Home » Eclipse Projects » Eclipse Scout » Change default visibility of a column
Change default visibility of a column [message #526271] Fri, 09 April 2010 08:32 Go to next message
I have a table page that is shown below a project and on its own. When shown below a project, I want the country column to be invisible:
  public void execInitPage() throws ProcessingException {
        getTable().getCountryColumn().setVisible(getProjectNr()==null);
My problem was that hitting the reset menu from the column headers will revert the column to its default configured state (ie. the visible property of the column) ignoring the code in execInitPage.
What is the recommended practice in this situation?
Right now I use the following on the column level in addition to the above:
      public boolean getConfiguredVisible() {
        return getProjectNr()==null;
The SDK shows this as "Unaccepted value!" but it works. Smile
Re: Change default visibility of a column [message #526274 is a reply to message #526271] Fri, 09 April 2010 08:39 Go to previous messageGo to next message
Hi Alex
For your problem the recommendet practice would be following:
    getTable().getCountryColumn().setDisplayable(getProjectNr()==null);
Your second code-fragment would be obsolete with the recommended way.
Greetings
Stephan
Re: Change default visibility of a column [message #526304 is a reply to message #526274] Fri, 09 April 2010 11:08 Go to previous messageGo to next message
Stephan Leicht wrote on Fri, 09 April 2010 14:39
getTable().getCountryColumn().setDisplayable(getProjectNr()= =null);
Hm, I see. If I read the specification correctly, the customer wants the column there, but "invisible by default" under certain conditions. My solution allows the client to make the column visible if so desired. That wouldn't be possible if I used the displayable property, right?
Thanks for the reminder regarding visible vs. displayable, though. Smile
[Updated on: Fri, 09 April 2010 11:08] by Moderator
Re: Change default visibility of a column [message #580362 is a reply to message #526274] Fri, 09 April 2010 11:08 Go to previous message
> [/code]
Thanks for the reminder regarding visible vs. displayable, though. :)
Previous Topic:Re: Change default visibility of a column
Next Topic:Behaviour of disabled form fields
Current Time: Wed Nov 05 08:51:44 EST 2025
Powered by FUDForum. Page generated in 0.05077 seconds
