Home » Archived » XML Schema Definition (XSD) » how to add enumerations, one per line in schema editor
Re: how to add enumerations, one per line in schema editor [message #523609 is a reply to message #522461] |
Sat, 27 March 2010 07:07 |
Valentin Messages: 36 Registered: July 2009 |
Member |
Hi Adrian, please open a feature request here
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=WTP%20So urce%20Editing&component=wst.xsd
Regards, Valentin
"Ed Merks" <Ed.Merks@gmail.com> wrote in message
news:ho8832$soa$1@build.eclipse.org...
> Adrian,
> I'm redirecting your question to the WTP newsgroup/forum; they provide the
> editor.
> Adrian wrote:
>> Hi!
>> I did a forum search but haven't found any relevant matches.
>> Instead of reformatting my copy/paste data I would like to add a list of
>> enumerations, one per line, to an attribute constraint.
>> The Eclipse XML Schema Editor properties constraints window [Add..] popup
>> window allows separators , : (some kind of space).
>> I can even use "a" (without quotes) as a separator, but I have not found
>> a way to specify one enumeration per line (separator \n or \r)
>> Likewise I would like to delete a range of enumerations by selection in
>> the properties window.
>> I would be greatful to learn if there are ways to do this already.
>> If not, should I file feature requests?
>> Best regards,
>> Adrian
Re: how to add enumerations, one per line in schema editor [message #604547 is a reply to message #522439] |
Mon, 22 March 2010 17:06 |
Ed Merks Messages: 33142 Registered: July 2009 |
Adrian,
the editor.
Adrian wrote:
> Hi!
> of enumerations, one per line, to an attribute constraint.
> popup window allows separators , : (some kind of space).
> found a way to specify one enumeration per line (separator \n or \r)
> in the properties window.
> Best regards,
> Adrian
Ed Merks
Re: how to add enumerations, one per line in schema editor [message #604552 is a reply to message #522461] |
Member |
Regards, Valentin
> Adrian,
> editor.
> Adrian wrote:
>> Hi!
>> Best regards,
>> Adrian
Current Time: Fri Apr 26 13:07:15 GMT 2024
Powered by FUDForum. Page generated in 0.03563 seconds
