Missing dependency on JSch when installing EGit on 3.5.2 [message #524824] |
Fri, 02 April 2010 14:52  |
After updating to Eclipse 3.5.2 on Ubuntu lucid I'm unable to install EGit because it can't locate JSch:
Cannot complete the install because one or more required items could not be found.
Software being installed: Eclipse JGit Feature (Incubation) 0.8.0.201003292117 (org.eclipse.jgit.feature.group 0.8.0.201003292117)
Missing requirement: JGit Core (Incubation) 0.7.1 (org.eclipse.jgit 0.7.1) requires 'package com.jcraft.jsch [0.1.41,0.2.0)' but it could not be found
Missing requirement: JGit Core (Incubation) 0.8.0.201003292111 (org.eclipse.jgit 0.8.0.201003292111) requires 'package com.jcraft.jsch [0.1.41,0.2.0)' but it could not be found
Cannot satisfy dependency:
From: Eclipse JGit Feature (Incubation) 0.8.0.201003292117 (org.eclipse.jgit.feature.group 0.8.0.201003292117)
To: org.eclipse.jgit 0.0.0
I've checked that jsch is installed:
jamie@avior:~$ aptitude show libjsch-java
Package: libjsch-java
State: installed
Automatically installed: yes
Version: 0.1.42-1build1
and the JAR is installed:
jamie@avior:~$ ls -al /usr/share/java/jsch*
-rw-r--r-- 1 root root 208590 2009-10-19 17:38 /usr/share/java/jsch-0.1.42.jar
lrwxrwxrwx 1 root root 15 2010-04-02 13:23 /usr/share/java/jsch.jar -> jsch-0.1.42.jar
and that it's listed in the plugin registry:
com.jcraft.jsch (0.1.42) "bundleName" [Resolved]
org.eclipse.jsch.core (1.1.100.I20090430-0408) "JSch Core" [Active]
org.eclipse.jsch.ui (1.1.200.r35x_20100210-1114) "JSch UI" [Starting]
Id: com.jcraft.jsch, Version: 0.1.42, Location: reference:file:plugins/com.jcraft.jsch_0.1.42.jar
The symlink from /usr/lib/eclipse/plugins is still there:
jamie@avior:/usr/lib/eclipse/plugins$ ls -al com.jcraft.jsch_0.1.42.jar
lrwxrwxrwx 1 root root 28 2010-04-02 13:23 com.jcraft.jsch_0.1.42.jar -> ../../../share/java/jsch.jar
I'm unsure how to debug this further.. any ideas?
Jamie
Re: Missing dependency on JSch when installing EGit on 3.5.2 [message #524867 is a reply to message #524824] |
Sat, 03 April 2010 03:39   |
> be found.
> not be found Missing requirement: JGit Core (Incubation)
> (org.eclipse.jgit.feature.group 0.8.0.201003292117) To:
> State: installed
> jsch-0.1.42.jar
We import the JSch stuff by package and version number and your version
of the JSch bundle does not export the packages with versions, which
is the recommended OSGi practice. Versions of EGit prior to 0.7 did not
require a specific version of JSch.
$ unzip -c /usr/share/java/jsch-0.1.42.jar META-INF/MANIFEST.MF|head
Archive: /usr/share/java/jsch-0.1.42.jar
inflating: META-INF/MANIFEST.MF
Manifest-Version: 1.0
Ant-Version: Apache Ant 1.7.1
Created-By: 14.0-b16 (Sun Microsystems Inc.)
Bundle-ManifestVersion: 2
Bundle-Version: 0.1.42
Export-Package: com.jcraft.jsch, com.jcraft.jsch.jce;x-internal:=true,
com.jcraft.jsch.jcraft;x-internal:=true
Compare with the Eclipse packaging which has version numbers in Export-
Package.
Bundle-ClassPath: .
Bundle-Vendor: %venderName
Bundle-Localization: plugin
Bundle-RequiredExecutionEnvironment: J2SE-1.4
Bundle-Name: %bundleName
Bundle-SymbolicName: com.jcraft.jsch
Created-By: 1.4.0 (Sun Microsystems Inc.)
Export-Package: com.jcraft.jsch;version="0.1.41",com.jcraft.jsch.jce;v
ersion="0.1.41";x-internal:=true,com.jcraft.jsch.jcraft;version= "0.1.
41";x-internal:=true,com.jcraft.jsch.jgss;version="0.1.41";x-internal
:=true
Bundle-Version: 0.1.41.v200903070017
You should report this with Ubuntu as they are the ones providing the
packages,
-- robin
Re: Missing dependency on JSch when installing EGit on 3.5.2 [message #527312 is a reply to message #524867] |
Wed, 14 April 2010 15:00   |
Robin Rosenberg wrote on Sat, 03 April 2010 03:39 |
<snip>
Package.
Bundle-ClassPath: .
:=true
packages,
I've attempted to work around this by repackaging the JSch JAR with a corrected Export-Package:
jamie@avior:~/Downloads/jsch/jsch-0.1.42/dist/lib$ unzip -c /usr/share/java/jsch-0.1.42.jar META-INF/MANIFEST.MF|head
Export-Package: com.jcraft.jsch;version="0.1.42",com.jcraft.jsch.jce;v
ersion="0.1.42";x-internal:=true,com.jcraft.jsch.jcraft;version="0.1.
However, Eclipse doesn't seem to recognise my Export-Package line and still complains that the dependency isn't fulfilled. I tried building a JAR by hand (using the tarball from JSch upstream), ensuring the manifest included an identical Export-Package attribute, with the same problem.
I'd really appreciate some pointers
Thanks again
Re: Missing dependency on JSch when installing EGit on 3.5.2 [message #579506 is a reply to message #524867] |
> <snip>
> Package.
> Bundle-ClassPath: .
> :=true
> packages,
ersion="0.1.42";x-internal:=true,com.jcraft.jsch.jcraft;version= "0.1.
Thanks again
FUDForum. Page generated in 0.07741 seconds
