Home » Archived » Service Component Architecture (SCA) Tools » Component within SCA assembly
Component within SCA assembly [message #520750] |
Mon, 15 March 2010 03:27  |
Originally posted by: michael.gebhart.googlemail.com
I have a question about the component concept within an SCA assembly.
Is it possible to use an already running Web service as component within
an SCA assembly? Or is the component within an SCA assembly always a
newly developed part?
And: In my opinion, a service is a functionality that is running and can
be used by other parties. Is it possible to call a component within a
SCA assembly even if it is not associated with a service at the SCA
assembly? In other words: Is a component within a SCA assembly already a
service? Can it be used by other parties that can not access the source
code?
Michael
Re: Component within SCA assembly [message #521324 is a reply to message #520750] |
Wed, 17 March 2010 00:48   |
Hi Michael,
Le 15/03/2010 08:27, Michael Gebhart a écrit :
> an SCA assembly?
Formulated like you did, I would say no.
For me, a service means an available interface, and no access to the
implementation. To expose an already existing web service through an SCA
application, you would have to create a component with a reference and a
service, and an implementation which only calls the reference.
Otherwise, I would even just declare a reference on this web service.
No need for a new component.
Once again, an SCA component is a configured implementation.
That is to say, a piece of code that you declare in the composite, and
that you link with services and references.
In your use case, if you absolutely want to have an SCA component
implemented by your web service, yes, you will have to code it.
> assembly?
If your component is an SCA component, then no, it's not possible.
A service has an interface. If it is not exposed, it cannot be called.
And if a service is not declared on a component, then there is not
service and no exposed interface.
> code?
No.
Vincent.
Re: Component within SCA assembly [message #576954 is a reply to message #520750] |
Wed, 17 March 2010 05:35  |
Hi Michael,
> an SCA assembly?
> assembly?
> code?
No.
Vincent.
Current Time: Wed May 14 21:16:20 EDT 2025
Powered by FUDForum. Page generated in 0.04264 seconds
