Home » Eclipse Projects » Nebula » Grid - Inline Editing
Grid - Inline Editing [message #52659] |
Sun, 11 May 2008 11:52 |
Originally posted by: mail.ppfeifer.net
Hello.
I'm using the GridTableViewer with inline editing support and moveable
columns. Inline editing works as it's supposed to, but when I move some
gridcolumns the inline editing tab order is still the same, as it was
after creation. Lets say I have got 4 columns (col1, col2, col3, col4)
and I move col3 to the second postion (col1, col3, col2, col4). Then
inline editing is still moving from col1 to col2 to col3 to col4. Is
there a way to tell the inline editing, to take the new column order
into account?
Thanks in adavance.
Peter
Re: Grid - Inline Editing [message #52687 is a reply to message #52659] |
Sun, 11 May 2008 15:08 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
I don't think this is possible with JFace 3.3 codebase (reordering was
not included in the 3.3 codestream). We (JFace) fixed this in 3.4 and if
Grid behaves like SWT-Table (which it should else I'd consider this a
Grid-bug) this should work out of the box with JFace from 3.4M7 (which
is in a fairly complete state because we are working towards 3.4RC1).
Tom
Peter Pfeifer schrieb:
> Hello.
> into account?
> Thanks in adavance.
> Peter
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Grid - Inline Editing [message #52712 is a reply to message #52687] |
Sun, 11 May 2008 16:22 |
Hello Tom.
Thanks for your answer. This means, if I change to Eclipse >= 3.4M7 this
should work out of the box?
There is one more thing I emcountered. When I do inline editing in a
GridTableViewer with eg. 60 lines where only 10 are displayed at once in
the GridTableViewer, the table does not scroll down to the line which is
currently edited. If you scroll down by using the vertical scrollbar
inline editing is still possible. Is it possible to scroll automatically
to the position of the line, if this line isn't shown?
Thanks Peter
> Tom
>> Hello.
>> some gridcolumns the inline editing tab order is still the same, as it
>> was after creation. Lets say I have got 4 columns (col1, col2, col3,
>> col4) and I move col3 to the second postion (col1, col3, col2, col4).
>> Then inline editing is still moving from col1 to col2 to col3 to col4.
>> Is there a way to tell the inline editing, to take the new column
>> order into account?
>> Thanks in adavance.
>> Peter
Re: Grid - Inline Editing [message #52766 is a reply to message #52739] |
Mon, 12 May 2008 10:31 |
Hello Tom.
Many thanks, It seems that it's a bug of the Grid beacause I downloaded
Exlipse 3.4M7 and tried what you suggested. But still it has the same
behaviour. Neither the inline editing nor the scrolling works as
supposed to. I've never filed a bug before. How does the procedure look
like, or is there already a bug entry in bugzilla?
Regards, Peter
>> Hello Tom.
>> this should work out of the box?
> Yes.
>> in the GridTableViewer, the table does not scroll down to the line
>> which is currently edited. If you scroll down by using the vertical
>> scrollbar inline editing is still possible. Is it possible to scroll
>> automatically to the position of the line, if this line isn't shown?
> This is also a fix in 3.4 stream. The bugfixes you are interested in are:
> - https://bugs.eclipse.org/bugs/show_bug.cgi?id=201910
> - https://bugs.eclipse.org/bugs/show_bug.cgi?id=195908
> Tom
Re: Grid - Inline Editing [message #52845 is a reply to message #52819] |
Mon, 12 May 2008 13:17 |
Hello Tom.
Thank you very much. I added your changes and now both work like a
charm. But that leads me to another question :-) I don't know if I
should start a new thread, but first I'll try my luck within this one.
I want to use the grid/gridtableviewer for quick data entry. Therefore I
have a special requirement. When the active cell is the really last one
in the grid and the user presses the tab-key a new record/row should be
added to the grid. It's more or less the same as in MS Word/OO when the
user is editing the last cell of a table and pressing the tab-key
automatically adds one new row.
Is this also possible to be done with the grid/gridtableviewer?
Peter
> You are right.
> Reordered Columns:
> Nebula Grid didn't implement the additional methods we added in 3.4. I
> filed a bug and added a patch which makes this work [1].
> Scrolling Cell into View:
> This is a bug in GridViewerEditor easily fixable as [2] shows.
> Tom
> [1]https://bugs.eclipse.org/bugs/show_bug.cgi?id=231530
> [2]https://bugs.eclipse.org/bugs/show_bug.cgi?id=231532
>> Hello Tom.
>> downloaded Exlipse 3.4M7 and tried what you suggested. But still it
>> has the same behaviour. Neither the inline editing nor the scrolling
>> works as supposed to. I've never filed a bug before. How does the
>> procedure look like, or is there already a bug entry in bugzilla?
>> Regards, Peter
>>>> Hello Tom.
>>> Yes.
>>>> once in the GridTableViewer, the table does not scroll down to the
>>>> line which is currently edited. If you scroll down by using the
>>>> vertical scrollbar inline editing is still possible. Is it possible
>>>> to scroll automatically to the position of the line, if this line
>>>> isn't shown?
>>> are:
>>> Tom
Re: Grid - Inline Editing [message #52872 is a reply to message #52845] |
Mon, 12 May 2008 14:16 |
--------------020202070508030301070905
> Hello Tom.
That's not an easy task but doable with some hacks. Because we are past
API-Freeze in JFace 3.4 it is to late to introduce such a feature at
JFace level and I don't think GridViewer should introduce an API itself.
Having said this you can solve "quite simply" your own and staying with
the current API but enhancing it (See the files attached). This is only
one solution you could also use Reflection for example.
Tom
name="GridViewerEditor.java"
Content-Disposition: inline;
filename="GridViewerEditor.java"
* Copyright (c) 2007 IBM Corporation and others.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* rmcamara@us.ibm.com - initial API and implementation
* Tom Schindl <tom.schindl@bestsolution.at> - various significant contributions
* bug fix in: 191216
package org.eclipse.nebula.snippets.gridviewer;
import org.eclipse.jface.viewers.ColumnViewer;
import org.eclipse.jface.viewers.ColumnViewerEditor;
import org.eclipse.jface.viewers.ColumnViewerEditorActivationEvent;
import org.eclipse.jface.viewers.ColumnViewerEditorActivationStrate gy;
import org.eclipse.jface.viewers.StructuredSelection;
import org.eclipse.jface.viewers.ViewerCell;
import org.eclipse.jface.viewers.ViewerRow;
import org.eclipse.jface.viewers.CellEditor.LayoutData;
import org.eclipse.nebula.jface.gridviewer.GridTableViewer;
import org.eclipse.nebula.jface.gridviewer.GridTreeViewer;
import org.eclipse.nebula.widgets.grid.Grid;
import org.eclipse.nebula.widgets.grid.GridEditor;
import org.eclipse.nebula.widgets.grid.GridItem;
import org.eclipse.swt.events.TraverseEvent;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.Item;
public class GridViewerEditor extends ColumnViewerEditor {
/** Editor support for tables. */
private GridEditor gridEditor;
private TabbingEndHandler handler;
* This handler is called when tabbing to the next/previous element didn't succeeded
public abstract static class TabbingEndHandler {
public abstract void handle(ViewerCell cell, TraverseEvent event);
GridViewerEditor(ColumnViewer viewer,
ColumnViewerEditorActivationStrategy editorActivationStrategy,
int feature) {
super(viewer, editorActivationStrategy, feature);
this.gridEditor = new GridEditor((Grid) viewer.getControl());
protected StructuredSelection createSelection(Object element) {
return new StructuredSelection(element);
protected void setEditor(Control w, Item item, int fColumnNumber) {
gridEditor.setEditor(w, (GridItem) item, fColumnNumber);
protected void setLayoutData(LayoutData layoutData) {
gridEditor.grabHorizontal = layoutData.grabHorizontal;
gridEditor.horizontalAlignment = layoutData.horizontalAlignment;
gridEditor.minimumWidth = layoutData.minimumWidth;
public void setTabbingEndHandler(TabbingEndHandler handler) {
this.handler = handler;
protected void processTraverseEvent(int columnIndex, ViewerRow row,
TraverseEvent event) {
if( handler != null ) {
ViewerCell previous = getFocusCell();
super.processTraverseEvent(columnIndex, row, event);
ViewerCell next = getFocusCell();
if( previous != null && previous.equals(next) ) {
handler.handle(next, event);
} else {
public ViewerCell getFocusCell() {
Grid grid = (Grid) getViewer().getControl();
if (grid.getCellSelectionEnabled()) {
Point p = grid.getFocusCell();
if (p.x >= 0 && p.y >= 0) {
GridItem item = grid.getItem(p.y);
if (item != null) {
ViewerRow row = getViewerRowFromItem(item);
return row.getCell(p.x);
return null;
private ViewerRow getViewerRowFromItem(GridItem item) {
if (getViewer() instanceof GridTableViewer) {
return ((MyGridTableViewer) getViewer()).getViewerRowFromItem(item);
} else {
return ((MyGridTreeViewer) getViewer()).getViewerRowFromItem(item);
protected void updateFocusCell(ViewerCell focusCell,
ColumnViewerEditorActivationEvent event) {
if (event.eventType == ColumnViewerEditorActivationEvent.PROGRAMMATIC
|| event.eventType == ColumnViewerEditorActivationEvent.TRAVERSAL) {
Grid grid = ((Grid) getViewer().getControl());
grid.deselectAllCells();
grid.setFocusColumn(grid.getColumn(focusCell.getColumnIndex( )));
grid.setFocusItem((GridItem) focusCell.getItem());
grid.setCellSelection(new Point(focusCell.getColumnIndex(), grid
.indexOf((GridItem) focusCell.getItem())));
grid.showSelection();
public static void create(MyGridTableViewer viewer,
int feature) {
viewer.setColumnViewerEditor(new GridViewerEditor(viewer,
editorActivationStrategy, feature));
public static void create(MyGridTreeViewer viewer,
int feature) {
name="MyGridTableViewer.java"
filename="MyGridTableViewer.java"
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Widget;
public class MyGridTableViewer extends GridTableViewer {
public MyGridTableViewer(Grid grid) {
super(grid);
// TODO Auto-generated constructor stub
public MyGridTableViewer(Composite parent, int style) {
super(parent, style);
public MyGridTableViewer(Composite parent) {
super(parent);
protected ViewerRow getViewerRowFromItem(Widget item) {
// TODO Auto-generated method stub
return super.getViewerRowFromItem(item);
name="MyGridTreeViewer.java"
filename="MyGridTreeViewer.java"
public class MyGridTreeViewer extends GridTreeViewer {
public MyGridTreeViewer(Grid grid) {
super(grid);
public MyGridTreeViewer(Composite parent, int style) {
public MyGridTreeViewer(Composite parent) {
super(parent);
--------------020202070508030301070905--
Re: Grid - Inline Editing [message #52899 is a reply to message #52872] |
Mon, 12 May 2008 15:15 |
Thank you very much. I'll give this a try tomorrow and let you know.
Besides that, would this be a valuable feature/enhancement for future
JFace releases?
Peter
>> Hello Tom.
>> I have a special requirement. When the active cell is the really last
>> one in the grid and the user presses the tab-key a new record/row
>> should be added to the grid. It's more or less the same as in MS
>> Word/OO when the user is editing the last cell of a table and pressing
>> the tab-key automatically adds one new row.
> Tom
Re: Grid - Inline Editing [message #589719 is a reply to message #52659] |
Tom
> Hello.
> into account?
> Thanks in adavance.
> Peter
Re: Grid - Inline Editing [message #589733 is a reply to message #52687] |
Peter Pfeifer Messages: 98 Registered: July 2009 |
Member |
Hello Tom.
Thanks Peter
> Tom
>> Hello.
>> order into account?
>> Thanks in adavance.
>> Peter
Re: Grid - Inline Editing [message #589794 is a reply to message #52845] |
> Hello Tom.
Tom
* Contributors:
int feature) {
} else {
if (item != null) {
return null;
} else {
int feature) {
int feature) {
super(grid);
super(parent);
super(grid);
super(parent);
Current Time: Sat May 04 12:42:16 GMT 2024
Powered by FUDForum. Page generated in 0.06289 seconds
