Home » Newcomers » Newcomers » How to apply these two agruement in eclipse?
How to apply these two agruement in eclipse? [message #524487] Thu, 01 April 2010 03:07 Go to next message
import java.util.regex.;
class Regex2 {
Pattern p = Pattern.compile(args[0]);
Matcher m = p.matcher(args[1]);
boolean b = false;
while(b = m.find()) {
System.out.print(m.start() + m.group());
And the command line:
java Regex2 "\d" ab34ef
How to do that in eclipse? I tried but don't work...because there are two arguments...I don't know how to input in the argument tab in the run setup
Re: How to apply these two agruement in eclipse? [message #524607 is a reply to message #524487] Thu, 01 April 2010 06:20 Go to previous message
"JavaBen" <benjamin.yau@gmail.com> wrote in message
news:hp1gmu$90m$1@build.eclipse.org...
> class Regex2 {
> public static void main(String[] args) {
> boolean b = false;
Enter them as you would enter them on the command line. Type "\d" ab34ef
into the Program arguments text box on the launch configuration dialog.
Previous Topic:Importing java application into eclipse
Next Topic:Linked Resources
Current Time: Fri Nov 07 01:36:30 EST 2025
Powered by FUDForum. Page generated in 0.08134 seconds
