generically get item provider for an EObject [message #523467] |
Fri, 26 March 2010 09:50 |
Originally posted by: formatzeh.gmx.de
Hi NG,
I want to open a subclass of FilteredItemsSelectionDialog where I can
select one of the elements which are all EObjects. For better labels in
the dialog I want to display the text and image of the EObjects as it is
returned by its item provider. If such an item provider doesn't exist
then the default text and image should be displayed. Can you give me a
hint how to achieve this?
best regards,
Gilbert
Re: generically get item provider for an EObject [message #523487 is a reply to message #523479] |
Fri, 26 March 2010 10:32 |
Hi Ed,
> It sounds like you'd want to use the same label provider
> (AdapterFactoryLabelProvider) as you see being created and used in the
> generated editor.
Yes, exactly that is what I want. I could solve it with the following
snippet:
EObject object = (EObject) element;
EcoreItemProviderAdapterFactory factory = new
EcoreItemProviderAdapterFactory();
if(factory.isFactoryForType(IItemLabelProvider.class)){
IItemLabelProvider labelProvider = (IItemLabelProvider)
factory.adapt(object, IItemLabelProvider.class);
if(labelProvider != null){
return labelProvider.getText(object);
Is this a convenient method to do this?
Re: generically get item provider for an EObject [message #523505 is a reply to message #523487] |
Fri, 26 March 2010 15:40 |
Ed Merks Messages: 33142 Registered: July 2009 |
--------------050504040206010100020800
Gilbert,
Wrap the item provider adapter factory with an AdapterFactoryLabelProvider.
Gilbert Mirenque wrote:
> Hi Ed,
>> generated editor.
> snippet:
<html>
<head>
http-equiv="Content-Type">
</head>
Gilbert,<br>
<br>
AdapterFactoryLabelProvider.<br>
<br>
<br>
<blockquote cite="mid:hoijmf$n0g$1@build.eclipse.org" type="cite">
<pre wrap="">Hi Ed,
</pre>
<blockquote type="cite">
<pre wrap="">It sounds like you'd want to use the same label provider
generated editor.
</pre>
</blockquote>
<pre wrap=""><!---->Yes, exactly that is what I want. I could solve it with the following
snippet:
</pre>
</blockquote>
</body>
</html>
--------------050504040206010100020800--
Ed Merks
FUDForum. Page generated in 0.03722 seconds
