Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [EEF] Generate Architecture error(What does it mean?)
Re: [EEF] Generate Architecture error [message #526309 is a reply to message #522723] |
Fri, 09 April 2010 15:20 |
Aditya Gupta Messages: 9 Registered: April 2010 |
I have been running into a similar problem. I read a few other threads and got to know that the prob was with Acceleo plugin, but on checking that i see that i have 0.9.0v200909291229, which i believe is the same as 0.9.0M2.
Stack Trace,
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:421)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(Progress MonitorDialog.java:507)
at org.eclipse.emf.eef.codegen.ui.generators.actions.AbstractGe nerateEEFAction.run(AbstractGenerateEEFAction.java:139)
at org.eclipse.emf.eef.codegen.ui.generators.actions.AbstractGe nerateEEFAction.run(AbstractGenerateEEFAction.java:79)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:251)
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3880)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3473)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
Caused by: org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedException: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http://www.eclipse.org/acceleo/mtl/3.0' not found. (platform:/plugin/org.eclipse.emf.eef.codegen/org/eclipse/em f/eef/codegen/components/SubPropertiesEditionComponent.emtl, 3, 52)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadException(ResourceSetImpl.java:315)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:274)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:397)
at org.eclipse.emf.eef.codegen.components.SubPropertiesEditionC omponent.createResource(SubPropertiesEditionComponent.java:3 64)
at org.eclipse.emf.eef.codegen.components.SubPropertiesEditionC omponent.load(SubPropertiesEditionComponent.java:330)
at org.eclipse.emf.eef.codegen.components.SubPropertiesEditionC omponent. <init>(SubPropertiesEditionComponent.java:170)
at org.eclipse.emf.eef.codegen.ui.generators.common.GenerateAll $1. <init>(GenerateAll.java:116)
at org.eclipse.emf.eef.codegen.ui.generators.common.GenerateAll .doGenerate(GenerateAll.java:116)
at org.eclipse.emf.eef.codegen.ui.generators.actions.AbstractGe nerateEEFAction$1.run(AbstractGenerateEEFAction.java:108)
at org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
Caused by: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http://www.eclipse.org/acceleo/mtl/3.0' not found. (platform:/plugin/org.eclipse.emf.eef.codegen/org/eclipse/em f/eef/codegen/components/SubPropertiesEditionComponent.emtl, 3, 52)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(X MLHandler.java:2590)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefi x(XMLHandler.java:2421)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType (XMLHandler.java:1299)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XM LHandler.java:1468)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:1019)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:87)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:1001)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:712)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHa ndler.java:169)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanStartElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse(Unknown Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:181)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
at org.eclipse.acceleo.model.mtl.resource.EMtlResourceImpl.doLo ad(EMtlResourceImpl.java:67)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1494)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1282)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:255)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:270)
... 8 more
Root exception:
... 8 more
Aditya
Re: [EEF] Generate Architecture error [message #526531 is a reply to message #526309] |
Mon, 12 April 2010 07:55 |
Stephane Bouchet Messages: 280 Registered: July 2009 |
Hi Aditya,
these error means you have to upgrade your acceleo version to 3.0.0M6 .
it can be found here :
http://www.eclipse.org/modeling/m2t/downloads/?project=accel eo
Aditya Gupta a écrit :
> as 0.9.0M2.
> Stack Trace,
> on.java:251)
> (Realm.java:332)
> bench.java:493)
> tarter.java:368)
> tarter.java:179)
> LHandler.java:1468)
> Handler.java:1019)
> Handler.java:87)
> ndler.java:1001)
> ndler.java:712)
> ndler.java:169)
> Source)
> ourceImpl.java:180)
> ceImpl.java:1494)
> ceImpl.java:1282)
> .. 8 more
> Root exception:
> LHandler.java:1468)
> Handler.java:1019)
> Handler.java:87)
> ndler.java:1001)
> ndler.java:712)
> ndler.java:169)
> Source)
> ourceImpl.java:180)
> ceImpl.java:1494)
> ceImpl.java:1282)
> .. 8 more
> Regards,
> Aditya
Stéphane Bouchet, OBEO
Re: [EEF] Generate Architecture error [message #534476 is a reply to message #530406] |
Wed, 19 May 2010 10:03 |
hi Aditya,
sorry to reply so lately, i didn't see your message untill today.
You are facing a known problem, that is your EEF models are not valid.
You must ensure by hand that every editor as a representation.
in the furture will will improve the generation to validate first the
model ( and add these validations, too )
> Hi Stephane,
> Thanks for the update on eclipse wiki, it worked.
> I am facing another problem when i try to generate the EEF architecture.
> The architecture generation gives me a components, parts.impl and
> providers package. Which obviously generates a lot of compile time
> errors as the parts and parts.forms packages are not created.
> To check the sanctity of my EEF installation i imported the emf library
> example and then generated the architecture again. This time it worked
> without any glitches, and i was also able to implement the
> TabbedPropertySheet as explained on wiki.
> I am able to generate my model, edit, editor and test code correctly
> using the same genmodel though.
> So does this imply that my genmodel is lacking something or is the error
> at some place else?
> Regards,
> Aditya
Re: [EEF] Generate Architecture error [message #622911 is a reply to message #622522] |
hi Aditya,
> Hi Stephane,
> at some place else?
> Regards,
> Aditya
Current Time: Fri Apr 26 02:33:55 GMT 2024
Powered by FUDForum. Page generated in 0.04636 seconds
