Home » Language IDEs » PHP Development Tools (PDT) » not suspend when debugging with xdebug(plz help me)
not suspend when debugging with xdebug [message #524220] Wed, 31 March 2010 08:24 Go to next message
No way is currently offline No wayFriend
Hi, everybody.
I using PDT 2.1 with all package and Xdebug. Everything seems okay, but Eclipse wasn't suspend at break point or first line when I was debugging.
This is image:
http://i97.photobucket.com/albums/l236/cinhat_2006/3-31-20103-21-39PM.png
Thanks.
Re: not suspend when debugging with xdebug [message #524228 is a reply to message #524220] Wed, 31 March 2010 09:01 Go to previous messageGo to next message
Originally posted by: dkel50.hotremovemail.com
Try reading
http://www.eclipse.org/pdt/documents/XDebugGuideForPDT2.0.pd f
Dave Kelsey
On 31/03/10 09:24, No way wrote:
> Hi, everybody.
> This is image:
> Thanks.
Re: not suspend when debugging with xdebug [message #524237 is a reply to message #524220] Wed, 31 March 2010 09:41 Go to previous messageGo to next message
thank you, Dave.
I had read this guide.
I don't know way to eclipse suspend as this image in this guide.
Sry for my dump.
I try debug script but eclipse terminal, not suspend as this guide.
http://i97.photobucket.com/albums/l236/cinhat_2006/temp/3-31-20104-38-34PM.png
Re: not suspend when debugging with xdebug [message #524255 is a reply to message #524220] Wed, 31 March 2010 05:52 Go to previous messageGo to next message
Ensure xdebug is loaded and configured correctly. run a script with
phpinfo() in it to get the output.
If you are php 5.2 ensure you load xdebug with the appropriate
zend_extension or zend_extension_ts call in php.ini depending on whether
you are using thread safe or non thread safe.
if you are php 5.3 ensure you use just zend_extension.
try using the xdebug calls such as xdebug_break() in your script to see
if that suspends
Dave Kelsey
> Hi, everybody.
> This is image:
> Thanks.
Re: not suspend when debugging with xdebug [message #524256 is a reply to message #524220] Wed, 31 March 2010 05:52 Go to previous messageGo to next message
Also ensure that zend_optimiser is not enabled, check out the FAQ at
http://www.xdebug.org for more info.
Dave Kelsey
> Hi, everybody.
> This is image:
> Thanks.
Re: not suspend when debugging with xdebug [message #524450 is a reply to message #524220] Thu, 01 April 2010 02:26 Go to previous messageGo to next message
thank you, Dave.
I sure Xdebug configured and loaded corectly.
This is parametter of Xdebug in phpinfo(); and I don't install Zend Optimizer.
this is configure in php.ini
[XDEBUG]
;xDebug Configuration starts
zend_extension_ts = "C:\wamp\bin\php\php5.2.11\ext\php_xdebug-2.1.0beta3-5.2-vc6.dll"
xdebug.profiler_output_dir = "c:\wamp\tmp\xdebug"
xdebug.profiler_output_name = "cachegrind.out.%p"
xdebug.profiler_enable = 0
xdebug.profiler_append=0
xdebug.extended_info=1
xdebug.remote_enable=true
xdebug.remote_handler="dbgp"
xdebug.remote_mode=req
xdebug.remote_host="localhost"
xdebug.remote_port=10001
xdebug.idekey="XDebug"
xdebug.remote_log="c:\wamp\tmp\xdebug\xdebug_remot.log"
xdebug.show_exception_trace=0
xdebug.show_local_vars=1
xdebug.show_mem_delta=0
xdebug.trace_format=0
;xDebug Configuration ends
Xdebug parametters:
http://i97.photobucket.com/albums/l236/cinhat_2006/temp/4-1-20109-15-42AM.png
and error themes:
http://i97.photobucket.com/albums/l236/cinhat_2006/temp/4-1-20109-19-31AM.png
Re: not suspend when debugging with xdebug [message #524538 is a reply to message #524450] Thu, 01 April 2010 10:24 Go to previous messageGo to next message
I see you are capturing the log from xdebug could you post that from a
run that fails ?
Cheers
Dave Kelsey
On 01/04/10 03:26, No way wrote:
> thank you, Dave.
> I sure Xdebug configured and loaded corectly. This is parametter of
> [XDEBUG]
> zend_extension_ts =
> " C:\wamp\bin\php\php5.2.11\ext\php_xdebug-2.1.0beta3-5.2-vc6. dll "
> Xdebug parametters:
> and error themes:
Re: not suspend when debugging with xdebug [message #524717 is a reply to message #524538] Fri, 02 April 2010 01:50 Go to previous messageGo to next message
yes, that's right. I created a error when running a web page to see error themes of Xdebug.
Eclipse User wrote on Thu, 01 April 2010 06:24
run that fails ?
Cheers
Dave Kelsey
Re: not suspend when debugging with xdebug [message #524807 is a reply to message #524717] Fri, 02 April 2010 15:23 Go to previous messageGo to next message
Sorry I think you misunderstood. Can you post the output in the log of
you trying to run a web page to debug ?
Dave Kelsey
>> run that fails ?
>> Cheers
>> Dave Kelsey
Re: not suspend when debugging with xdebug [message #524863 is a reply to message #524807] Sat, 03 April 2010 04:20 Go to previous messageGo to next message
thank Dave,
this is log of xdebug:
-> <init xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" fileuri="file:///C:/wamp/www/testdebug/test.php" language="PHP" protocol_version="1.0" appid="2104" session="127002765789012" idekey="ECLIPSE_DBGP"><engine version="2.1.0rc1-dev"><![CDATA[Xdebug]]></engine><author><![CDATA[Derick Rethans]]></author><url><![CDATA[http://xdebug.org]]></url><copyright><![CDATA[Copyright (c) 2002-2010 by Derick Rethans]]></copyright></init>
<- feature_set -i 143 -n show_hidden -v 1
-> <response xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="feature_set" transaction_id="143" feature="show_hidden" success="1"></response>
<- feature_set -i 144 -n max_depth -v 3
-> <response xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="feature_set" transaction_id="144" feature="max_depth" success="1"></response>
<- feature_set -i 145 -n max_children -v 31
-> <response xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="feature_set" transaction_id="145" feature="max_children" success="1"></response>
<- feature_get -i 146 -n encoding
-> <response xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="feature_get" transaction_id="146" feature_name="encoding" supported="1"><![CDATA[iso-8859-1]]></response>
<- feature_get -i 147 -n supports_async
-> <response xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="feature_get" transaction_id="147" feature_name="supports_async" supported="1"><![CDATA[0]]></response>
<- stdout -i 148 -c 1
-> <response xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="stdout" transaction_id="148" success="1"></response>
<- stderr -i 149 -c 1
-> <response xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="stderr" transaction_id="149" success="0"></response>
<- breakpoint_set -i 150 -t line -f file:///C:%5Cwamp%5Cwww%5Ctestdebug%5Ctest.php -n 4
-> <response xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="breakpoint_set" transaction_id="150" id="21040001"></response>
<- step_into -i 151
-> <stream xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" type="stdout" encoding="base64"><![CDATA[Mw==]]></stream>
-> <response xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="step_into" transaction_id="151" status="stopping" reason="ok"></response>
<- stop -i 152
-> <response xmlns="urn:debugger_protocol_v1" xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="stop" transaction_id="152" status="stopped" reason="ok"></response>
Re: not suspend when debugging with xdebug [message #525301 is a reply to message #524863] Tue, 06 April 2010 03:28 Go to previous message
The output shows me that PDT is doing everything correctly. I see a
breakpoint being set on line 4 for c:\wamp\www\testdebug\test.php and I
see that is the initial script being executed. I see it doing a step
into which means it should stop at the first line but doesn't. I also
see a value of 3 being output. Could you post your script just in case I
there is something there that may cause the problem.
I don't know why this isn't working. Did you try adding an
xdebug_break(); line into your code and see if that works ? The only
other thing I can suggest is you try the xdebug mailing list and see if
you can get some help there.
Dave Kelsey
On 03/04/10 05:20, No way wrote:
> thank Dave,
> version="2.1.0rc1-dev"><![CDATA[Xdebug]]></engine><author ><![CDATA[Derick Rethans]]></author><url><![CDATA[http://xdebug.org]]></url><copyright><![CDATA[Copyright
> <- step_into -i 151
> <- stop -i 152
Previous Topic:Setting debug script variables
Next Topic:Autocomplete HTML/CSS
Current Time: Sun Mar 26 07:36:35 GMT 2023
Powered by FUDForum. Page generated in 0.02730 seconds
