| Returning Arrays from EOperations [message #519017] |
Fri, 05 March 2010 12:11  |
Originally posted by: jconlon.apache.org
I am importing a schema into a model to generate classes but I also need
to implement some interfaces with those generated classes. Would like
to do this with annotations on the schema.
Several of the methods I need to implement, return arrays. Most are
String arrays and one returns an array on one of my complex types.
Here is an example.
<!-- public String[] getDefaultValue() -->
<operation name="getDefaultValue" type="xs:string" lowerBound="1"
upperBound="-1">
<body>
return getDefault().split(",");
</body>
</operation>
The above generates an EList<String>. How can I return an array instead
of an EList without manually editing my generated code?
thanks for any pointers,
John
| Re: Returning Arrays from EOperations [message #519085 is a reply to message #519075] |
Sat, 06 March 2010 04:38  |
John,
Comments below.
John E. Conlon wrote:
> Hi Ed,
> Response below,
> Ed Merks wrote:
>> John,
>> Comments below.
>>> need to implement some interfaces with those generated classes.
>>> Would like to do this with annotations on the schema.
>>> Here is an example.
>>> upperBound="-1">
>>> <body>
>>> </body>
>>> </operation>
>>> instead of an EList without manually editing my generated code?
>> You'll need to define an EDataType, which in XML Schema means a
>> simple type. So yes, unfortunately you do need an actual type in the
>> schema itself. You might put it in a separate schema that you import.
> My annotated schema is significantly enhanced already with the
> existing annotations. Don't think adding a simpleType (or several -
> since I need some for throwing some exceptions too.) should change
> it's functional capabilities for validation.
That's right.
> Are there any other reasons for putting it in a separate schema?
Nope.
> The
>> instance type name annotation for it must specify
>> "java.lang.String[]". Then you can refer to that simple type
>> wherever you need it.
> It works - here's what I did:
> <simpleType name="StringArray"
> ecore:instanceClass="java.lang.String[]">
> <restriction base="string"/>
> </simpleType>
> <simpleType name="AttributeDefinitionArray"
> ecore:instanceClass="org.osgi.service.metatype.AttributeDefinition[] ">
> </simpleType>
> And referenced them like:
> <!-- public String[] getOptionValues() -->
> <operation name="getOptionValues" type="metatype:StringArray">
> <body>...
> thanks for the help,
Given these types don't need to support persistence because they aren't
used in non-transient attributes, you could use
ecore:serializaable="false" on them; that avoids generating the to/from
string conversion methods in the factory.
> John
FUDForum. Page generated in 0.03016 seconds
