Home » Modeling » Amalgam » Is there any way to generate an indefinite number of target models in a qvto m2m transformation?
Is there any way to generate an indefinite number of target models in a qvto m2m transformation? [message #525204] |
Mon, 24 August 2009 15:45 |
Toñi Reina Messages: 209 Registered: July 2009 |
Hi all,
my question is related to the mindmap2xhtml (included in the book
Eclipse Modeling Project: A Domain-Specific Language (DSL) Toolkit) or
the Uml2Xhtml example that Sergey has mentioned in his answer to my
previous question
('org.eclipse.m2m/org.eclipse.m2m.qvt.oml/examples/org.eclip se.m2m.qvt.oml.econ2009.tutorial').
In both cases a unique xhtml file is generated that contains all the
mindmap information, in the first example, and all the uml model
information in the second one. But what if I want to generate different
xhtml files, one for each topic, in the first example, and one for
each class in the second one.
In both cases the number of instances of the output metamodel is
variable, because it depends on the number of topics in the first
example, and on the number of classes in the second one. My question is:
is there any way of specifying this in qvto?
Toñi
Re: Is there any way to generate an indefinite number of target models in a qvto m2m transformation? [message #525205 is a reply to message #525204] |
Mon, 24 August 2009 18:43 |
Sergey Boyko Messages: 171 Registered: July 2009 |
Hi Toñi ,
There's no direct way to express arbitrary number of output models in
qvto engine.
Described scenario can be archived like follows:
- using Ant script. First invocation of qvto engine would create output
model with root objects each for separate entity. Then this model can be
processed with Xpand template to save each entity to physical file.
- using Java black-box library with qvto script. Such library can take
same model produced by qvto script (with arbitrary number of root
objects) and then save each object as system file.
Sergey
Toñi Reina Quintero wrote:
> Hi all,
> previous question
> xhtml files, one for each topic, in the first example, and one for each
> Best regards,
> Toñi
Re: Is there any way to generate an indefinite number of target models in a qvto m2m transformation? [message #525206 is a reply to message #525205] |
Mon, 24 August 2009 20:30 |
As far as I understood, they are two alternative ways of solving the
problem, aren't they?
Sergey Boyko escribió:
> Hi Toñi ,
> qvto engine.
> Regards,
> Sergey
>> Hi all,
>> previous question
>> different xhtml files, one for each topic, in the first example, and
>> one for each class in the second one.
>> is: is there any way of specifying this in qvto?
>> Best regards,
>> Toñi
Re: Is there any way to generate an indefinite number of target models in a qvto m2m transformation? [message #525208 is a reply to message #525206] |
Tue, 25 August 2009 13:37 |
Hi Toñi ,
Yes, I've suggested two ways:
1. Coupling with Xpand by means of Ant script.
2. Providing black-box library for qvto to achieve desired behavior.
However it is not improbable that there are some other solutions for
your scenario ;)
Sergey
>> Hi Toñi ,
>> qvto engine.
>> output model with root objects each for separate entity. Then this
>> model can be processed with Xpand template to save each entity to
>> physical file.
>> Regards,
>> Sergey
>>> Hi all,
>>> or the Uml2Xhtml example that Sergey has mentioned in his answer to
>>> my previous question
>>> Best regards,
>>> Toñi
Re: Is there any way to generate an indefinite number of target models in a qvto m2m transformation? [message #583877 is a reply to message #525204] |
Hi Toñi ,
qvto engine.
Sergey
> Hi all,
> previous question
> Best regards,
> Toñi
Re: Is there any way to generate an indefinite number of target models in a qvto m2m transformation? [message #583890 is a reply to message #525205] |
> Hi Toñi ,
> qvto engine.
> Regards,
> Sergey
>> Hi all,
>> previous question
>> Best regards,
>> Toñi
Re: Is there any way to generate an indefinite number of target models in a qvto m2m transformation? [message #583919 is a reply to message #525206] |
Hi Toñi ,
your scenario ;)
Sergey
>> Hi Toñi ,
>> qvto engine.
>> physical file.
>> Regards,
>> Sergey
>>> Hi all,
>>> Best regards,
>>> Toñi
Current Time: Sat Apr 27 04:26:38 GMT 2024
Powered by FUDForum. Page generated in 0.03774 seconds
