| Auto-closing of parentheses cannot be disabled. [message #520974] |
Mon, 15 March 2010 21:49  |
I'm using build 20100218-1602 of Eclipse under MacOSX, although the problem I'm about to describe has existed under several other earlier versions that I have used on various OS's.
I want to disable the automatic closing of parentheses, but the setting that controls this doesn't seem to work. When I type an open paren after a function name, Eclipse always immediately puts a close paren to the right of it, even when the following setting is unchecked:
Preferences->Java->Editor->Typing->Automatically close
(Parentheses), [square], and <angle> brackets.
I know that there is a difference of opinion as to whether auto-closing of parentheses is desirable, and I'm sure that this is the reason for why the behavior is controlled by an option.
But the option doesn't work.
Is there another setting somewhere in the IDE which controls this?
Or is there perhaps a property I can set outside of the IDE which can turn off this auto-close behavior?
Thanks in advance for any suggestions.
[Updated on: Mon, 15 March 2010 21:50] by Moderator
| Re: Auto-closing of parentheses cannot be disabled. [message #640325 is a reply to message #539611] |
Sat, 20 November 2010 10:56  |
I'm following up on this after a long absence.
I understand that I'm stuck with that horrible (IMHO) auto-inserted close parenthesis when proposals are enabled. I guess I just have to live with this "feature".
But I thought of a possible way to reduce my discomfort: is there a way to disable only the method argument proposals, but to keep all the other proposals enabled?
Thanks in advance.
FUDForum. Page generated in 1.14665 seconds
