My wizard has got a simple interface which it uses calling methods
provided by this interface. The implementation of the interface comes
from another bundle and in some methods it does it's work by scheduling
a job. But this is completely hidden from the wizard.
Otherwise your solution would be the right way I think.
Am 14.04.2010 18:04, schrieb Wim Jongman:
> Hi Sascha,
> op = your job
> try {
> op.run(monitor);
Re: How to show a job's progress within a wizard [message #527363 is a reply to message #527030] Thu, 15 April 2010 00:17 Go to previous message
You need to wrap the job & runnable. Else you have to wait till
https://bugs.eclipse.org/bugs/show_bug.cgi?id=293098 is fixed
- Prakash
Platform UI Team, IBM
www.eclipse-tips.com
Previous Topic:Associating javadoc with a plugin
Next Topic:Icon Sharing between plugins
Current Time: Wed Aug 27 04:41:14 EDT 2025
Powered by FUDForum. Page generated in 0.51704 seconds
