Home » Eclipse Projects » Rich Client Platform (RCP) » customize Splashscreen using StartupMonitor(how to modify the splashscreen in realtime using StartupMonitor)
customize Splashscreen using StartupMonitor [message #520786] Mon, 15 March 2010 06:42
Hello. I'm trying to create/modify my RCP product splashscreen so that I can have full access to the the Splash Shell all the time.
Basically, what I want to do is change the shell image in real-time when a plugin is loaded, put custom text (replace the "Loading Wrkbench" text), mix images, etc.
I have read articles about using the org.eclipse.ui.splashHandlers extension, but this splash screen extension point takes affect when the Workbench is starting up, right after the workspace-choose dialog. I understand that it is possible to use the StartupMonitor earlier, but I couldn't find a clean example anywhere.
Any help is much appreciated.
Thanks a lot,
Viorel
Previous Topic:org.eclipse.ui.console
Next Topic:Can't launch RCP App with Minimal Target
Current Time: Wed Nov 05 07:47:04 EST 2025
Powered by FUDForum. Page generated in 0.03048 seconds
