Re: mouseUp event on sash only onright side [message #521890 is a reply to message #521746] |
Fri, 19 March 2010 03:12 |
Holger Staudacher Messages: 166 Registered: July 2009 |
Hi Lars,
in case the behaviour is different as in RCP this might be a bug. Can
you file a bugzilla for this?
Thanks you.
Regards Holger
On 2010-03-18 16:55:31 +0100, Lars Fischer <lfischer@fastmail.fm> said:
> Hello,
> I use a vertical sash in a single sourcing project. This sash has an
> MouseListener, which is listening for a mouseUp event.
> On rap, the event is only fired, if the sash was moved to the right...
> If the sash was moved to the left, nothing happens after releasing the
> pressed mouse button.
> Started the same app as rcp, the mouseUp Method of the listener is
> called regardless of to which side (left or right) the sash was moved.
> Could this be a rap bug?
> Regards,
> Lars
http://eclipsesource.com
http://twitter.com/eclipsesource
FUDForum. Page generated in 0.04003 seconds
