Re: Could not publish to the server. Eclipse 3.5 SR-2 Build id: 20100218-1602 [message #526664 is a reply to message #526327] |
Mon, 12 April 2010 14:23 |
Larry Isaacs Messages: 1354 Registered: July 2009 |
Thanks for the stack trace. It shows you are running with the WTP
3.1.2patch that addresses Bug 305306[1] and are suffering from the
regression mentioned in that bug. I assume you picked it up through
Help -> Check for Updates. You can re-install Eclipse Java EE IDE
tar.gz. I believe the problem WTP 3.1.2patch has been removed, so you
could try Check for Updates again and not suffer the same fate, though I
just tried it and no updates were found.
Larry
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=305306
Yiannis wrote:
> After installing the latest Eclipse Java EE IDE for Web Developers web
> project files are no longer published to the tomcat server when the
> project include jars in the J2EE module dependencies. The current setup
> was working fine with at least 2 versions of eclipse and various
> configurations and operating systems.
> In detail:
> Having a standalone project and linked to a user library works as it
> used to and as expected. However if I add one .jar dependency to the
> project (from another project in the workspace) it fails immediately
> with the following error: Could not publish to the server.
> (Stack trace at the end of the message)
> The web project I am working is part of a workspace with a few other
> projects. Including the projects as J2EE module dependencies works. But
> the moment I add any of jars from the projects I depend on, I get the
> could not publish error.
> I tried to work around this by combining all the workspace jars my
> project depends on a user library and then add this library to the J2EE
> module dependencies. This is solving the error but the result is that
> none of the files from WebContent directory are published. The
> .metadata/.plugins/org.eclipse.wst.server.core/tmp0/wtpwebap
> ps/myproject/ directory contains only the WEB-INF with the classes and
> the lib folder with the jars. If i publish manually (just copy all the
> files from my project the wtpwebapps) everything works well, but then
> auto publish does not work any more for .jsp or plain files (only works
> for editing java source files).
> Still, if my project does not depend on other local projects, everything
> works fine.
> The stack trace is:
> org.eclipse.core.runtime.AssertionFailedException: null argument:
> at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:85)
> at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:73)
> at org.eclipse.core.runtime.Path.initialize(Path.java:577)
> at org.eclipse.core.runtime.Path.<init>(Path.java:163)
> at
> org.eclipse.wst.web.internal.deployables.ComponentDeployable .addUtilMember(ComponentDeployable.java:366)
> at
> org.eclipse.jst.j2ee.internal.deployables.J2EEFlexProjDeploy able.addUtilMember(J2EEFlexProjDeployable.java:160)
> at
> org.eclipse.wst.web.internal.deployables.ComponentDeployable .addUtilMembers(ComponentDeployable.java:354)
> at
> org.eclipse.jst.j2ee.internal.deployables.J2EEFlexProjDeploy able.members(J2EEFlexProjDeployable.java:256)
> at
> org.eclipse.wst.server.core.internal.ModulePublishInfo.getDe lta(ModulePublishInfo.java:366)
> at
> org.eclipse.wst.server.core.internal.ServerPublishInfo.getDe lta(ServerPublishInfo.java:368)
> at
> org.eclipse.wst.server.core.internal.Server.getPublishedReso urceDelta(Server.java:1363)
> at
> org.eclipse.wst.server.core.model.ServerBehaviourDelegate.ge tPublishedResourceDelta(ServerBehaviourDelegate.java:653)
> at
> org.eclipse.jst.server.tomcat.core.internal.TomcatServerBeha viour.getPublishedResourceDelta(TomcatServerBehaviour.java:8 96)
> at
> org.eclipse.jst.server.tomcat.core.internal.PublishOperation 2.publishDir(PublishOperation2.java:110)
> at
> org.eclipse.jst.server.tomcat.core.internal.PublishOperation 2.execute(PublishOperation2.java:78)
> at
> org.eclipse.wst.server.core.model.ServerBehaviourDelegate.pe rformTasks(ServerBehaviourDelegate.java:1136)
> at
> org.eclipse.wst.server.core.model.ServerBehaviourDelegate.pu blish(ServerBehaviourDelegate.java:853)
> at
> org.eclipse.wst.server.core.model.ServerBehaviourDelegate.pu blish(ServerBehaviourDelegate.java:708)
> at
> org.eclipse.wst.server.core.internal.Server.publishImpl(Serv er.java:2731)
> at
> org.eclipse.wst.server.core.internal.Server$PublishJob.run(S erver.java:278)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> The session data are:
> eclipse.buildId=unknown
> java.version=1.6.0_18
> java.vendor=Sun Microsystems Inc.
> BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_GB
> Framework arguments: -product org.eclipse.epp.package.jee.product
> Command-line arguments: -os linux -ws gtk -arch x86_64 -product
FUDForum. Page generated in 0.02958 seconds
