mouseUp event on sash only onright side [message #521746] |
Thu, 18 March 2010 11:55  |
I use a vertical sash in a single sourcing project. This sash has an
MouseListener, which is listening for a mouseUp event.
On rap, the event is only fired, if the sash was moved to the right...
If the sash was moved to the left, nothing happens after releasing the
pressed mouse button.
Started the same app as rcp, the mouseUp Method of the listener is
called regardless of to which side (left or right) the sash was moved.
Could this be a rap bug?
Lars
Re: mouseUp event on sash only onright side [message #521890 is a reply to message #521746] |
Thu, 18 March 2010 23:12   |
Hi Lars,
in case the behaviour is different as in RCP this might be a bug. Can
you file a bugzilla for this?
Thanks you.
Regards Holger
On 2010-03-18 16:55:31 +0100, Lars Fischer <lfischer@fastmail.fm> said:
> Hello,
> Lars
http://eclipsesource.com
http://twitter.com/eclipsesource
FUDForum. Page generated in 0.04254 seconds
