Home » Archived » BIRT » Joint data set does not invoke DataSourceEventHandler(DataSourceEventHandler.beforeOpen method is not executed with joint data set)
Joint data set does not invoke DataSourceEventHandler [message #519472] Mon, 08 March 2010 17:38 Go to next message
I have a DataSourceEventHandler with a beforeOpen() method that updates the connection properties (user and password) to point to a specific schema depending on the value of a request parameter. This works fine as long as the report uses only one table. Reports that use a joint data set to join two or more tables fail because the DataSourceEventHandler is never invoked.
I've run this in debug with break points set in the event handler's beforeOpen method and on the JDBC driver's connect method. The stack looks like this when it works correctly (single table).
DataSourceEventHandler.beforeOpen(IDataSourceInstance, IReportContext) line: 32
DataSourceScriptExecutor.handleBeforeOpen(IDataSourceInstanceHandle) line: 87
OdaDataSourceRuntime(DataSourceRuntime).beforeOpen() line: 245
PreparedOdaDSQuery$OdaDSQueryExecutor(QueryExecutor).dataSourceBeforeOpen() line: 184
PreparedOdaDSQuery$OdaDSQueryExecutor(QueryExecutor).openDataSource() line: 386
PreparedOdaDSQuery$OdaDSQueryExecutor(QueryExecutor).prepareExecution(IBaseQueryResults, Scriptable) line: 315
When using a joint data set the stack looks like this when it hits the driver's connect method (the event handler's breakpoint is skipped)
Driver.connect(String, Properties) line: 175
JDBCDriverManager$WrappedDriver.connect(String, Properties) line: 1162
DriverManager.getConnection(String, Properties, ClassLoader) line: 582
DriverManager.getConnection(String, Properties) line: 154
JDBCDriverManager.doConnect(String, String, String, Properties, Collection<String>) line: 251
JDBCDriverManager.getConnection(String, String, String, Properties, Collection<String>) line: 212
Connection.connectByUrl(String, Properties) line: 234
Connection.open(Properties) line: 160
OdaConnection.open(Properties) line: 238
ConnectionManager.openConnection(String, Properties, Map) line: 180
DataSource.newConnection() line: 193
DataSource.open() line: 181
OdaDataSourceRuntime(DataSourceRuntime).openOdiDataSource(IDataSource) line: 209
PreparedOdaDSQuery$OdaDSQueryExecutor(QueryExecutor).openDataSource() line: 396
The stack above that point is the same in both cases.
The data source looks like this:
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc" name="WMDataSource" id="5">
    <property name="eventHandlerClass">com.infor.wm.reports.birtviewer.DataSourceEventHandler</property>
    <property name="odaDriverClass">net.sourceforge.jtds.jdbc.Driver</property>
    <property name="odaURL">jdbc:jtds:sqlserver://localhost:1433/WMPRD;useLOBs=false</property>
    <property name="odaUser">******</property>
    <encrypted-property name="odaPassword" encryptionID="base64">******</encrypted-property>
</oda-data-source>
Re: Joint data set does not invoke DataSourceEventHandler [message #519615 is a reply to message #519472] Tue, 09 March 2010 08:49 Go to previous messageGo to next message
John,
Can you try this in script like the attached example?
Also please log a bug for this.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.20"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.5.1.v20090903 Build &lt;2.5.1.v20090917-1447></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="7">
<text-property name="displayName"></text-property>
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="8">
<list-property name="columnHints">
<structure>
<property name="columnName">ORDERNUMBER</property>
<text-property
name="displayName">ORDERNUMBER</text-property>
</structure>
<structure>
<property name="columnName">PRODUCTCODE</property>
<text-property
name="displayName">PRODUCTCODE</text-property>
</structure>
<structure>
<property name="columnName">QUANTITYORDERED</property>
<text-property
name="displayName">QUANTITYORDERED</text-property>
</structure>
<structure>
<property name="columnName">PRICEEACH</property>
<text-property
name="displayName">PRICEEACH</text-property>
</structure>
<structure>
<property name="columnName">ORDERLINENUMBER</property>
<text-property
name="displayName">ORDERLINENUMBER</text-property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ORDERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">PRODUCTCODE</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">PRICEEACH</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">ORDERLINENUMBER</property>
</structure>
</list-property>
</structure>
<method name="beforeOpen"><![CDATA[this.queryText = "select
* from orderdetails where ordernumber = 10104";]]></method>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select *
from orderdetails where ordernumber = 10101]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>ORDERNUMBER</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>PRODUCTCODE</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>PRODUCTCODE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRODUCTCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>QUANTITYORDERED</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>QUANTITYORDERED</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>QUANTITYORDERED</design:label>
<design:attributes>
<design:name>PRICEEACH</design:name>
<design:position>4</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>PRICEEACH</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRICEEACH</design:label>
<design:displaySize>22</design:displaySize>
<design:attributes>
<design:name>ORDERLINENUMBER</design:name>
<design:position>5</design:position>
<design:nativeDataTypeCode>5</design:nativeDataTypeCode>
<design:precision>5</design:precision>
<design:uiHints>
<design:displayName>ORDERLINENUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERLINENUMBER</design:label>
<design:displaySize>6</design:displaySize>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>
]]></xml-property>
</oda-data-set>
<oda-data-set
name="Data Set1" id="9">
<structure>
<text-property
</structure>
<structure>
<property name="columnName">ORDERDATE</property>
<text-property
name="displayName">ORDERDATE</text-property>
</structure>
<structure>
<property name="columnName">REQUIREDDATE</property>
<text-property
name="displayName">REQUIREDDATE</text-property>
</structure>
<structure>
<property name="columnName">SHIPPEDDATE</property>
<text-property
name="displayName">SHIPPEDDATE</text-property>
</structure>
<structure>
<property name="columnName">STATUS</property>
<text-property
name="displayName">STATUS</text-property>
</structure>
<structure>
<property name="columnName">COMMENTS</property>
<text-property
name="displayName">COMMENTS</text-property>
</structure>
<structure>
<property name="columnName">CUSTOMERNUMBER</property>
<text-property
name="displayName">CUSTOMERNUMBER</text-property>
</structure>
</list-property>
<structure>
</structure>
<structure>
<property name="name">ORDERDATE</property>
<property name="dataType">date</property>
</structure>
<structure>
<property name="name">REQUIREDDATE</property>
</structure>
<structure>
<property name="name">SHIPPEDDATE</property>
</structure>
<structure>
<property name="name">STATUS</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">COMMENTS</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">CUSTOMERNUMBER</property>
</structure>
</list-property>
</structure>
* from orders where ordernumber = 10104";]]></method>
<structure>
</structure>
<structure>
<property name="nativeName">ORDERDATE</property>
<property name="nativeDataType">91</property>
</structure>
<structure>
<property name="nativeName">REQUIREDDATE</property>
</structure>
<structure>
<property name="nativeName">SHIPPEDDATE</property>
</structure>
<structure>
<property name="nativeName">STATUS</property>
</structure>
<structure>
<property name="nativeName">COMMENTS</property>
</structure>
<structure>
<property name="nativeName">CUSTOMERNUMBER</property>
</structure>
</list-property>
from orders where ordernumber = 10101]]></xml-property>
<model:DesignValues
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:name>ORDERDATE</design:name>
<design:nativeDataTypeCode>91</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>ORDERDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERDATE</design:label>
<design:displaySize>10</design:displaySize>
<design:attributes>
<design:name>REQUIREDDATE</design:name>
<design:uiHints>
<design:displayName>REQUIREDDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>REQUIREDDATE</design:label>
<design:attributes>
<design:name>SHIPPEDDATE</design:name>
<design:uiHints>
<design:displayName>SHIPPEDDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>SHIPPEDDATE</design:label>
<design:attributes>
<design:name>STATUS</design:name>
<design:uiHints>
<design:displayName>STATUS</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>STATUS</design:label>
<design:attributes>
<design:name>COMMENTS</design:name>
<design:position>6</design:position>
<design:precision>32700</design:precision>
<design:uiHints>
<design:displayName>COMMENTS</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>COMMENTS</design:label>
<design:displaySize>32700</design:displaySize>
<design:attributes>
<design:name>CUSTOMERNUMBER</design:name>
<design:position>7</design:position>
<design:uiHints>
<design:displayName>CUSTOMERNUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CUSTOMERNUMBER</design:label>
</model:DesignValues>]]></xml-property>
</oda-data-set>
<joint-data-set name="JDS" id="10">
<structure>
<property name="columnName">Data
Set::QUANTITYORDERED</property>
<property name="alias">QUANTITYORDERED</property>
<text-property name="displayName">Data
Set::QUANTITYORDERED</text-property>
</structure>
<structure>
Set1::CUSTOMERNUMBER</property>
<property name="alias">CUSTOMERNUMBER</property>
Set1::CUSTOMERNUMBER</text-property>
</structure>
<structure>
Set1::ORDERNUMBER</property>
<property name="alias">Data
Set1::ORDERNUMBER</text-property>
</structure>
<structure>
Set::PRICEEACH</property>
<property name="alias">PRICEEACH</property>
Set::PRICEEACH</text-property>
</structure>
<structure>
Set::ORDERNUMBER</property>
<property name="alias">Data Set::ORDERNUMBER</property>
Set::ORDERNUMBER</text-property>
</structure>
<structure>
Set::PRODUCTCODE</property>
<property name="alias">PRODUCTCODE</property>
Set::PRODUCTCODE</text-property>
</structure>
<structure>
Set1::STATUS</property>
<property name="alias">STATUS</property>
Set1::STATUS</text-property>
</structure>
<structure>
Set::ORDERLINENUMBER</property>
<property name="alias">ORDERLINENUMBER</property>
Set::ORDERLINENUMBER</text-property>
</structure>
<structure>
Set1::REQUIREDDATE</property>
<property name="alias">REQUIREDDATE</property>
Set1::REQUIREDDATE</text-property>
</structure>
<structure>
Set1::COMMENTS</property>
<property name="alias">COMMENTS</property>
Set1::COMMENTS</text-property>
</structure>
<structure>
Set1::ORDERDATE</property>
<property name="alias">ORDERDATE</property>
Set1::ORDERDATE</text-property>
</structure>
<structure>
Set1::SHIPPEDDATE</property>
<property name="alias">SHIPPEDDATE</property>
Set1::SHIPPEDDATE</text-property>
</structure>
</list-property>
<structure>
<property name="name">Data
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
<property name="position">8</property>
</structure>
<structure>
<property name="position">9</property>
</structure>
<structure>
<property name="position">10</property>
</structure>
<structure>
<property name="position">11</property>
</structure>
<structure>
<property name="position">12</property>
</structure>
</list-property>
</structure>
<simple-property-list name="dataSets">
<value>Data Set</value>
<value>Data Set1</value>
</simple-property-list>
<list-property name="joinConditions">
<structure>
<property name="joinType">full-out</property>
<property name="joinOperator">eq</property>
<property name="leftDataSet">Data Set</property>
<property name="rightDataSet">Data Set1</property>
<expression
name="leftExpression">dataSetRow["ORDERNUMBER"]</expression >
<expression
name="rightExpression">dataSetRow["ORDERNUMBER"]</expression >
</structure>
</list-property>
</joint-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">sans-serif</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab-cell" id="6">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
</report>
> is never invoked.
> line: 32
> DataSourceScriptExecutor.handleBeforeOpen(IDataSourceInstanc eHandle)
> line: 87
> PreparedOdaDSQuery$OdaDSQueryExecutor(QueryExecutor).dataSou rceBeforeOpen()
> line: 184
> PreparedOdaDSQuery$OdaDSQueryExecutor(QueryExecutor).openDat aSource()
> line: 386
> PreparedOdaDSQuery$OdaDSQueryExecutor(QueryExecutor).prepare Execution(IBaseQueryResults,
> OdaDataSourceRuntime(DataSourceRuntime).openOdiDataSource(ID ataSource)
> line: 209
> line: 396
> <property
> name="eventHandlerClass">com.infor.wm.reports.birtviewer.DataSourceEventHandler </property>
> <property
> name="odaDriverClass">net.sourceforge.jtds.jdbc.Driver</property >
> <property
> </oda-data-source>
Re: Joint data set does not invoke DataSourceEventHandler [message #519640 is a reply to message #519615] Tue, 09 March 2010 10:04 Go to previous messageGo to next message
Bug 305165 has been created.
Re: Joint data set does not invoke DataSourceEventHandler [message #519770 is a reply to message #519640] Tue, 09 March 2010 11:34 Go to previous message
Thanks John
John Sipher wrote:
> Bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=305165 has been created.
Re: Joint data set does not invoke DataSourceEventHandler [message #519771 is a reply to message #519770] Tue, 09 March 2010 11:34 Go to previous message
BTW did you try the JavaScript event?
Jason Weathersby wrote:
> Thanks John
>> created.
Previous Topic:Eclipse RCP issue with modal dialog
Next Topic:BIRT install on Windows 7
Current Time: Wed Aug 20 09:02:07 EDT 2025
Powered by FUDForum. Page generated in 0.03759 seconds
