Home » Archived » P2 dev » Installed features using p2.mirror are not in the registry
Installed features using p2.mirror are not in the registry [message #523232] Thu, 25 March 2010 11:48 Go to next message
Hello everyone,
I am experiencing a tricky problem when installing features from composite repository.
I created a composite repository, where I copied features coming from the Galileo update site and some local update site. It seems that the features were correctly copied and the repository was well created. I got the message BUILD SUCCESSFUL when the script ended.
The problem is when I install the features in Eclipse 3.5.2 using the Update Manager. I can connect to my composite repository and install the features I want. When Eclipse restart, I see the features in the Installed software tab (Help -> About Eclipse SDK -> Installation Details -> Installed software) but nothing appears in the Features tab (Help -> About Eclipse SDK -> Installation Details -> Features).
I also know that the features are not installed as I don't see any of their UI elements in the workbench.
Does anyone have a clue on that?
Any help is welcomed. Thanks.
icon14.gif  Re: Installed features using p2.mirror are not in the registry [message #523265 is a reply to message #523232] Thu, 25 March 2010 13:25 Go to previous message
Hello again,
There is no more issue.
Everything was perfect on the repository side. The problem was coming from the Eclipse SDK that I got it from the p2 installer. After a quick look in the configuration folder, I found out it was using "Bundle pooling" although I asked for a single installation and not a shared one (weird!).
I got a new Eclipse installation (without the p2 installer) and everything worked fine.
Thanks.
Previous Topic:P2 mirror to extract a IU from repository
Next Topic:P2 in Client Server Szenario
Current Time: Sat Jul 26 05:10:30 EDT 2025
Powered by FUDForum. Page generated in 0.47302 seconds
