Home » Archived » BIRT » How integrate Birt report with web application
How integrate Birt report with web application [message #523370] Fri, 26 March 2010 04:35 Go to next message
How can I integrate a birt report project in a j2ee web application ?
It is possible to insert a report in one or more web page of a java application ?
Re: How integrate Birt report with web application [message #523717 is a reply to message #523370] Sun, 28 March 2010 15:52 Go to previous messageGo to next message
Stefano,
This is possible. You can call the engines in a servlet
http://wiki.eclipse.org/Servlet_Example_%28BIRT%29_2.1
Or you can use the viewer or tag libraries:
http://www.eclipse.org/birt/phoenix/deploy/viewerSetup.php
http://www.eclipse.org/birt/phoenix/deploy/viewerUsage2.2.ph p
Jason
> application ?
Re: How integrate Birt report with web application [message #523864 is a reply to message #523370] Mon, 29 March 2010 12:21 Go to previous messageGo to next message
It is relatively easy to integrate BIRT into a Web App. What type of web
application are you using (Struts, servlets, JSF...)
Scott Rosenbaum
> application ?
Scott Rosenbaum
Innovent Solutions, BIRT PMC
Re: How integrate Birt report with web application [message #530384 is a reply to message #523864] Thu, 29 April 2010 10:33 Go to previous messageGo to next message
I would like to integrate one of my BIRT report in a JSP....
Re: How integrate Birt report with web application [message #530439 is a reply to message #530384] Thu, 29 April 2010 11:37 Go to previous messageGo to next message
Have you looked at using the JSP Tag library?
http://www.eclipse.org/birt/phoenix/deploy/viewerUsage2.2.ph p#tags
Jason
Re: How integrate Birt report with web application [message #537639 is a reply to message #523370] Thu, 03 June 2010 04:39 Go to previous messageGo to next message
Ok I follow the Viewer tag library, so I add to my working web application a birt.jsp to try to use the Birt Viewer.
When I run the jsp , display HTTP Status 404, The requested resource (/Test_WebApp/frameset) is not available.
So it don't see my report that it have to display in the viewer.
In the jsp Body I use:
<birt:viewer id="birtViewer" reportDesign="test_fid.rptdesign" pattern="frameset"
height="450"
width="700"
format="html"
></birt:viewer>
test_fid.rptdesign file stay in WebContent directory of the web application.
How can I resolve the problem ?
Re: How integrate Birt report with web application [message #537777 is a reply to message #537639] Thu, 03 June 2010 11:16 Go to previous messageGo to next message
Did you add the entire BIRT Viewer to your application?
> pattern="frameset"
> height="450"
> width="700" format="html"
> ></birt:viewer>
> application.
Re: How integrate Birt report with web application [message #537784 is a reply to message #537777] Thu, 03 June 2010 11:56 Go to previous messageGo to next message
I add:
- birt.ltd in WEB-INF/ltds
and follow jars in WEB-INF/lib:
- coreapi.jar
-modelapi.jar
-viewerservlets.jar
-engineapi.jar
-com.ibm.icu....jar
Jason Weathersby wrote on Thu, 03 June 2010 11:16
Re: How integrate Birt report with web application [message #537800 is a reply to message #537784] Thu, 03 June 2010 12:37 Go to previous messageGo to next message
Stefan,
You have to have the full viewer installed on the app server either in
your context or another context. In your case it looks like you added
the tag library but did not specify a baseURL attribute to an existing
BIRT Viewer on the same appserver. Take a look at this:
Jason
On 6/3/2010 11:56 AM, Stefano wrote:
> I add:
> - coreapi.jar
> -modelapi.jar
> -viewerservlets.jar
> -engineapi.jar
> -com.ibm.icu....jar
Re: How integrate Birt report with web application [message #538007 is a reply to message #537800] Fri, 04 June 2010 09:33 Go to previous messageGo to next message
ok, so in <birt:viewer> tag I add baseURL properties, but what path must I use ? relative path ? Can I have an example ?
The birt.war is deployed on the same JBoss application server of the web application.
Jason Weathersby wrote on Thu, 03 June 2010 12:37
Stefan,
Jason
> I add:
> - coreapi.jar
> -modelapi.jar
> -viewerservlets.jar
> -engineapi.jar
> -com.ibm.icu....jar
Re: How integrate Birt report with web application [message #538031 is a reply to message #538007] Fri, 04 June 2010 10:37 Go to previous messageGo to next message
It is a relative path. You are specifying the context of the viewer.
For example:
<birt:viewer id="1" baseURL="/WebViewer"
height="600"
width="800"
reportDesign="TopNPercent.rptdesign"></birt:viewer>
Keep in mind also that the report design is in relation to the viewer
not your app. So in the above example TopNPercent.rptdesign is in the
webcontent directory of the depolyed viewer in the /WebViewer context.
Jason
> application.
>> Stefan,
>> Jason
>> > I add:
>> > - coreapi.jar
>> > -modelapi.jar
>> > -viewerservlets.jar
>> > -engineapi.jar
>> > -com.ibm.icu....jar
Re: How integrate Birt report with web application [message #538037 is a reply to message #538031] Fri, 04 June 2010 11:31 Go to previous message
Thank you very much, now it work...
Jason Weathersby wrote on Fri, 04 June 2010 10:37
For example:
height="600"
width="800"
Jason
> application.
>> Stefan,
>> Jason
>> > I add:
>> > - coreapi.jar
>> > -modelapi.jar
>> > -viewerservlets.jar
>> > -engineapi.jar
>> > -com.ibm.icu....jar
Previous Topic:Cannot open the connection for the driver
Next Topic:BIRT 2.5.1 incorrect xtab header
Current Time: Wed Aug 20 22:17:53 EDT 2025
Powered by FUDForum. Page generated in 0.06491 seconds
