Home » Modeling » OCL » actor, usecase relationship query
actor, usecase relationship query [message #520911] Mon, 15 March 2010 13:41 Go to next message
I am new to UML and OCL. I am reading superstructure document, where actor and usecase relationship is defined in OCL like this:
self.ownedAttribute->forAll ( a |
(a.association->notEmpty()) implies
((a.association.memberEnd.size() = 2) and
 (a.opposite.class.oclIsKindOf(UseCase) or
  (a.opposite.class.oclIsKindOf(Class) and not a.opposite.class.oclIsKindOf(Behavior))))
I want to count how many usecases are associated with one actor.
from above OCL definition it should be like this (I am using OCL Interpreter console to run this query)
Actor.allInstances().attribute.opposite.class->select(oclIsTypeOf(UseCase))->size()
but it does not work. can any one guide me to resolve this query.
regards,
arise
Re: actor, usecase relationship query [message #520925 is a reply to message #520911] Mon, 15 March 2010 15:37 Go to previous messageGo to next message
Hi arise
'does not work' is never a good way to report a problem.
What happened?
Did it return 0.
Did it crash ?
Did it give a syntax error ?
Ed Willink
Re: actor, usecase relationship query [message #520956 is a reply to message #520925] Mon, 15 March 2010 18:55 Go to previous messageGo to next message
Hi Edward
It returns zero.
does not work --> may be considered as does not provide correct result and I am sorry for misleading words.
regards,
arise
Re: actor, usecase relationship query [message #521008 is a reply to message #520956] Mon, 15 March 2010 23:26 Go to previous messageGo to next message
> It returns zero.
Well now you need to bug the problem.
Why is it zero?
Is the expression wrong (with seven terms quite probably)?
Is the source data as expected (quite possibly not, wrong file/didn't
load/...)
Try a simpler expression such as
then
and at some point you should encounter a more obvious discrepancy with
your expectation.
Ed Willink
Re: actor, usecase relationship query [message #521058 is a reply to message #521008] Tue, 16 March 2010 07:12 Go to previous messageGo to next message
Hi Ed,
I follow your steps:
successfully parsed with the correct results
successfully parsed with out any error but with empty result. I mean there is no output.
I have tried and check with some simple queries on this file and they executed with correct result that means I have loaded the correct UML file.
I do not know whats wrong with the query as I am new to OCL. I may be going in wrong direction to count actor use case relationship.
Do you think any other way to count how many usecases are associated to one actor.
Thanks for help,
arise
Re: actor, usecase relationship query [message #521228 is a reply to message #521058] Tue, 16 March 2010 15:44 Go to previous messageGo to next message
Hi arise
You haven't provided any executable evidence, so I'm left to guess at
your meta-models.
If there is no output then I suspect that you have no Actors with
attributes.
NB Actor.allInstances().attribute is shorthand for
Actor.allInstances()->collect(attribute)
Ed Willink
On 16/03/2010 11:12, arise76 wrote:
> Hi Ed,
> there is no output.
> one actor.
> Thanks for help,
> arise
Re: actor, usecase relationship query [message #521434 is a reply to message #521228] Wed, 17 March 2010 11:26 Go to previous messageGo to next message
Hi Ed,
I do not understand what do you mean by attribute.
suppose usecase diagram is like this:
actor A---uc1
actor A---uc2
actor A-- uc3
from above scenario actor A is associated to three usecases.
I want to use OCL query to calculate this:
The follwoing queries I have tested..
1. Actor.allInstances()->size()
Result:
3
2. Actor.allInstances().attribute
Result
no result
3. Actor.allInstances().attribute->size()
Result
0
I tried with another way I got the result but I do not know it is correct way or not:
Association.allInstances().endType->select(e|e.oclIsTypeOf(Actor).and(Association.allInstances().endType->exists(a|a.oclIsTypeOf(UseCase))))->size()
regards,
arise
Re: actor, usecase relationship query [message #521454 is a reply to message #521434] Wed, 17 March 2010 07:12 Go to previous messageGo to next message
Hi, arise,
In the UML2 metamodel, Actors and Use Cases cannot own attributes.
Their "attribute" property has no subsets contributing any elements to
it, so it is always empty.
You will have to search by assocation, instead. The "other way" that
you tried is the correct approach. For your original problem of
counting how many uses cases are associated with a given actor, you
might try (I have not tested this):
context Actor
def: associatedUseCases : Set(UseCase) =
Association.allInstances()->select(
isBinary() and endType->contains(self))->iterate(
assoc : Assocation; ucs : Set(UseCase) = Set{} |
let actorEnd : Property = assoc.end->any(type = self).otherEnd,
useCase : UseCase = actorEnd.type.oclAsType(UseCase)
if useCase.oclIsUndefined() then
ucs
else
ucs->including(useCase)
endif
def: countUseCases : Integer = associatedUseCases->size()
Basically, the idea is to iterate through the associations involving the
actor and, for each, find the end that is the actor's end. The actor's
end is the opposite of the end typed by the actor, and thus is the one
expected to be typed by the use case. Then, if this end actually is
typed by a use case, the result of oclAsType is defined and we can add
it to the result set.
Christian
On 17/03/10 11:26 AM, arise76 wrote:
> Hi Ed,
> actor A---uc1
> actor A---uc2
> actor A-- uc3
> Result:
> 3
> Result
> no result
> Result
> 0
> correct way or not:
> Association.allInstances().endType-> select(e|e.oclIsTypeOf(Actor).and(Association.allInstances() .endType- >exists(a|a.oclIsTypeOf(UseCase))))->size()
> regards,
> arise
Re: actor, usecase relationship query [message #521470 is a reply to message #521454] Wed, 17 March 2010 13:06 Go to previous messageGo to next message
Hi Christian,
Thanks alot, I understand the problem now, but I am new to OCL world. I am using eclipse OCL interpreter console to execute OCL queries. It always complain about context keyword.
Another question I have related to OCL, I hope you will guide me:
I want to reuse OCLEvaluator Class (from OCLInterpreter example) to my java project to run these queries , is there any tutorial available or any simple example to run these queries.
arise
Re: actor, usecase relationship query [message #522414 is a reply to message #521470] Mon, 22 March 2010 11:06 Go to previous message
Hi, arise,
The OCL Interactive Console does not use the syntax for context
declaration. It parses expressions in the "embedded" style, taking as
the context the element currently selected in the model editor.
So, for example, if you have selected an Actor "arise" in your model,
then the expression that you enter in the console is parsed as
- an invariant constraint (the most appropriate for when the
context is a classifier) in the context of the "arise" actor
if the modeling level control is set to M1 (User Model)
- a query expression in the context of the Actor metaclass if the
modeling level control is set to M2 (Metamodel)
You would get different results if you select, say, operations or
properties in the M1 modeling level.
Concerning usage of OCLEvaluator, there is no tutorial, but the example
itself is, of course, an example of how to use it. Just see how the
console uses it.
HTH,
Christian
On 17/03/10 01:06 PM, arise76 wrote:
> Hi Christian,
> arise
Previous Topic:EMF validation: provide clientData for validationListeners from inside a constraint
Next Topic:OCL related query
Current Time: Thu Nov 06 12:54:56 EST 2025
Powered by FUDForum. Page generated in 1.06759 seconds
