Home » Modeling » Epsilon » Debugging ETL
Debugging ETL [message #523830] |
Mon, 29 March 2010 09:32 |
Originally posted by: c.k.holmes.lboro.ac.uk
I'm running an ETL transformation via Ant, passing in various parameters
such as Source and Target to tell ETL what to transform and where to put
the result. What type are these parameters? And what operations can I
run on them to confirm that they are as expected?
The parameters are pssed into ETL from Ant viz:
<epsilon.etl src="${EtlFile}">
<model ref="${SourceName}" as="Source"/>
<model ref="${TargetName}" as="Target"/>
<model ref="${ReferenceName}" as="MessageSet"/>
</epsilon.etl>
Chris
Re: Debugging ETL [message #523858 is a reply to message #523840] |
Mon, 29 March 2010 16:00 |
Hi Dimitris,
I declare the variables as properties in Ant:
Source details
<property name="SourceDataDir" value="sourceDirectory"/>
<property name="SourceUri" location="SourceUrl"/>
<property name="SourceName" value="sourceName"/>
<property name="SourceMetaModel" value="sourceMetaModel.ecore"/>
<filelist
id="SourceFiles"
dir="${SourceDataDir}"
files=" <listOfFilesToBeParsed>"/>
Target details
<property name="TargetFile" value="target.model"/>
<property name="TargetUri" value="targetModelUrl"/>
<property name="TargetName" value="targetModelName"/>
<property name="TargetMetaModel" value="targetMetaModel.ecore"/>
Reference details
<property name="ReferenceFile" value="reference.model"/>
<property name="ReferenceUri" value="referenceUri"/>
<property name="ReferenceName" value="referenceModelName"/>
and then use the variables to define the source/target/reference models
for the ETL transformation:
</epsilon.etl>
I'd like to be able to inspect the values of Source/Target/MessageSet
from within ETL to convince myself that they are pointing to the
relevant models. I notice (e.g.) that from within ETL I can resolve
Target to:
org.eclipse.epsilon.workflow.tasks.ModelReference@5bedf
It would be useful if I could get hold of the object to which this
refers to confirm what it is. It ought to refer to a model, so if I
could get hold of the root element of the model I could confirm it's
URL, location, etc. and also navigate down to expected objects/attributes.
Hence, when I declare some variable within ETL, say:
var thing : Target!Thing;
and ETL fails, saying something like:
EXCEPTION: Type 'Target!Thing' not found
I can at least begin to confirm the identity, location, etc. of Target.
Best Wishes
Chris
Dimitris Kolovos wrote:
> Hi Chris,
> Are you referring to parameters passed to Epsilon programs via the
> <parameter> tag or to ANT variables such as ${SourceName}? Could you
> please also elaborate a bit on what sort of checks you'd like to run?
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hi,
>> parameters such as Source and Target to tell ETL what to transform and
>> where to put the result. What type are these parameters? And what
>> operations can I run on them to confirm that they are as expected?
>> </epsilon.etl>
>> Regards
>> Chris
Re: Debugging ETL [message #523883 is a reply to message #523858] |
Mon, 29 March 2010 17:38 |
Dimitrios Kolovos Messages: 1776 Registered: July 2009 |
Hi Chris,
Thanks for your detailed explanation! Target.target should return the
real EmfModel wrapped by the ModelReference and Target.target.modelFile
should return the location of the model file.
Dimitris
Chris Holmes wrote:
> Hi Dimitris,
> Source details
> <filelist
> id="SourceFiles"
> Target details
> Reference details
> </epsilon.etl>
> Target to:
> Best Wishes
> Chris
>> Hi Chris,
>> Cheers,
>> Dimitris
>> Chris Holmes wrote:
>>> Hi,
>>> and where to put the result. What type are these parameters? And what
>>> </epsilon.etl>
>>> Regards
>>> Chris
Re: Debugging ETL [message #523985 is a reply to message #523883] |
Tue, 30 March 2010 03:10 |
Hi dimitris,
Thanks, Is it possible to identify the metamodel on which
Target.target.modelFile is based? It would also be useful to be able to
query the packages imported into the underlying metamodel. e.g. if I
receive an error from ETL to the effect that some type is not defined
I'd like to be able to confirm the scope of the imports.
Best Wishes
Chris
> Hi Chris,
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hi Dimitris,
>> Source details
>> <filelist
>> id="SourceFiles"
>> Target details
>> Reference details
>> models for the ETL transformation:
>> </epsilon.etl>
>> Target to:
>> objects/attributes.
>> Best Wishes
>> Chris
>>> Hi Chris,
>>> Cheers,
>>> Dimitris
>>> Chris Holmes wrote:
>>>> Hi,
>>>> what operations can I run on them to confirm that they are as expected?
>>>> </epsilon.etl>
>>>> Regards
>>>> Chris
Re: Debugging ETL [message #523999 is a reply to message #523985] |
Tue, 30 March 2010 04:10 |
Hi Chris,
You can identify the metamodel URI by calling Target.target.metamodelUri
or the metamodel file by calling Target.target.metamodelFile. You can
also navigate the metamodel by reflection (i.e. pick 1 model element,
call it's eClass() method and you're now at the metamodel level). Please
let me know if you need more specific examples.
Dimitris
Chris Holmes wrote:
> Hi dimitris,
> Best Wishes
> Chris
>> Hi Chris,
>> Target.target.modelFile should return the location of the model file.
>> Cheers,
>> Dimitris
>> Chris Holmes wrote:
>>> Hi Dimitris,
>>> Source details
>>> <filelist
>>> id="SourceFiles"
>>> Target details
>>> Reference details
>>> </epsilon.etl>
>>> Target to:
>>> objects/attributes.
>>> Best Wishes
>>> Chris
>>>> Hi Chris,
>>>> Cheers,
>>>> Dimitris
>>>> Chris Holmes wrote:
>>>>> Hi,
>>>>> expected?
>>>>> </epsilon.etl>
>>>>> Regards
>>>>> Chris
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: Debugging ETL [message #524007 is a reply to message #523999] |
Tue, 30 March 2010 09:49 |
Hi Dimitris,
Is the following call correct?
('Metamodel file: ' + Target.target.metamodelFile).println();
I run the following from the 'pre' section of a working ETL file:
-- some diagnostics
'Source model:'.println();
('Source: ' + Source).println();
('EMF model: ' + Source.target).println();
'Target model:'.println();
('Target: ' + Target).println();
('EMF model: ' + Target.target).println();
('Location: ' + Target.target.modelFile).println();
('Metamodel URI: ' + Target.target.metamodelUri).println();
I receive the following output and error message:
Source model:
Source: org.eclipse.epsilon.workflow.tasks.ModelReference@99c2aa
EMF model: org.eclipse.epsilon.emc.emf.xml.XmlModel@bb4c22
Target model:
Target: org.eclipse.epsilon.workflow.tasks.ModelReference@8380df
EMF model: org.eclipse.epsilon.emc.emf.EmfModel@181b9f7
Metamodel URI: http://blah../MyStuff
EXCEPTION: Internal error: java.lang.reflect.InvocationTargetException
Best Wishes
Chris
> Hi Chris,
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hi dimitris,
>> to query the packages imported into the underlying metamodel. e.g. if
>> I receive an error from ETL to the effect that some type is not
>> defined I'd like to be able to confirm the scope of the imports.
>> Best Wishes
>> Chris
>>> Hi Chris,
>>> Cheers,
>>> Dimitris
>>> Chris Holmes wrote:
>>>> Hi Dimitris,
>>>> Source details
>>>> <filelist
>>>> id="SourceFiles"
>>>> Target details
>>>> Reference details
>>>> </epsilon.etl>
>>>> Source/Target/MessageSet from within ETL to convince myself that
>>>> they are pointing to the relevant models. I notice (e.g.) that from
>>>> within ETL I can resolve Target to:
>>>> objects/attributes.
>>>> Best Wishes
>>>> Chris
>>>>> Hi Chris,
>>>>> you please also elaborate a bit on what sort of checks you'd like
>>>>> to run?
>>>>> Cheers,
>>>>> Dimitris
>>>>> Chris Holmes wrote:
>>>>>> Hi,
>>>>>> expected?
>>>>>> </epsilon.etl>
>>>>>> Regards
>>>>>> Chris
Re: Debugging ETL [message #524018 is a reply to message #524007] |
Tue, 30 March 2010 05:44 |
Hi Chris,
As you're loading the model by metamodel URI, metamodelFile is null and
this causes an exception. Could you please add another bug report for
this? Until we get this fixed you can get the raw URI of the metamodel
file (which will also be null in this case but won't throw an exception)
using:
('Metamodel file: ' + Target.target.metamodelFileUri).println();
On a side note, Target.target.xxx will only work when you're launching
the transformation through ANT. If at some point you invoke the ETL
transformation from Java/launch configuration there'll be no
ModelReference so all calls to Target.target.xxx will need to be
replaced by Target.xxx.
Dimitris
Chris Holmes wrote:
> Hi Dimitris,
> -- some diagnostics
> Source model:
> Target model:
> Location: C:\EclipseWorkspaces\blah...\MyStuff.model
> Best Wishes
> Chris
>> Hi Chris,
>> Target.target.metamodelUri or the metamodel file by calling
>> Target.target.metamodelFile. You can also navigate the metamodel by
>> reflection (i.e. pick 1 model element, call it's eClass() method and
>> you're now at the metamodel level). Please let me know if you need
>> Cheers,
>> Dimitris
>> Chris Holmes wrote:
>>> Hi dimitris,
>>> Best Wishes
>>> Chris
>>>> Hi Chris,
>>>> the real EmfModel wrapped by the ModelReference and
>>>> Cheers,
>>>> Dimitris
>>>> Chris Holmes wrote:
>>>>> Hi Dimitris,
>>>>> Source details
>>>>> <filelist
>>>>> id="SourceFiles"
>>>>> Target details
>>>>> Reference details
>>>>> </epsilon.etl>
>>>>> it's URL, location, etc. and also navigate down to expected
>>>>> objects/attributes.
>>>>> Target.
>>>>> Best Wishes
>>>>> Chris
>>>>>> Hi Chris,
>>>>>> to run?
>>>>>> Cheers,
>>>>>> Dimitris
>>>>>> Chris Holmes wrote:
>>>>>>> Hi,
>>>>>>> transform and where to put the result. What type are these
>>>>>>> parameters? And what operations can I run on them to confirm that
>>>>>>> </epsilon.etl>
>>>>>>> Regards
>>>>>>> Chris
Re: Debugging ETL [message #524019 is a reply to message #524018] |
Hi Dimitris,
OK, will do. Thanks for your help (and continued patience!).
Best Wishes
Chris
> Hi Chris,
> using:
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hi Dimitris,
>> -- some diagnostics
>> Source model:
>> Target model:
>> Best Wishes
>> Chris
>>> Hi Chris,
>>> Cheers,
>>> Dimitris
>>> Chris Holmes wrote:
>>>> Hi dimitris,
>>>> if I receive an error from ETL to the effect that some type is not
>>>> Best Wishes
>>>> Chris
>>>>> Hi Chris,
>>>>> Cheers,
>>>>> Dimitris
>>>>> Chris Holmes wrote:
>>>>>> Hi Dimitris,
>>>>>> Source details
>>>>>> <filelist
>>>>>> id="SourceFiles"
>>>>>> Target details
>>>>>> Reference details
>>>>>> </epsilon.etl>
>>>>>> from within ETL I can resolve Target to:
>>>>>> I could get hold of the root element of the model I could confirm
>>>>>> objects/attributes.
>>>>>> Target.
>>>>>> Best Wishes
>>>>>> Chris
>>>>>>> Hi Chris,
>>>>>>> the <parameter> tag or to ANT variables such as ${SourceName}?
>>>>>>> Could you please also elaborate a bit on what sort of checks
>>>>>>> you'd like to run?
>>>>>>> Cheers,
>>>>>>> Dimitris
>>>>>>> Chris Holmes wrote:
>>>>>>>> Hi,
>>>>>>>> </epsilon.etl>
>>>>>>>> Regards
>>>>>>>> Chris
Re: Debugging ETL [message #587917 is a reply to message #523840] |
Hi Dimitris,
Source details
<filelist
id="SourceFiles"
Target details
Reference details
</epsilon.etl>
Target to:
Best Wishes
Chris
> Hi Chris,
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hi,
>> </epsilon.etl>
>> Regards
>> Chris
Re: Debugging ETL [message #587924 is a reply to message #523858] |
Hi Chris,
Dimitris
Chris Holmes wrote:
> Hi Dimitris,
> Source details
> <filelist
> id="SourceFiles"
> Target details
> Reference details
> </epsilon.etl>
> Target to:
> Best Wishes
> Chris
>> Hi Chris,
>> Cheers,
>> Dimitris
>> Chris Holmes wrote:
>>> Hi,
>>> </epsilon.etl>
>>> Regards
>>> Chris
Re: Debugging ETL [message #587951 is a reply to message #523883] |
Tue, 30 March 2010 07:36 |
Hi dimitris,
Best Wishes
Chris
> Hi Chris,
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hi Dimitris,
>> Source details
>> <filelist
>> id="SourceFiles"
>> Target details
>> Reference details
>> </epsilon.etl>
>> Target to:
>> objects/attributes.
>> Best Wishes
>> Chris
>>> Hi Chris,
>>> Cheers,
>>> Dimitris
>>> Chris Holmes wrote:
>>>> Hi,
>>>> </epsilon.etl>
>>>> Regards
>>>> Chris
Re: Debugging ETL [message #587959 is a reply to message #587951] |
Tue, 30 March 2010 09:00 |
Hi Chris,
Dimitris
Chris Holmes wrote:
> Hi dimitris,
> Best Wishes
> Chris
>> Hi Chris,
>> Cheers,
>> Dimitris
>> Chris Holmes wrote:
>>> Hi Dimitris,
>>> Source details
>>> <filelist
>>> id="SourceFiles"
>>> Target details
>>> Reference details
>>> </epsilon.etl>
>>> Target to:
>>> objects/attributes.
>>> Best Wishes
>>> Chris
>>>> Hi Chris,
>>>> Cheers,
>>>> Dimitris
>>>> Chris Holmes wrote:
>>>>> Hi,
>>>>> expected?
>>>>> </epsilon.etl>
>>>>> Regards
>>>>> Chris
Re: Debugging ETL [message #587969 is a reply to message #587959] |
Hi Dimitris,
-- some diagnostics
Source model:
Target model:
Best Wishes
Chris
> Hi Chris,
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hi dimitris,
>> Best Wishes
>> Chris
>>> Hi Chris,
>>> Cheers,
>>> Dimitris
>>> Chris Holmes wrote:
>>>> Hi Dimitris,
>>>> Source details
>>>> <filelist
>>>> id="SourceFiles"
>>>> Target details
>>>> Reference details
>>>> </epsilon.etl>
>>>> objects/attributes.
>>>> Best Wishes
>>>> Chris
>>>>> Hi Chris,
>>>>> to run?
>>>>> Cheers,
>>>>> Dimitris
>>>>> Chris Holmes wrote:
>>>>>> Hi,
>>>>>> expected?
>>>>>> </epsilon.etl>
>>>>>> Regards
>>>>>> Chris
Re: Debugging ETL [message #587976 is a reply to message #524007] |
Tue, 30 March 2010 10:18 |
Hi Chris,
using:
Dimitris
Chris Holmes wrote:
> Hi Dimitris,
> -- some diagnostics
> Source model:
> Target model:
> Best Wishes
> Chris
>> Hi Chris,
>> Cheers,
>> Dimitris
>> Chris Holmes wrote:
>>> Hi dimitris,
>>> Best Wishes
>>> Chris
>>>> Hi Chris,
>>>> Cheers,
>>>> Dimitris
>>>> Chris Holmes wrote:
>>>>> Hi Dimitris,
>>>>> Source details
>>>>> <filelist
>>>>> id="SourceFiles"
>>>>> Target details
>>>>> Reference details
>>>>> </epsilon.etl>
>>>>> objects/attributes.
>>>>> Target.
>>>>> Best Wishes
>>>>> Chris
>>>>>> Hi Chris,
>>>>>> to run?
>>>>>> Cheers,
>>>>>> Dimitris
>>>>>> Chris Holmes wrote:
>>>>>>> Hi,
>>>>>>> </epsilon.etl>
>>>>>>> Regards
>>>>>>> Chris
Re: Debugging ETL [message #587989 is a reply to message #587976] |
Tue, 30 March 2010 10:36 |
Hi Dimitris,
Best Wishes
Chris
> Hi Chris,
> using:
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hi Dimitris,
>> -- some diagnostics
>> Source model:
>> Target model:
>> Best Wishes
>> Chris
>>> Hi Chris,
>>> Cheers,
>>> Dimitris
>>> Chris Holmes wrote:
>>>> Hi dimitris,
>>>> Best Wishes
>>>> Chris
>>>>> Hi Chris,
>>>>> Cheers,
>>>>> Dimitris
>>>>> Chris Holmes wrote:
>>>>>> Hi Dimitris,
>>>>>> Source details
>>>>>> <filelist
>>>>>> id="SourceFiles"
>>>>>> Target details
>>>>>> Reference details
>>>>>> </epsilon.etl>
>>>>>> objects/attributes.
>>>>>> Target.
>>>>>> Best Wishes
>>>>>> Chris
>>>>>>> Hi Chris,
>>>>>>> you'd like to run?
>>>>>>> Cheers,
>>>>>>> Dimitris
>>>>>>> Chris Holmes wrote:
>>>>>>>> Hi,
>>>>>>>> </epsilon.etl>
>>>>>>>> Regards
>>>>>>>> Chris
Current Time: Sat Apr 27 01:19:59 GMT 2024
Powered by FUDForum. Page generated in 0.04935 seconds
