Re: buckminster headless subversive support not working [message #520405 is a reply to message #520034] |
Fri, 12 March 2010 04:58 |
Hi Bernhard,
I have no problems with Subversive. What update sites are you currently using? The reason I ask is that I suspect that
you might have a mix of 3.6 and 3.5 bundles.
You should use either this combination
http://download.eclipse.org/tools/buckminster/updates-3.6 (or headless-3.6)
http://download.cloudsmith.com/buckminster/external-3.6
or this combination
http://download.eclipse.org/tools/buckminster/updates-3.5 (or headless-3.5)
http://download.cloudsmith.com/buckminster/external-3.5
This one won't fly:
*http://download.cloudsmith.com/buckminster/external (BAD, only 3.5)
Thomas Hallgren
On 03/10/2010 10:45 PM, Bernhard Merkle wrote:
> I installed subversive headless support as described on the wiki, but it
> is not working...
> any idea how I can debug this ?
> --> subversive support seems to be installed...
> C:\ide\ibm\buckminster-headless>buckminster listsite
> Features:
> org.eclipse.buckminster.core.headless.feature (Buckminster - Core Headless)
> org.eclipse.buckminster.pde.headless.feature (Buckminster - PDE support
> for headless operation)
> org.eclipse.buckminster.product (Buckminster Product)
> org.eclipse.buckminster.subversive.headless.feature (Buckminster -
> Subversive based SVN support for headless operation)
> org.eclipse.equinox.p2.director.feature (Equinox P2 Director Feature)
> --> If i start the build i get the following errors:
> C:\ide\ibm\buckminster-headless>buckminster.bat -consoleLog -L DEBUG
> -data file:///W:/Buckminster_SopasGenerator build
> !SESSION 2010-03-10 22:39:48.078
> eclipse.buildId=unknown
> java.version=1.6.0_16
> java.vendor=Sun Microsystems Inc.
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
> Framework arguments: -L DEBUG build
> Command-line arguments: -consoleLog -L DEBUG -data
> !ENTRY org.eclipse.buckminster.runtime 0 293 2010-03-10 22:39:50.078
> !MESSAGE build
> build
> ERROR: Problems occurred when invoking code from plug-in:
> "org.eclipse.core.resources".
> org.eclipse.team.svn.core.operation.UnreportableException: Selected SVN
> connector library is not available or cannot be loaded.
> If you selected native JavaHL connector, please check if binaries are
> available or install and select pure Java Subversion connector from the
> plug-in
> connectors update site.
> If connectors already installed then you can change the selected one at:
> Window->Preferences->Team->SVN->SVN Connector.
> at
> org.eclipse.team.svn.core.extension.factory.ISVNConnectorFac tory$1.newInstance(ISVNConnectorFactory.java:105)
> at
> org.eclipse.team.svn.core.utility.SVNUtility.getSVNInfoForNo tConnected(SVNUtility.java:833)
> at
> org.eclipse.team.svn.core.SVNTeamProvider.uploadRepositoryRe source(SVNTeamProvider.java:238)
> I have selected Java Native HL in my eclipse...
> the project also builds if i disconnect my projects from the team
> provider...
> thanks for your help,
> Bernhard.
FUDForum. Page generated in 0.05101 seconds
