Home » Eclipse Projects » Rich Client Platform (RCP) » IMemento usage
IMemento usage [message #522278] Sun, 21 March 2010 22:07 Go to next message
I'm trying to follow advice from Tom Schindl's tutorial on EMF Databinding.
I have a few problems due to the fact my setup isn't identical to his.
I have a real EditorPart actually:
public class WorldEditor extends FormEditor implements
IResourceChangeListener {
In some pages of this multipage editor I use master-detail.
Problems:
1) "Restoring view state information" section relies on the init(final
IViewSite site, IMemento memento) call; I have not been able to find an
equivalent for Editors: where is it?
2) I have not been able to limit the growth of some Text(SWT.MULTI) I
have; this results in very ugly layout: what should I override?
I do realize this post lacks a lot of information and I'm prepared to
give it, but I am unsure about what might be useful and I didn't want to
post a lot of useless data.
Any pointer *very* welcome.
Thanks in advance
Mauro
Re: IMemento usage [message #523330 is a reply to message #522278] Thu, 25 March 2010 18:29 Go to previous messageGo to next message
Originally posted by: rjl.third-monday.com
I think you're just wondering how to use IMemento structure for editors, eh?
here's what I do:
1) Implement a org.eclipse.ui.IElementFactory class with:
public static final String ID_FACTORY = "ElementFactory";
public IAdaptable createElement(IMemento memento) {
IEditorInput element = null;
if (<object
classname>.equals(memento.getString(Persist.OBJECT_CLASS)))
try {
Long key =
Long.parseLong(memento.getString(Persist.OBJECT_KEY));
element = new EditorInput (<get object from model using
'key'>,
false);
} catch (Exception e) {
} finally {
return element;
2) Implement a org.eclipse.ui.IPersistableElement with:
public final static String OBJECT_KEY = "object.key";
public final static String OBJECT_CLASS = "object.class";
private <Object> object = null;
public Persist (<Object> d) {
object = d;
public String getFactoryId() {
return ElementFactory.ID_FACTORY;
public void saveState(IMemento memento) {
if (null != object) {
memento.putString(OBJECT_KEY, object.getKey().toString());
memento.putString(OBJECT_CLASS, <Object classname>);
In the plugin.xml:
<extension
point="org.eclipse.ui.elementFactories">
<factory
class="<IElementFactory class>"
id="ID_FACTORY from class"/>
</extension>
is that what you're after?
On 03/21/2010 09:07 PM, Mauro Condarelli wrote:
> Problems:
> Thanks in advance
> Mauro
Re: IMemento usage [message #524340 is a reply to message #523330] Wed, 31 March 2010 06:04 Go to previous message
On top of that, you need to implement org.eclipse.ui.IPersistableEditor
to be notified of any saved IMemento on restart.
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Previous Topic:Build ID in product splash screen
Next Topic:How to get menumanager of Main menu in a treeviewer
Current Time: Sun Oct 26 12:20:17 EDT 2025
Powered by FUDForum. Page generated in 0.03009 seconds
