Home » Archived » M2M (model-to-model transformation) » ATL launch error
ATL launch error [message #521486] Wed, 17 March 2010 14:18 Go to next message
Hi all,
I've written a java application to run a basic ATL transformation. The ".asm" file and all the models came from the families to Persons example, so i exclude any rule or model issue.
I'm getting an exception when laucnhing the transformation itself. The code is as follows:
//Setup launcher...
    	EMFVMLauncher launcher = new EMFVMLauncher();
    	CoreService.registerLauncher(launcher);
    	launcher.initialize(Options);
    	CoreService.registerFactory("EMF", EMFModelFactory.class);
    	ModelFactory factory = CoreService.createModelFactory("EMF");
    	CoreService.registerExtractor("EMF", new EMFExtractor());
    	CoreService.registerInjector("EMF", new EMFInjector());
		EMFInjector injector = new EMFInjector();
		IExtractor extractor = CoreService.getExtractor(factory.getDefaultExtractorName());
		// Metamodels && models
		EMFReferenceModel Metamodel1 = (EMFReferenceModel)factory.newReferenceModel();
		//Resource resource = new XMIResourceImpl(URI.createURI("file:/C:/wS/BS/atl_data/sample-Families.xmi"));
		injector.inject(Metamodel1, "Families.ecore");
		IModel model1 = factory.newModel(Metamodel1);
		injector.inject(model1, "sample-Families.xmi");
		EMFReferenceModel Metamodel2 = (EMFReferenceModel)factory.newReferenceModel();
		injector.inject(Metamodel2, "Persons.ecore");
		IModel model2 = factory.newModel(Metamodel2);
		// Launching
		launcher.addInModel(model1, "IN_MODEL", "IN_META"); //$NON-NLS-1$ //$NON-NLS-2$
		launcher.addOutModel(model2, "OUT_MODEL", "OUT_META"); //$NON-NLS-1$ //$NON-NLS-2$
		URL asmURL = new URL("file:/C:/wS/BS/one.asm");
		InputStream asmInputStream = asmURL.openStream();
		InputStream[] modules = new InputStream[1];
		modules[0] = asmInputStream;
                launcher.launch(ILauncher.RUN_MODE, new NullProgressMonitor(), Collections.<String, Object> emptyMap(),(Object[])modules);
And of course, forgot to post the exception i get:
Exception in thread "main" java.lang.NoClassDefFoundError: org/eclipse/m2m/atl/common/ATLExecutionException
	at java.lang.ClassLoader.defineClass1(Native Method)
	at java.lang.ClassLoader.defineClass(Unknown Source)
	at java.security.SecureClassLoader.defineClass(Unknown Source)
	at java.net.URLClassLoader.defineClass(Unknown Source)
	at java.net.URLClassLoader.access$000(Unknown Source)
	at java.net.URLClassLoader$1.run(Unknown Source)
	at java.net.URLClassLoader.findClass(Unknown Source)
	at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
	at java.lang.ClassLoader.loadClassInternal(Unknown Source)
	at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher.loadModule(EMFVMLauncher.java:171)
	at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher.getASMFromObject(EMFVMLauncher.java:183)
	at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher.launch(EMFVMLauncher.java:131)
	at bs.atl.PrivatizeAction.privatize(PrivatizeAction.java:169)
	at bs.Loader.XsdTest.main(XsdTest.java:63)
Caused by: java.lang.ClassNotFoundException: org.eclipse.m2m.atl.common.ATLExecutionException
Are there any obvious errors with this code?
Any help would be greatly appreciated.
Thank you,
João Vaz
[Updated on: Wed, 17 March 2010 14:25] by Moderator
Re: ATL launch error [message #521592 is a reply to message #521486] Thu, 18 March 2010 04:57 Go to previous messageGo to next message
Looks like you're missing some dependencies. Try to add org.eclipse.m2m.atl.common as a dependency.
Re: ATL launch error [message #521651 is a reply to message #521592] Thu, 18 March 2010 08:24 Go to previous messageGo to next message
Sylvain EVEILLARD wrote on Thu, 18 March 2010 04:57
Thanks, it did really help... although now a new problem arises when launching the vm:
org.eclipse.m2m.atl.engine.emfvm.VMException: Could not find model Families
It seems that the metamodel Families isn't being loaded correctly. Just debugged the code, and added a watch to the Families Metamodel and i'm pretty much sure it isn't correct.
To load the Families metamodel i'm using:
injector.inject(Metamodel1, "file:/C:/wS/BS/Families.ecore");
And the Watch i added returned this:
{org.eclipse.emf.ecore.impl.EClassImpl@dc86eb (name: EDataType) (instanceClassName: null) (abstract: false, interface: false)=[org.eclipse.emf.ecore.impl.EDataTypeImpl@134263a (name: String) (instanceClassName: java.lang.String) (serializable: true)]}
{org.eclipse.emf.ecore.impl.EClassImpl@1546dbc (name: EPackage) (instanceClassName: null) (abstract: false, interface: false)=[org.eclipse.emf.ecore.impl.EPackageImpl@c1186f (name: Families) (nsURI: Families, nsPrefix: null), org.eclipse.emf.ecore.impl.EPackageImpl@12b3349 (name: PrimitiveTypes) (nsURI: PrimitiveTypes, nsPrefix: null)], org.eclipse.emf.ecore.impl.EClassImpl@dc86eb (name: EDataType) (instanceClassName: null) (abstract: false, interface: false)=[org.eclipse.emf.ecore.impl.EDataTypeImpl@134263a (name: String) (instanceClassName: java.lang.String) (serializable: true)]}
null
false
{Member=org.eclipse.emf.ecore.impl.EClassImpl@6a63d3 (name: Member) (instanceClassName: null) (abstract: false, interface: false), Families::Family=org.eclipse.emf.ecore.impl.EClassImpl@b9b8d0 (name: Family) (instanceClassName: null) (abstract: false, interface: false), PrimitiveTypes::String=org.eclipse.emf.ecore.impl.EDataTypeImpl@134263a (name: String) (instanceClassName: java.lang.String) (serializable: true), Families::Member=org.eclipse.emf.ecore.impl.EClassImpl@6a63d3 (name: Member) (instanceClassName: null) (abstract: false, interface: false), String=org.eclipse.emf.ecore.impl.EDataTypeImpl@134263a (name: String) (instanceClassName: java.lang.String) (serializable: true), Family=org.eclipse.emf.ecore.impl.EClassImpl@b9b8d0 (name: Family) (instanceClassName: null) (abstract: false, interface: false)}
org.eclipse.m2m.atl.core.emf.EMFModelFactory@1972e3a
org.eclipse.m2m.atl.core.emf.EMFReferenceModel@1955970
Since i'm new to all this EMF and ATL world i can't seem to figure out if the injected metamodel is correct.
João Vaz
Re: ATL launch error [message #521660 is a reply to message #521651] Thu, 18 March 2010 08:31 Go to previous messageGo to next message
> launching the vm:
> null
> false
Have a look in your Model using text editor to get its way to refer to
the metamodel. May be the model point out on another instance/flavour of
Families.ecore
Cordialement
Vincent MAHÉ
Ingénieur plate-forme - Cesar/Artemisia - Équipe Espresso
IRISA-INRIA, Campus de Beaulieu, 35042 Rennes cedex, France
Tél: +33 (0) 2 99 84 71 00, Fax: +33 (0) 2 99 84 71 71
Re: ATL launch error [message #522389 is a reply to message #521660] Mon, 22 March 2010 10:19 Go to previous messageGo to next message
Vincent MAHE wrote on Thu, 18 March 2010 08:31
> launching the vm:
> null
> false
Families.ecore
Cordialement
Vincent MAHÉ
Thanks for your help. After taking an intensive look at the models (and modifying them) i couldn't solve the problem, though if i had to guess i'd say I have a problem in the "sample-families.xmi" reference to the ecore model "Families".
I still get:
Both models are in the same directory and the used models refer to the ATL Families-Persons example.
Families.ecore:
<?xml version="1.0" encoding="ISO-8859-1"?>
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore">
  <ecore:EPackage name="Families">
    <eClassifiers xsi:type="ecore:EClass" name="Family">
      <eStructuralFeatures xsi:type="ecore:EAttribute" name="lastName" ordered="false" unique="false" lowerBound="1" eType="/1/String"/>
      <eStructuralFeatures xsi:type="ecore:EReference" name="father" ordered="false" lowerBound="1" eType="/0/Member" containment="true" eOpposite="/0/Member/familyFather"/>
      <eStructuralFeatures xsi:type="ecore:EReference" name="mother" ordered="false" lowerBound="1" eType="/0/Member" containment="true" eOpposite="/0/Member/familyMother"/>
      <eStructuralFeatures xsi:type="ecore:EReference" name="sons" ordered="false" upperBound="-1" eType="/0/Member" containment="true" eOpposite="/0/Member/familySon"/>
      <eStructuralFeatures xsi:type="ecore:EReference" name="daughters" ordered="false" upperBound="-1" eType="/0/Member" containment="true" eOpposite="/0/Member/familyDaughter"/>
    </eClassifiers>
    <eClassifiers xsi:type="ecore:EClass" name="Member">
      <eStructuralFeatures xsi:type="ecore:EAttribute" name="firstName" ordered="false" unique="false" lowerBound="1" eType="/1/String"/>
      <eStructuralFeatures xsi:type="ecore:EReference" name="familyFather" ordered="false" eType="/0/Family" eOpposite="/0/Family/father"/>
      <eStructuralFeatures xsi:type="ecore:EReference" name="familyMother" ordered="false" eType="/0/Family" eOpposite="/0/Family/mother"/>
      <eStructuralFeatures xsi:type="ecore:EReference" name="familySon" ordered="false" eType="/0/Family" eOpposite="/0/Family/sons"/>
      <eStructuralFeatures xsi:type="ecore:EReference" name="familyDaughter" ordered="false" eType="/0/Family" eOpposite="/0/Family/daughters"/>
    </eClassifiers>
  </ecore:EPackage>
  <ecore:EPackage name="PrimitiveTypes">
    <eClassifiers xsi:type="ecore:EDataType" name="String"/>
  </ecore:EPackage>
</xmi:XMI>
And the sample-Families.xmi:
    xmlns="Families">
  <Family lastName="March">
    <father firstName="Jim"/>
    <mother firstName="Cindy"/>
    <sons firstName="Brandon"/>
    <daughters firstName="Brenda"/>
  </Family>
  <Family lastName="Sailor">
    <father firstName="Peter"/>
    <mother firstName="Jackie"/>
    <sons firstName="David"/>
    <sons firstName="Dylan"/>
    <daughters firstName="Kelly"/>
  </Family>
</xmi:XMI>
João Vaz
[Updated on: Mon, 22 March 2010 10:20] by Moderator
Re: ATL launch error [message #524055 is a reply to message #522389] Tue, 30 March 2010 09:36 Go to previous messageGo to next message
Finally i understood where the error was:
// Launching
The names of both model and metamodel were wrong and thus returning the null pointer error. Embarrassed
João Vaz
Re: ATL launch error [message #524082 is a reply to message #521486] Tue, 30 March 2010 11:32 Go to previous messageGo to next message
Care to share the full working code with us? Including the imports. I'm trying to get a similar thing to work but everything fails as soon as I try to create an EMF model factory.
Re: ATL launch error [message #726057 is a reply to message #524082] Fri, 16 September 2011 09:34 Go to previous message
The same here!
Previous Topic:[QVTO] Calling transformation programmatically
Next Topic:[QVTo] Metamodels list "reloading" in QVTo plugin
Current Time: Mon Nov 03 21:52:13 EST 2025
Powered by FUDForum. Page generated in 0.45641 seconds
