Home » Eclipse Projects » Eclipse Platform » How do I stop Eclipse from worrying about everything?(It's always pestering me with useless errors that just slow me down!)
How do I stop Eclipse from worrying about everything? [message #523730] Mon, 29 March 2010 01:56 Go to next message
Hi all,
I've been forced to work on a project hosted on a remote machine, and Eclipse is being such a pain about it!
Every time I try to open a file instead of just opening it, it tells me "Resource 'xxx' is out of sync with file system", and I have to go over, click the right mouse button on the file, choose Refresh, see that nothing at all happens, then try to open it again and this time it works! The next time I want to open that file or another one, I get the same error again and have to go through the same convoluted process, just to open a file! What's the point of that error? I don't see how it's useful - why can't Eclipse just open the file?
I've already posted another thread about the other issues, every time I want to save a file I get a popup and I have to click "yes I want to overwrite the file", and every time I switch to another app and back to Eclipse it warns me that the file has been changed (well duh, I just saved it through Eclipse.) Unfortunately someone decided these were really brilliant ideas and didn't bother to implement a way to switch them off (don't want people working *too* efficiently I guess.) Eclipse is just trying to be too smart for its own good, and is failing miserably.
I know these issues stem from the system clocks being out of sync, but both machines are NTP sync'd to the same time server - they are less than a second out. You'd think that sort of precision would be more than enough, but apparently Eclipse measures file update times down to the nanosecond... Sad
If anyone can help me figure out how to get rid of these infuriating popups I'd be forever in your debt. As you can probably tell, they're currently driving me 'round the bend!
Re: How do I stop Eclipse from worrying about everything? [message #523822 is a reply to message #523730] Mon, 29 March 2010 05:08 Go to previous message
Adam,
Comments below.
Adam Nielsen wrote:
> Hi all,
Eclipse keeps track of the expected time stamp of each resource so if
you change it from outside of Eclipse, Eclipse will know about it and
will be able to update the workspace along with kicking off builds and
things like that to get everything back in sync.
You have a file system that's completely incapable of maintain
consistent time stamps.
> the nanosecond... :(
Being only a little bit in sync is like being a little pregnant.
You could try Window->Preferences->General->Workspace->Refresh
Automatically. You might consider using a real version control system
instead of sharing files across a network.
Previous Topic:Reentrancy in WorkspaceRunnable
Next Topic:Eclipse plugin development - what version control tool do you use?
Current Time: Mon Sep 22 09:36:34 EDT 2025
Powered by FUDForum. Page generated in 0.03661 seconds
