| A solution similar to the PROIV IDE? [message #522758] |
Tue, 23 March 2010 16:34 |
Hi everyone. I'm fairly new to Eclipse. I'm looking into a programming environment solution to replace PROIV. I'm not sure which plugins or libraries, if any, I should use. Essentially, we need to be able to quickly produce extremely simple menus, forms and reports that are generated and propagated from and updated to a database. The most complicated thing would probably be displaying the results of a database query and allow the user to easily modify the data. Other considerations are security, reporting, simplicity of query generation, and which language(s) / database system to use. The ability to easily produce applications to be run on the web or stand-alone is important. Completely open-source would definitely be ideal. Any suggestions?
Jason
| Re: A solution similar to the PROIV IDE? [message #522772 is a reply to message #522758] |
Tue, 23 March 2010 12:26  |
> Jason
I'm not familiar with PROIV, but Adobe's (rather expensive and not
open-source) Flex Builder is built atop Eclipse and works very well. Use
something like Granite Data Services to integrate your Flex UI code with
Java/JEE.
Hope this helps,
Russ Bateman
FUDForum. Page generated in 0.09030 seconds
