Re: Create Mindmap wizard won't finish in osx (DSL Toolkit book) [message #525214 is a reply to message #525213] |
Thu, 17 September 2009 16:28 |
Ed Merks Messages: 33216 Registered: July 2009 |
Ian,
From a thread in the EMF newsgroup, it sounds like there is some Mac
issue with the default selection in the drop down. I gather that if you
choose a different choice and then the choice you want, the finish
button will enable.
ian mayo wrote:
> Hi all,
> I'm working my way through Richard's DSL Toolkit book.
> I've genreated my model, and then generated the editor from it. I've
> then run the target application (as instructed on Page 44). I've
> created a blank General project, and have requested a new Mindmap
> Model using the EMF Model Creation Wizard. I've selected Map as the
> Model Object, but the Finish button is still disabled. The page of
> the wizard is showing a valid Model Object and XML encoding, but only
> Back and Cancel are enabled.
> Note, this problem doesn't arise running the toolkit under Windows XP.
> Regards,
> Ian
Ed Merks
Re: Create Mindmap wizard won't finish in osx (DSL Toolkit book) [message #584011 is a reply to message #525213] |
Ian,
button will enable.
ian mayo wrote:
> Hi all,
> Regards,
> Ian
Ed Merks
FUDForum. Page generated in 0.03849 seconds
