Home » Modeling » UML2 » Re: ApplyStereotype method - issue
Re: ApplyStereotype method - issue [message #522212] |
Sun, 21 March 2010 10:26 |
Ed Merks Messages: 33142 Registered: July 2009 |
Mario,
It's best to ask UML-specific question on the UML newsgroup/forum, which
I've added to the "to" list of the reply, so no need to repost.
mario wrote:
> Hello all,
> I got question concerning programatic approach to defing EMF models
> and applying profiles.
> I have problem with applying UML2 profile stereotypes to an Elements
> of the UML2 Model.
> Based on the following specifications:
> http://www.eclipse.org/modeling/mdt/uml2/docs/articles/Getti ng_Started_with_UML2/article.html
> and
> http://www.eclipse.org/modeling/mdt/uml2/docs/articles/Intro duction_to_UML2_Profiles/article.html
> I've defined:
> 1. Model with: package1, package2 in package1, class in package1,
> attributes and operations in class.
> 2. and a Profile with stereotypes.
> Every time when I want to apply stereotype using
> 'applyStereotype(UMLElement, Stereotype)' I got an error:
> "java.lang.IllegalArgumentException:
> mailto:org.eclipse.uml2.uml.internal.impl.StereotypeImpl@19f332b (
> name: @Stereotype, visibility: <unset>) (isLeaf: false, isAbstract:
> true) (isActive: false)
> at org.eclipse.uml2.uml.internal.operations.ElementOperations.a
> pplyStereotype(ElementOperations.java:1411)
> at org.eclipse.uml2.uml.internal.impl.ElementImpl.applyStereoty
> pe(ElementImpl.java:499)
> The following code snipped shows what Im doing now :
> protected static void registerPathmaps(URI uri) {
> URIConverter.URI_MAP.put(URI.createURI(UMLResource.LIBRARIES _PATHMAP),
> uri.appendSegment("libraries").appendSegment(""));
> URIConverter.URI_MAP.put(URI.createURI(UMLResource.METAMODEL S_PATHMAP),
> uri.appendSegment("metamodels").appendSegment(""));
> URIConverter.URI_MAP.put(URI.createURI(UMLResource.PROFILES_ PATHMAP),
> uri.appendSegment("profiles").appendSegment(""));
> protected static void registerResourceFactories() {
> Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put(
> UMLResource.FILE_EXTENSION,
> UMLResource.Factory.INSTANCE);
> URI uri = URI.createURI("file://home/mario/model.profile/resource");
> /* Part1: MODEL - model was creating properly */
> // creating model, packages, class, attributes and operations
> Model model = createModel("Model"); //Model
> createPackages("package1"); //Model::package1
> createPackages("package2"); //Model::package1::package2
> createClass("Class"); //Model::package1:package2::Class
> createAttribute("attribute1")
> //Model::package1:package2::Class::attribute1
> createAttribute("attribute2")
> //Model::package1:package2::Class::attribute2
> createMethods("method1"); //Model::package1:package2::Class::method1
> createMethods("method2");
> ////Model::package1:package2::Class::method2
> registerResourceFactories();
> registerPathmaps(URI.createURI(" jar:file:/home/mario/Programy/eclipse/plugins/org.eclipse.um l2.uml.resources_3.0.0.v200906011111.jar!/ "));
> writer.saveModel(model,
> uri.appendSegment(model.getNam()).appendFileExtension(UMLRes ource.FILE_EXTENSION));
> /* Part2: PROFILE - I got also properly generated and saved Profile*/
> // creating Profile
> Profile profileFromReader = createProfile("Profile");
> // importing primitive Type
> Type stringType = importPrimitiveType(profileFromReader, "String");
> Type boolType = importPrimitiveType(profileFromReader, "Boolean");
> // meta-classes
> Class propertyMetaClass = referenceMetaclass(profileFromReader,
> UMLPackage.Literals.PROPERTY.getName());
> Class packageMetaClass = referenceMetaclass(profileFromReader,
> UMLPackage.Literals.PACKAGE.getName());
> // stereotype examplewith with with Stereotype stereotype =
> createStereotype(profileFromReader, "@Stereotype", true);
> // stereotype property
> Property stereotypeProperty1 = stereotypeProperty =
> writer.writeAttribute(stereotype, "attributeStereo1", boolType, 0, 1);
> Property stereotypeProperty = writer.writeAttribute(stereotype,
> "attributeStereo2", stringType, 0, 1);
> // creating extensions
> createExtension(propertyMetaClass, stereotype, false);
> createExtension(packageMetaClass, stereotype, false);
> // defining Profile
> writer.defineProfile(profileFromReader);
> // saving Profile
> saveProfile(profileFromReader,
> uri.appendSegment("ProfileEx").appendFileExtension(UMLResource.PROFILE_FILE_EXTENSION));
> // loading model and standard profiles (ecore and standard)
> Model modelLoaded = (Model)
> load(uri.appendSegment(model.getName()).appendFileExtension( UMLResource.FILE_EXTENSION));
> Profile ecoreProfile = (Profile)
> load(URI.createURI("pathmap://UML_PROFILES/Ecore.profile.uml"));
> Profile standardProfile = (Profile)
> load(URI.createURI("pathmap://UML_PROFILES/Standard.profile.uml"));
> // applying ecore, standard and my profiles
> if(!model.isProfileApplied(ecoreProfile))
> writer.applyProfile(modelLoaded, ecoreProfile);
> if(!model.isProfileApplied(standardProfile))
> writer.applyProfile(modelLoaded, standardProfile);
> if(!modelLoaded.isProfileApplied(profileFromReader))
> writer.applyProfile(modelLoaded, profileFromReader);
> // HERE IS AN ISSUE :/
> // no matter if first parameter is Package, Class or Attribute...
> I got IllegalArgumentException
> applyStereotype(package1, stereotype)
> applyStereotype(class, stereotype)
> applyStereotype(attribute1, stereotype)[
> I've no idea what's wrong.... I've beed checking and comparing code
> with introduction from website several time. obviously I've searching
> for the answer on the forums but coudn't find for that case....
> Could someone help me? Maybe I'm doing sth with wrong order?
> Cheers,
> Mario
Ed Merks
Re: ApplyStereotype method - issue [message #522233 is a reply to message #522212] |
Sun, 21 March 2010 15:25 |
Rafael Chaves Messages: 161 Registered: July 2009 |
Mario, it seems you are making the stereotype to extend the right metaclasses, defining the profile, applying it to the package. Can't be 100% sure because much of the code does not show here. I could try to reproduce the problem but I would need the entire code, not only this class (or you could produce a more straightforward version of this code that was self-contained).
Or even better, you could try to step through the UML2 code and determine what is going on. The stacktrace you have tells this is the code in ElementOperations that is throwing the exception:
if (definition == null || getExtension(element, stereotype) == null
|| element.getStereotypeApplication(stereotype) != null) {
throw new IllegalArgumentException(String.valueOf(stereotype));
If you debug into this section, you should be able which of the conditions is causing UML2 to reject your request to apply a stereotype to an element.
Rafael
http://abstratt.com/blog
[Updated on: Sun, 21 March 2010 15:26] Report message to a moderator
Current Time: Fri Apr 26 12:21:04 GMT 2024
Powered by FUDForum. Page generated in 0.03951 seconds
