Home » Modeling » Epsilon » Reuse of EOL operations in ETL
Reuse of EOL operations in ETL [message #523169] |
Thu, 25 March 2010 12:02 |
Originally posted by: c.k.holmes.lboro.ac.uk
I would like to access a number of operations captured in EOL in the
form shown below from within an ETL scipt.
operation MyType myOperation() : MyReturnType {
<blah>
I'm running ETL via ANT and ETL seems to expect to be passed in the
source model such that the type is expressed as:
MyModel!MyType
e.g.
MyRule
transform inThing : InModel!InType
to outThing : OutModel!OutType {
var myObj : MyModel!MyType := <some expression>;
<blah>;
myObj.myOperation();
The call myObj.myOperation() appears to be resolved such that it finds
the relevant eol file (which is imported at the top of the ETL script,
but then fails with the error message stating that the type MyType could
not be found. How do I dereference MyModel!MyType such that I can invoke
EOL operations on type MyType from within the ETL script?
Chris
Re: Reuse of EOL operations in ETL [message #523172 is a reply to message #523170] |
Thu, 25 March 2010 12:30 |
Hi Dimitris,
Yes, I was aware of that, however I think this means that I will end up
with duplicates of the relevant operations differing only in their type
signatures. Is there no way to access the original operations?
Chris
Dimitris Kolovos wrote:
> Hi Chris,
> The best solution for this is to change the signature of the operation
> to "operation MyModel!MyType myOperation() ...".
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hi,
>> <blah>
>> MyModel!MyType
>> e.g.
>> MyRule
>> <blah>;
>> could not be found. How do I dereference MyModel!MyType such that I
>> can invoke EOL operations on type MyType from within the ETL script?
>> Regards,
>> Chris
Re: Reuse of EOL operations in ETL [message #523173 is a reply to message #523172] |
Thu, 25 March 2010 12:36 |
Dimitrios Kolovos Messages: 1776 Registered: July 2009 |
Hi Chris,
Another option is to use an alias. If MyModel conforms to a metamodel
called XYZ, you can define the operation as "operation XYZ!MyType
myOperation() ... " and then when you load MyModel in your ETL
transformation, use MyModel as its name and XYZ as its alias.
Dimitris
Chris Holmes wrote:
> Hi Dimitris,
> Regards
> Chris
>> Hi Chris,
>> Cheers,
>> Dimitris
>> Chris Holmes wrote:
>>> Hi,
>>> <blah>
>>> MyModel!MyType
>>> e.g.
>>> MyRule
>>> <blah>;
>>> finds the relevant eol file (which is imported at the top of the ETL
>>> script, but then fails with the error message stating that the type
>>> MyType could not be found. How do I dereference MyModel!MyType such
>>> that I can invoke EOL operations on type MyType from within the ETL
>>> script?
>>> Regards,
>>> Chris
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: Reuse of EOL operations in ETL [message #523215 is a reply to message #523173] |
Thu, 25 March 2010 14:48 |
Hi Dimitris,
How would this look in the example 'MyRule'? Would there be any impact
on how I call the operation from another EOL script?
Chris
> Hi Chris,
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hi Dimitris,
>> up with duplicates of the relevant operations differing only in their
>> type signatures. Is there no way to access the original operations?
>> Regards
>> Chris
>>> Hi Chris,
>>> operation to "operation MyModel!MyType myOperation() ...".
>>> Cheers,
>>> Dimitris
>>> Chris Holmes wrote:
>>>> Hi,
>>>> <blah>
>>>> MyModel!MyType
>>>> e.g.
>>>> MyRule
>>>> <blah>;
>>>> script?
>>>> Regards,
>>>> Chris
Re: Reuse of EOL operations in ETL [message #523229 is a reply to message #523215] |
Thu, 25 March 2010 15:20 |
Hi Chris,
Rule MyRule won't change at all if you go for the alias option. However,
other Epsilon programs that call the myOperation() operation should now
also define an XYZ alias for the model.
Dimitris
Chris Holmes wrote:
> Hi Dimitris,
> Regards
> Chris
>> Hi Chris,
>> Cheers,
>> Dimitris
>> Chris Holmes wrote:
>>> Hi Dimitris,
>>> Regards
>>> Chris
>>>> Hi Chris,
>>>> Cheers,
>>>> Dimitris
>>>> Chris Holmes wrote:
>>>>> Hi,
>>>>> the form shown below from within an ETL scipt.
>>>>> <blah>
>>>>> MyModel!MyType
>>>>> e.g.
>>>>> MyRule
>>>>> <blah>;
>>>>> ETL script, but then fails with the error message stating that the
>>>>> type MyType could not be found. How do I dereference MyModel!MyType
>>>>> such that I can invoke EOL operations on type MyType from within
>>>>> the ETL script?
>>>>> Regards,
>>>>> Chris
Re: Reuse of EOL operations in ETL [message #523303 is a reply to message #523229] |
Thu, 25 March 2010 20:18 |
Hi Dimitris,
I am running MyRule unchanged and have amended the signature of
myOperation to:
operation MyMetaModel!MyType myOperation()
Where MyModel is an instance of MyMetaModel, however the EOL fails to
resolve the operation call:
EXCEPTION: Type 'MyMetaModel!MyType' not found
(C:\EclipseWorkspaces\MyFile.eol@7:23)
Chris
> Hi Chris,
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hi Dimitris,
>> Regards
>> Chris
>>> Hi Chris,
>>> Cheers,
>>> Dimitris
>>> Chris Holmes wrote:
>>>> Hi Dimitris,
>>>> their type signatures. Is there no way to access the original
>>>> operations?
>>>> Regards
>>>> Chris
>>>>> Hi Chris,
>>>>> Cheers,
>>>>> Dimitris
>>>>> Chris Holmes wrote:
>>>>>> Hi,
>>>>>> <blah>
>>>>>> the source model such that the type is expressed as:
>>>>>> MyModel!MyType
>>>>>> e.g.
>>>>>> MyRule
>>>>>> <blah>;
>>>>>> MyModel!MyType such that I can invoke EOL operations on type
>>>>>> Regards,
>>>>>> Chris
Re: Reuse of EOL operations in ETL [message #523323 is a reply to message #523303] |
Thu, 25 March 2010 21:33 |
Hi Chris,
Are you defining MyMetaModel as an alias for MyModel when you're loading
it? If yes, could you please send me a minimal example that reproduces
this behaviour so that I can have a look at this in more detail?
Dimitris
Chris Holmes wrote:
> Hi Dimitris,
> myOperation to:
> Regards
> Chris
>> Hi Chris,
>> However, other Epsilon programs that call the myOperation() operation
>> should now also define an XYZ alias for the model.
>> Cheers,
>> Dimitris
>> Chris Holmes wrote:
>>> Hi Dimitris,
>>> impact on how I call the operation from another EOL script?
>>> Regards
>>> Chris
>>>> Hi Chris,
>>>> metamodel called XYZ, you can define the operation as "operation
>>>> XYZ!MyType myOperation() ... " and then when you load MyModel in
>>>> your ETL transformation, use MyModel as its name and XYZ as its alias.
>>>> Cheers,
>>>> Dimitris
>>>> Chris Holmes wrote:
>>>>> Hi Dimitris,
>>>>> end up with duplicates of the relevant operations differing only in
>>>>> operations?
>>>>> Regards
>>>>> Chris
>>>>>> Hi Chris,
>>>>>> Cheers,
>>>>>> Dimitris
>>>>>> Chris Holmes wrote:
>>>>>>> Hi,
>>>>>>> <blah>
>>>>>>> MyModel!MyType
>>>>>>> e.g.
>>>>>>> MyRule
>>>>>>> <blah>;
>>>>>>> the type MyType could not be found. How do I dereference
>>>>>>> Regards,
>>>>>>> Chris
Re: Reuse of EOL operations in ETL [message #523377 is a reply to message #523323] |
Fri, 26 March 2010 08:55 |
Hi Dimitris,
I'm not sure! How would I declare that MyMetaModel is an alias for
MyModel? Perhaps it would be easiest to send you the model, the problems
I'm experiencing relates to only one operation so it's well constrained.
Best Wishes
Chris
> Hi Chris,
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hi Dimitris,
>> myOperation to:
>> Regards
>> Chris
>>> Hi Chris,
>>> Cheers,
>>> Dimitris
>>> Chris Holmes wrote:
>>>> Hi Dimitris,
>>>> Regards
>>>> Chris
>>>>> Hi Chris,
>>>>> Cheers,
>>>>> Dimitris
>>>>> Chris Holmes wrote:
>>>>>> Hi Dimitris,
>>>>>> in their type signatures. Is there no way to access the original
>>>>>> operations?
>>>>>> Regards
>>>>>> Chris
>>>>>>> Hi Chris,
>>>>>>> Cheers,
>>>>>>> Dimitris
>>>>>>> Chris Holmes wrote:
>>>>>>>> Hi,
>>>>>>>> <blah>
>>>>>>>> MyModel!MyType
>>>>>>>> e.g.
>>>>>>>> MyRule
>>>>>>>> <blah>;
>>>>>>>> Regards,
>>>>>>>> Chris
Re: Reuse of EOL operations in ETL [message #523387 is a reply to message #523377] |
Fri, 26 March 2010 04:40 |
Hi Chris,
If you're running a launch configuration, you can define the alias in
the "Aliases" field of the EMF model configuration dialog. If you're
using ANT, you can specify it in the alias attribute of the
epsilon.emf.loadModel task (i.e. <epsilon.emf.loadModel name="MyModel"
alias="MyMetaModel" ... />). Finally, if you're using the generic
epsilon.loadModel task, you can specify it through a nested parameter:
<parameter name="aliases" value="MyMetaModel"/>
If this doesn't solve it, please send me the model/operations and I'll
have a closer look.
Dimitris
Chris Holmes wrote:
> Hi Dimitris,
> Best Wishes
> Chris
>> Hi Chris,
>> loading it? If yes, could you please send me a minimal example that
>> reproduces this behaviour so that I can have a look at this in more
>> detail?
>> Cheers,
>> Dimitris
>> Chris Holmes wrote:
>>> Hi Dimitris,
>>> myOperation to:
>>> Regards
>>> Chris
>>>> Hi Chris,
>>>> operation should now also define an XYZ alias for the model.
>>>> Cheers,
>>>> Dimitris
>>>> Chris Holmes wrote:
>>>>> Hi Dimitris,
>>>>> Regards
>>>>> Chris
>>>>>> Hi Chris,
>>>>>> alias.
>>>>>> Cheers,
>>>>>> Dimitris
>>>>>> Chris Holmes wrote:
>>>>>>> Hi Dimitris,
>>>>>>> operations?
>>>>>>> Regards
>>>>>>> Chris
>>>>>>>> Hi Chris,
>>>>>>>> Cheers,
>>>>>>>> Dimitris
>>>>>>>> Chris Holmes wrote:
>>>>>>>>> Hi,
>>>>>>>>> in the form shown below from within an ETL scipt.
>>>>>>>>> <blah>
>>>>>>>>> MyModel!MyType
>>>>>>>>> e.g.
>>>>>>>>> MyRule
>>>>>>>>> <blah>;
>>>>>>>>> it finds the relevant eol file (which is imported at the top of
>>>>>>>>> the ETL script, but then fails with the error message stating
>>>>>>>>> that the type MyType could not be found. How do I dereference
>>>>>>>>> Regards,
>>>>>>>>> Chris
Re: Reuse of EOL operations in ETL [message #523391 is a reply to message #523387] |
Fri, 26 March 2010 09:47 |
Hi Dimitris,
Thanks, that was the missing piece of information ... how to define the
alias from the Ant script (and thanks for defining the other forms too).
The transformation now works as expected :)
Chris
> Hi Chris,
> have a closer look.
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hi Dimitris,
>> problems I'm experiencing relates to only one operation so it's well
>> constrained.
>> Best Wishes
>> Chris
>>> Hi Chris,
>>> detail?
>>> Cheers,
>>> Dimitris
>>> Chris Holmes wrote:
>>>> Hi Dimitris,
>>>> myOperation to:
>>>> to resolve the operation call:
>>>> Regards
>>>> Chris
>>>>> Hi Chris,
>>>>> Cheers,
>>>>> Dimitris
>>>>> Chris Holmes wrote:
>>>>>> Hi Dimitris,
>>>>>> Regards
>>>>>> Chris
>>>>>>> Hi Chris,
>>>>>>> alias.
>>>>>>> Cheers,
>>>>>>> Dimitris
>>>>>>> Chris Holmes wrote:
>>>>>>>> Hi Dimitris,
>>>>>>>> operations?
>>>>>>>> Regards
>>>>>>>> Chris
>>>>>>>>> Hi Chris,
>>>>>>>>> Cheers,
>>>>>>>>> Dimitris
>>>>>>>>> Chris Holmes wrote:
>>>>>>>>>> Hi,
>>>>>>>>>> <blah>
>>>>>>>>>> in the source model such that the type is expressed as:
>>>>>>>>>> MyModel!MyType
>>>>>>>>>> e.g.
>>>>>>>>>> MyRule
>>>>>>>>>> <blah>;
>>>>>>>>>> of the ETL script, but then fails with the error message
>>>>>>>>>> stating that the type MyType could not be found. How do I
>>>>>>>>>> dereference MyModel!MyType such that I can invoke EOL
>>>>>>>>>> Regards,
>>>>>>>>>> Chris
Re: Reuse of EOL operations in ETL [message #587675 is a reply to message #523170] |
Hi Dimitris,
Chris
> Hi Chris,
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hi,
>> <blah>
>> MyModel!MyType
>> e.g.
>> MyRule
>> <blah>;
>> Regards,
>> Chris
Re: Reuse of EOL operations in ETL [message #587680 is a reply to message #523172] |
Hi Chris,
Dimitris
Chris Holmes wrote:
> Hi Dimitris,
> Regards
> Chris
>> Hi Chris,
>> Cheers,
>> Dimitris
>> Chris Holmes wrote:
>>> Hi,
>>> <blah>
>>> MyModel!MyType
>>> e.g.
>>> MyRule
>>> <blah>;
>>> script?
>>> Regards,
>>> Chris
Re: Reuse of EOL operations in ETL [message #587689 is a reply to message #523173] |
Hi Dimitris,
Chris
> Hi Chris,
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hi Dimitris,
>> Regards
>> Chris
>>> Hi Chris,
>>> Cheers,
>>> Dimitris
>>> Chris Holmes wrote:
>>>> Hi,
>>>> <blah>
>>>> MyModel!MyType
>>>> e.g.
>>>> MyRule
>>>> <blah>;
>>>> script?
>>>> Regards,
>>>> Chris
Re: Reuse of EOL operations in ETL [message #587697 is a reply to message #523215] |
Hi Chris,
Dimitris
Chris Holmes wrote:
> Hi Dimitris,
> Regards
> Chris
>> Hi Chris,
>> Cheers,
>> Dimitris
>> Chris Holmes wrote:
>>> Hi Dimitris,
>>> Regards
>>> Chris
>>>> Hi Chris,
>>>> Cheers,
>>>> Dimitris
>>>> Chris Holmes wrote:
>>>>> Hi,
>>>>> <blah>
>>>>> MyModel!MyType
>>>>> e.g.
>>>>> MyRule
>>>>> <blah>;
>>>>> the ETL script?
>>>>> Regards,
>>>>> Chris
Re: Reuse of EOL operations in ETL [message #587709 is a reply to message #523229] |
Hi Dimitris,
myOperation to:
Chris
> Hi Chris,
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hi Dimitris,
>> Regards
>> Chris
>>> Hi Chris,
>>> Cheers,
>>> Dimitris
>>> Chris Holmes wrote:
>>>> Hi Dimitris,
>>>> operations?
>>>> Regards
>>>> Chris
>>>>> Hi Chris,
>>>>> Cheers,
>>>>> Dimitris
>>>>> Chris Holmes wrote:
>>>>>> Hi,
>>>>>> <blah>
>>>>>> MyModel!MyType
>>>>>> e.g.
>>>>>> MyRule
>>>>>> <blah>;
>>>>>> Regards,
>>>>>> Chris
Re: Reuse of EOL operations in ETL [message #587717 is a reply to message #523303] |
Hi Chris,
Dimitris
Chris Holmes wrote:
> Hi Dimitris,
> myOperation to:
> Regards
> Chris
>> Hi Chris,
>> Cheers,
>> Dimitris
>> Chris Holmes wrote:
>>> Hi Dimitris,
>>> Regards
>>> Chris
>>>> Hi Chris,
>>>> Cheers,
>>>> Dimitris
>>>> Chris Holmes wrote:
>>>>> Hi Dimitris,
>>>>> operations?
>>>>> Regards
>>>>> Chris
>>>>>> Hi Chris,
>>>>>> Cheers,
>>>>>> Dimitris
>>>>>> Chris Holmes wrote:
>>>>>>> Hi,
>>>>>>> <blah>
>>>>>>> MyModel!MyType
>>>>>>> e.g.
>>>>>>> MyRule
>>>>>>> <blah>;
>>>>>>> Regards,
>>>>>>> Chris
Re: Reuse of EOL operations in ETL [message #587727 is a reply to message #523323] |
Hi Dimitris,
Best Wishes
Chris
> Hi Chris,
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hi Dimitris,
>> myOperation to:
>> Regards
>> Chris
>>> Hi Chris,
>>> Cheers,
>>> Dimitris
>>> Chris Holmes wrote:
>>>> Hi Dimitris,
>>>> Regards
>>>> Chris
>>>>> Hi Chris,
>>>>> Cheers,
>>>>> Dimitris
>>>>> Chris Holmes wrote:
>>>>>> Hi Dimitris,
>>>>>> operations?
>>>>>> Regards
>>>>>> Chris
>>>>>>> Hi Chris,
>>>>>>> Cheers,
>>>>>>> Dimitris
>>>>>>> Chris Holmes wrote:
>>>>>>>> Hi,
>>>>>>>> <blah>
>>>>>>>> MyModel!MyType
>>>>>>>> e.g.
>>>>>>>> MyRule
>>>>>>>> <blah>;
>>>>>>>> Regards,
>>>>>>>> Chris
Re: Reuse of EOL operations in ETL [message #587736 is a reply to message #523377] |
Fri, 26 March 2010 09:24 |
Hi Chris,
have a closer look.
Dimitris
Chris Holmes wrote:
> Hi Dimitris,
> Best Wishes
> Chris
>> Hi Chris,
>> detail?
>> Cheers,
>> Dimitris
>> Chris Holmes wrote:
>>> Hi Dimitris,
>>> myOperation to:
>>> Regards
>>> Chris
>>>> Hi Chris,
>>>> Cheers,
>>>> Dimitris
>>>> Chris Holmes wrote:
>>>>> Hi Dimitris,
>>>>> Regards
>>>>> Chris
>>>>>> Hi Chris,
>>>>>> alias.
>>>>>> Cheers,
>>>>>> Dimitris
>>>>>> Chris Holmes wrote:
>>>>>>> Hi Dimitris,
>>>>>>> operations?
>>>>>>> Regards
>>>>>>> Chris
>>>>>>>> Hi Chris,
>>>>>>>> Cheers,
>>>>>>>> Dimitris
>>>>>>>> Chris Holmes wrote:
>>>>>>>>> Hi,
>>>>>>>>> <blah>
>>>>>>>>> MyModel!MyType
>>>>>>>>> e.g.
>>>>>>>>> MyRule
>>>>>>>>> <blah>;
>>>>>>>>> Regards,
>>>>>>>>> Chris
Re: Reuse of EOL operations in ETL [message #587749 is a reply to message #587736] |
Hi Dimitris,
Chris
> Hi Chris,
> have a closer look.
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hi Dimitris,
>> constrained.
>> Best Wishes
>> Chris
>>> Hi Chris,
>>> detail?
>>> Cheers,
>>> Dimitris
>>> Chris Holmes wrote:
>>>> Hi Dimitris,
>>>> myOperation to:
>>>> Regards
>>>> Chris
>>>>> Hi Chris,
>>>>> Cheers,
>>>>> Dimitris
>>>>> Chris Holmes wrote:
>>>>>> Hi Dimitris,
>>>>>> Regards
>>>>>> Chris
>>>>>>> Hi Chris,
>>>>>>> alias.
>>>>>>> Cheers,
>>>>>>> Dimitris
>>>>>>> Chris Holmes wrote:
>>>>>>>> Hi Dimitris,
>>>>>>>> operations?
>>>>>>>> Regards
>>>>>>>> Chris
>>>>>>>>> Hi Chris,
>>>>>>>>> Cheers,
>>>>>>>>> Dimitris
>>>>>>>>> Chris Holmes wrote:
>>>>>>>>>> Hi,
>>>>>>>>>> <blah>
>>>>>>>>>> MyModel!MyType
>>>>>>>>>> e.g.
>>>>>>>>>> MyRule
>>>>>>>>>> <blah>;
>>>>>>>>>> Regards,
>>>>>>>>>> Chris
Current Time: Fri Apr 26 17:02:56 GMT 2024
Powered by FUDForum. Page generated in 0.04814 seconds
