Home » Archived » Buckminster » Buckminster fails to find bundles
Buckminster fails to find bundles [message #520344] |
Fri, 12 March 2010 02:50 |
Alex Kravets Messages: 561 Registered: November 2009 |
During my build Buckminster fails to find some bundles which are pretty much the same in nature as other bundles that have been successfully located. I even created a word by word locator just to find these bundles, but nothing helps. This is the error I am getting:
Quote: |
org.apache.log4j:eclipse.feature/[1.2.14.v200701080905,1.2.1 4.v200701080905]: No provider was found that could resolve the request
ERROR [0000] : No suitable provider for component org.apache.log4j:eclipse.feature/[1.2.14.v200701080905,1.2.1 4.v200701080905] was found in resourceMap file:/home/akravets2/.hudson/jobs/buckminster.job/workspace/ totaltrader/build/com.totaltrader.site/site.rmap
ERROR [0000] : No suitable provider for component org.apache.log4j:eclipse.feature/[1.2.14.v200701080905,1.2.1 4.v200701080905] was found in searchPath totaltrader
ERROR [0000] : Resolution attempt ended with exception: Provider local( file:///home/akravets2/.hudson/jobs/buckminster.job/workspac e/totaltrader/org.apache.log4j): Missing CSpec source required by component type eclipse.feature
ERROR Provider local( file:///home/akravets2/.hudson/jobs/buckminster.job/workspac e/totaltrader/org.apache.log4j): Missing CSpec source required by component type eclipse.feature
org.apache.commons:eclipse.feature/[1.0.0.v200701071427,1.0. 0.v200701071427]: No provider was found that could resolve the request
ERROR [0000] : No suitable provider for component org.apache.commons:eclipse.feature/[1.0.0.v200701071427,1.0. 0.v200701071427] was found in resourceMap file:/home/akravets2/.hudson/jobs/buckminster.job/workspace/ totaltrader/build/com.totaltrader.site/site.rmap
ERROR [0000] : No suitable provider for component org.apache.commons:eclipse.feature/[1.0.0.v200701071427,1.0. 0.v200701071427] was found in searchPath totaltrader
ERROR [0000] : Resolution attempt ended with exception: Provider local( file:///home/akravets2/.hudson/jobs/buckminster.job/workspac e/totaltrader/org.apache.commons): Missing CSpec source required by component type eclipse.feature
ERROR Provider local( file:///home/akravets2/.hudson/jobs/buckminster.job/workspac e/totaltrader/org.apache.commons): Missing CSpec source required by component type eclipse.feature
What is the nature of this error?
Also, how does Buckminster decide what is the eclipse.feature and osgi.bundle. I have two similar bundles org.jdom and or.apache.log4j, first is treated as bundle and second as feature.
thanks,
Alex
[Updated on: Fri, 12 March 2010 02:56] Report message to a moderator
Re: Buckminster fails to find bundles [message #520406 is a reply to message #520344] |
Fri, 12 March 2010 04:58 |
Hi Alex,
From the looks of it, the resolver isn't trying to find bundles. It's looking for features. It fails because it doesn't
find the feature.xml at the specified locations.
HTH,
- thomas
On 03/12/2010 03:50 AM, Alex wrote:
> Hello,
> Quote:
> thanks,
> Alex
Re: Buckminster fails to find bundles [message #520407 is a reply to message #520344] |
Achim Demelt Messages: 160 Registered: July 2009 |
Hi Alex,
It looks to me like the component type is wrong. The error message says:
org.apache.log4j:eclipse.feature/...: No provider was found
I think that there is no feature for org.apache.log4j, only a bundle. The
same applies to the other artifacts that cannot be resolved. Can you check
your dependencies?
Achim
Alex wrote:
> Hello,
> but nothing helps. This is the error I am getting: Quote:
> thanks,
> Alex
Re: Buckminster fails to find bundles [message #520549 is a reply to message #520501] |
Fri, 12 March 2010 14:22 |
Hi Alex,
The log4j bundle itself is ok. It's rather the component that references it
seems to look for a *feature* named org.apache.log4j, rather than a bundle.
Do you have a CSPEC somewhere that depends on org.apache.log4j?
Achim
Alex wrote:
> Thanks Thomas and Achim,
> Yeah, that's what I thought, but wasn't sure completely.
> May be you can take a look at my manifest to see what's wrong?
> Manifest-Version: 1.0
> Bundle-ManifestVersion: 2
> Bundle-Name: %pluginName
> Bundle-SymbolicName: org.apache.log4j
> Bundle-Version: 1.2.14.v200701080905
> Bundle-Vendor: %providerName
> Bundle-Localization: plugin
> Export-Package: org.apache.log4j;version="1.2.14",
> org.apache.log4j.chainsaw;version="1.2.14",
> org.apache.log4j.config;version="1.2.14",
> org.apache.log4j.helpers;version="1.2.14",
> org.apache.log4j.jdbc;version="1.2.14",
> org.apache.log4j.jmx;version="1.2.14",
> org.apache.log4j.lf5;version="1.2.14",
> org.apache.log4j.lf5.util;version="1.2.14",
> org.apache.log4j.lf5.viewer;version="1.2.14",
> org.apache.log4j.lf5.viewer.categoryexplorer;version="1.2.14 ",
> org.apache.log4j.lf5.viewer.configure;version="1.2.14",
> org.apache.log4j.net;version="1.2.14",
> org.apache.log4j.nt;version="1.2.14",
> org.apache.log4j.or;version="1.2.14",
> org.apache.log4j.or.jms;version="1.2.14",
> org.apache.log4j.or.sax;version="1.2.14",
> org.apache.log4j.spi;version="1.2.14",
> org.apache.log4j.varia;version="1.2.14",
> org.apache.log4j.xml;version="1.2.14"
> Bundle-ClassPath: log4j-1.2.14.jar
> Bundle-RequiredExecutionEnvironment: J2SE-1.4
> thanks,
> Alex
Current Time: Fri Apr 26 04:13:13 GMT 2024
Powered by FUDForum. Page generated in 0.03465 seconds
