Home » Modeling » M2T (model-to-text transformation) » [XPAND/XTEND] Workflow error at running
[XPAND/XTEND] Workflow error at running [message #524789] Fri, 02 April 2010 10:02 Go to next message
I am having trouble running my workflow in an Xpand/Xtend M2M/M2T project.
Basically, I have a object model, I generate from it a relationnal model using Xtend, and from my relationnal model I want to generate SQL code using Xpand (I need the M2M because I'll use the object model to generate other stuff).
The M2M part works, the outmodel.xmi file is created with the data.
From the error message I get, I believe that as I load 2 metamodels, my workflow doesn't know which one to use once I try to load my outmodel.xmi
Workflow :
<workflow>
	<property name="src-gen" value="src-gen" />
	<property name="relationnalmodel" value="src-gen/outModel.xmi" />
	<bean class="org.eclipse.emf.mwe.utils.StandaloneSetup">
		<platformUri value=".." />
		<!-- first ecore -->
		<registerEcoreFile value="platform:/resource/genCPP/src/metamodel/metamodel.ecore"/>
		<!-- second ecore -->
		<registerEcoreFile value="platform:/resource/genCPP/src/metamodel/relationnel.ecore" />
	</bean>
	<!--read the model -->
	<component class="org.eclipse.emf.mwe.utils.Reader">
		<uri value="src/Model.xmi" />
		<modelSlot value="model" />
	</component>
	<!--transform the model -->
	<component class="org.eclipse.xtend.XtendComponent">
		<metaModel class="org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel" />
		<invoke value="object2relationnal::object2relationnal::transform(model)"/>
		<outputSlot value="newModel"/>
	</component>
	<!--write the new model -->
	<component class="org.eclipse.emf.mwe.utils.Writer">
		<modelSlot value="newModel" />
		<uri value="${relationnalmodel}" />
	</component>
	<!-- load the new model and store it in 'newModel' -->
	</component>
	<!--once model is loaded, generate SQL tables and SQL procedures-->
	<component class="org.eclipse.xpand2.Generator">
		<expand
			value="object2relationnal::SQL::main FOR Base" />
		<outlet path="${src-gen}" >
		</outlet>
	</component>
</workflow>
Error Message (I cut the beginning) :
2 avr. 2010 15:51:35 org.eclipse.emf.mwe.utils.StandaloneSetup registerPackage
INFO: Adding dynamic EPackage 'http://www.example.org/metamodel' from 'platform:/resource/genCPP/src/metamodel/metamodel.ecore'
INFO: Adding dynamic EPackage 'http://relationnel/1.0' from 'platform:/resource/genCPP/src/metamodel/relationnel.ecore'
2 avr. 2010 15:51:35 org.eclipse.emf.mwe.core.WorkflowRunner logIssues
ATTENTION: [WARNING]: no metamodels specified (use 'metaModel' property)!(Element: -UNKNOWN-; Reported by: -UNKNOWN-)
2 avr. 2010 15:51:35 org.eclipse.emf.mwe.core.container.CompositeComponent internalInvoke
INFO: Reader: Loading model from src/Model.xmi
INFO: XtendComponent: executing 'object2relationnal::object2relationnal'
INFO: Writer: Writing model to src-gen/outModel.xmi
INFO: Reader: Loading model from src-gen/outModel.xmi
INFO: Generator: generating 'object2relationnal::SQL::main FOR Base' => src-gen
2 avr. 2010 15:51:35 org.eclipse.xtend.expression.AbstractExpressionsUsingWorkflowComponent invokeInternal
GRAVE: Error in Component  of type org.eclipse.xpand2.Generator:
	EvaluationException : Couldn't find type or property 'Base'
	[64,4] on line 1 'Base'
2 avr. 2010 15:51:35 org.eclipse.emf.mwe.core.WorkflowRunner executeWorkflow
GRAVE: Workflow interrupted. Reason: Couldn't find type or property 'Base'
GRAVE: [ERROR]: Couldn't find type or property 'Base'(Element: Base; Reported by: Generator: generating 'object2relationnal::SQL::main FOR Base' => src-gen)
GRAVE: [ERROR]: Couldn't find type or property 'Base'(Element: EXPAND object2relationnal::SQL::main FOR Base; Reported by: Generator: generating 'object2relationnal::SQL::main FOR Base' => src-gen)
From the message, it seems I made at least two mistakes in workflow.
Maxime
Re: [XPAND/XTEND] Workflow error at running [message #524792 is a reply to message #524789] Fri, 02 April 2010 10:31 Go to previous message
hi, you haven't configured a metamodel for your generator component: try to add <metaModel class="org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel " />
to it.
second you should invoke the generator with your second model that is stored in newModel: <expand
value="object2relationnal::SQL::main FOR newModel" />
Previous Topic:[Xpand] unresolved proxy between ecore models
Next Topic:Check oaw
Current Time: Thu Nov 06 01:18:57 EST 2025
Powered by FUDForum. Page generated in 0.04987 seconds
