Home » Eclipse Projects » Remote Application Platform (RAP) » Notification that click custom widget( run the J.S. file )to show information for a view (Notification that click custom widget( run the J.S. file )to show information for a view )
icon5.gif  Notification that click custom widget( run the J.S. file )to show information for a view [message #524201] Wed, 31 March 2010 03:14 Go to next message
hi,
everyone
I have created a custom widget, when I click my custom widget, I will run the J.S. file using the LAC class. Then I want to change the view( extends View Part), which is the normal view in the rap platform. Like the Properties view in the eclipse. I can change the label value of my view(extends View Part), but the value don't show in the IE. How to refresh the rap view?
Please give me some method about that. Thanks!
[Updated on: Wed, 31 March 2010 23:15] by Moderator
Re: Notification that click custom widget( run the J.S. file )to show information for a view [message #524512 is a reply to message #524201] Thu, 01 April 2010 04:15 Go to previous messageGo to next message
I'm sorry but I can't understand what you are trying to do. Could you
try to explain the problem in more detail?
Ralf
zezhenyan wrote:
> hi,
> everyone
Re: Notification that click custom widget( run the J.S. file )to show information for a view [message #524718 is a reply to message #524512] Thu, 01 April 2010 22:03 Go to previous messageGo to next message
hi,
Ralf
Thanks for you pay close attention to my question.
I want add a flex file in my rap view. Now I have finished it. Likes the Gmap demo. But I have a trouble.
When I click the view, which is coded by Java Scrip. I can change the value of the rap view in the Java Scrip code. for example "req.addParameter( gmapId + ".centerLocation", a );" then I want to change the value of the other view. for example:
" final GMap g = (GMap) View.viewMap.get(GMap.ID);
// g.addPropertyChangeListener(new PropertyChangeListener() {
// public void propertyChange(PropertyChangeEvent evt) {
// // TODO Auto-generated method stub
// label.setText(g.getCenterLocation());
// System.out.println(g.getCenterLocation()+"----------=========== ");
// }g.CENLoca);"
the text of label changed, but it didn't show in the rap view. I think maybe some method can refresh the value of the rap widget or control.
like that "var req = org.eclipse.swt.Request.getInstance();
req.send();"
maybe other methods. I am not sure. Could you understand me?
Re: Notification that click custom widget( run the J.S. file )to show information for a view [message #525317 is a reply to message #524718] Tue, 06 April 2010 04:07 Go to previous messageGo to next message
changes to widget properties that happen within a request life cycle are
immediately rendered, you don't need a refresh.
Is the label change a direct effect of a click in the custom widget by
the same user?
Do you see the changed label text after resizing the browser window? If
so, you probably change the label text in the background. In this case
you'd need a UICallback to "push" the changes to the client.
Hope this helps, Ralf
zezhenyan wrote:
> hi,
> Ralf
> // }g.CENLoca);"
> req.send();"
Re: Notification that click custom widget( run the J.S. file )to show information for a view [message #525863 is a reply to message #525317] Thu, 08 April 2010 00:38 Go to previous message
Thanks, I will try it again.
Previous Topic:User workspace
Next Topic:How can refresh a widget while running java script.
Current Time: Thu Nov 06 16:15:29 EST 2025
Powered by FUDForum. Page generated in 0.04623 seconds
