Re: Where do I find BIRT Charting Programmer Reference or BIRT Programmer Reference? [message #523711 is a reply to message #523619] |
Sun, 28 March 2010 23:25 |
Michal,
Those should be in the sdk download. If you extracted these into your
install they should be available. Do a search of the features and
plugins folders for org.eclipse.birt.doc* and org.eclipse.birt.chart.doc*
Jason
Michal Tkacz wrote:
> According to http://www.eclipse.org/birt/phoenix/birthelp.php, BIRT
> supplies three sections in the Eclipse Help:
> - BIRT Report Developers Guide
> - BIRT Charting Programmer Reference
> - BIRT Programmer Reference
> But after installing "Report Designer Full Eclipse Install for Linux"
> (2.5.2) I can see only the first one. Unzipping "BIRT SDK" over it did
> not help either. So where do I find the other two?
> Again please note that I'm using Linux.
> Thanks in advance,
> Michal
Re: Where do I find BIRT Charting Programmer Reference or BIRT Programmer Reference? [message #635066 is a reply to message #634931] |
Mon, 25 October 2010 14:46 |
//2.5.1 shown but all versions should be available this way.
// Just look at the full download page for the build
//http://download.eclipse.org/birt/downloads/build.php?build =R-R1-2_6_1-201009171723
Download the BIRT Source Code download package
http://download.eclipse.org/birt/downloads/build.php?build=R
-R1-2_5_1-200909220630
extract the download and get this plugin:
org.eclipse.birt.doc.isv and place it in your plugins folder
get this feature:
and copy it to your features directory.
For chart javadocs download the Chart Engine package and get
org.eclipse.birt.chart.doc.isv plugin from this directory
birt-charts-2_5_1\ChartSDK\eclipse\plugins
and put it your plugins directory.
Get the
from the
\birt-charts-2_5_1\ChartSDK\eclipse\features
directory and put it in your features directory.
Jason
On 10/25/2010 3:41 AM, Ian wrote:
> I have downloaded Eclipse IDE for Java and Report Developers from the
> following site:
> http://www.eclipse.org/downloads/download.php?file=/technolo gy/epp/downloads/release/helios/SR1/eclipse-reporting-helios -SR1-win32.zip
> As the link above shows I am using Windows (XP 32bit). After unzipping
> and starting eclipse I cannot find the Help topics
> I have tried various different eclipse releases and always have the same
> problem (I also thought I might be able to additionally install just the
> missing help contents via "Help->Install new Software...",but again, no
> luck), only "BIRT Report Developers Guide" is visible in the Help contents.
> I have worked through that and would like to get a look at the "deeper
> stuff" which I suspect in the missing two topics.
> Where am I going wrong? If I have to download something else please
> point me to it with a link, thanks.
Re: Where do I find BIRT Charting Programmer Reference or BIRT Programmer Reference? [message #635122 is a reply to message #635111] |
Mon, 25 October 2010 16:45 |
Ian,
Thanks for the response. Not certain if you know about a couple of
other places for BIRT info:
BIRT-Exchange www.birt-exchange.org
BIRT World birtworld.blogspot.com
Jason
On 10/25/2010 12:27 PM, Ian wrote:
> Thanks for the very (!!!) fast reply. It all worked and I can access the
> documentation I had been looking for (with being able to view the
> javadocs and your link to the various downloads everything makes more
> sense now).
> Am really amazed at how fast you replied to my post. I was going to get
> my boss to buy your book(s) on BIRT anyway...but since he hasn't ordered
> them yet I am going to walk into his office first thing tomorrow and
> watch him order them on amazon. Greetings from Germany and thanks again.
Re: Where do I find BIRT Charting Programmer Reference or BIRT Programmer Reference? [message #765791 is a reply to message #765577] |
Wed, 14 December 2011 17:26 |
I just tried this with 2.6.1 I copied the following folders from the
source download to my install:
//3 features
//3 plugins
And it worked for me.
Jason
On 12/14/2011 5:27 AM, mika.tapanainen wrote:
> Hello,
> I tried this for the version 2.6.1 and that brings "BIRT Programmer
> Reference
> " to the Eclipse, but it is not working. For example there are "Report
> Object Model API Reference" item in the menu, but it opens "Topic not
> found".
> Quote:
>> get this feature:
> There are plugin org.eclipse.birt.doc.isv and also plugin
> org.eclipse.birt.doc?? Features are like
> org.eclipse.birt.doc.isv.feature not org.eclipse.birt.doc.isv.
> How to get the BIRT Programmer Reference to work??
> BR,
> Mika
Re: Where do I find BIRT Charting Programmer Reference or BIRT Programmer Reference? [message #766327 is a reply to message #766054] |
Thu, 15 December 2011 15:00 |
What download did you use? I used the source download that is available
as a zip. birt-source-2-6-1.zip. I extracted it and copied the following:
birt-source-2-6-1\features:
to
C:\birt-report-designer-all-in-one-2_6_1\eclipse\features
and
birt-source-2-6-1\plugins:
to
C:\birt-report-designer-all-in-one-2_6_1\eclipse\plugins
Jason
On 12/15/2011 1:30 AM, mika.tapanainen wrote:
> Hello,
> I copied the folders:
> C:\source_BIRT_2_6_1_Release_201009151750\source_BIRT_2_6_1_Release_201009151750\features\org.eclipse.birt.chart.doc.isv.feature
> C:\source_BIRT_2_6_1_Release_201009151750\source_BIRT_2_6_1_Release_201009151750\features\org.eclipse.birt.doc.feature
> C:\source_BIRT_2_6_1_Release_201009151750\source_BIRT_2_6_1_Release_201009151750\features\org.eclipse.birt.doc.isv.feature
> to the folder
> and the folders:
> C:\source_BIRT_2_6_1_Release_201009151750\source_BIRT_2_6_1_Release_201009151750\org.eclipse.birt.chart.doc.isv
> C:\source_BIRT_2_6_1_Release_201009151750\source_BIRT_2_6_1_Release_201009151750\org.eclipse.birt.doc
> C:\source_BIRT_2_6_1_Release_201009151750\source_BIRT_2_6_1_Release_201009151750\org.eclipse.birt.doc.isv
> to the folder
> When I opened the Eclipse I got the error message. See the attachment picture.
> Where I am doing wrong??
> BR,
> Mika
Re: Where do I find BIRT Charting Programmer Reference or BIRT Programmer Reference? [message #768137 is a reply to message #768016] |
Mon, 19 December 2011 16:35 |
Mika,
Can you log a bug for the chart doc and open an enhancement to make the
java docs available as a pdf download?
Jason
On 12/19/2011 6:58 AM, mika.tapanainen wrote:
> Hello,
> Now "BIRT Programmer Reference" is working in the Eclipse, but the PDF
> printing doesn't contain the javadoc. Is it possible to get the full
> documentation in the PDF?
> Currently I don't need the chart documentation, but it wasn't working
> correctly. All 3 API documentation (Chart Engine API Reference etc.)
> created "Topic not found" error message.
> BR,
> Mika
Re: Where do I find BIRT Charting Programmer Reference or BIRT Programmer Reference? [message #768697 is a reply to message #768442] |
Tue, 20 December 2011 16:10 |
Mika,
What I mean was go here:
http://www.eclipse.org/birt/phoenix/community.php
And open a bugzilla for the bug in the chart help. Then open another
for the PDF reference. I do not think the help document is available in
PDF currently.
Jason
On 12/20/2011 1:52 AM, mika.tapanainen wrote:
> Hello,
> 1) BIRT Charting Programmer Reference
> Here is a part of the Eclipse log for the Charting Programmer Reference:
> !ENTRY org.eclipse.help.base 4 4 2011-12-19 13:14:29.957
> !MESSAGE Help documentation could not be indexed completely.
> !SUBENTRY 1 org.eclipse.help.base 4 4 2011-12-19 13:14:29.958
> /org.eclipse.birt.chart.doc.isv/chartui/api/index.html cannot be opened.
> /org.eclipse.birt.chart.doc.isv/chartscript/api/index.html cannot be
> opened.
> /org.eclipse.birt.chart.doc.isv/chart/api/index.html cannot be opened.
> How to create the Charting Programmer Reference?
> 2) BIRT Programmer Reference
> I'm sorry I didn't understand. Could you explain this
> Quote:
> Is it possible to get complete "BIRT Programmer Reference" from the
> Eclipse help in the PDF format?
> BR,
> Mika
FUDForum. Page generated in 0.06406 seconds
