Re: Headless SVN not working with 3.6? [message #519021 is a reply to message #519008] |
Fri, 05 March 2010 17:35 |
Hi Patrick,
What sites are you using for provisioning the headless Buckminster?
- thomas
On 03/05/2010 05:43 PM, Patrick Ruckstuhl wrote:
> I tried both subversive and subclipse but without success.
> When I try it with subversive I get
> ERROR [0001] :
> org.eclipse.team.svn.core.operation.UnreportableException: Selected SVN
> connector library is not available or cannot be loaded.
> If you selected native JavaHL connector, please check if binaries are
> available or install and select pure Java Subversion connector from the
> plug-in connectors update site.
> If connectors already installed then you can change the selected one at:
> Window->Preferences->Team->SVN->SVN Connector.
> INFO: TAG-ID 0001 = Query for
> ch.ethz.origo.aranea.messagedsl.feature:eclipse.feature
> if I try subclipse I get
> ERROR [0001] : No suitable provider for component
> ch.ethz.origo.aranea.messagedsl.feature:eclipse.feature was found in
> resourceMap
> file:/home/build/tmp/ch.ethz.origo.aranea.messagedsl.build/a ranea.rmap
> searchPath aranea
> ERROR [0001] : Rejecting provider
> svn(https://svn.origo.ethz.ch/aranea/trunk/dev/{0}): No component match
> was found
> ERROR Unable to load default SVN Client
> Running the same mspec from within eclipse works fine and fetches the
> projects from SVN.
Re: Headless SVN not working with 3.6? [message #519042 is a reply to message #519028] |
Fri, 05 March 2010 20:15 |
Darn, I must have done something wrong when I published the new external site today. I'll have a look at it tomorrow.
Thanks for reporting so rapidly and I'm sorry for the inconvenience.
- thomas
On 03/05/2010 07:30 PM, Carsten Reckord wrote:
> Hi Thomas, hi Patrick,
> I have the same problem with subversive when using
> http://download.eclipse.org/tools/buckminster/headless-3.6
> http://download.cloudsmith.com/buckminster/external-3.6
> A workaround is to follow the procedure from
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=295696 and install the SVN
> connectors directly from polarion for the moment.
> Carsten
> On 05.03.2010 18:35, Thomas Hallgren wrote:
>> Hi Patrick,
>> - thomas
>>> ERROR [0001] :
>>> resourceMap
>>> searchPath aranea
>>> was found
>>> projects from SVN.
Re: Headless SVN not working with 3.6? [message #519080 is a reply to message #519042] |
Sat, 06 March 2010 08:28 |
There is a problem with subversive but everything seems OK with subclipse. I have tested it on both Linux and Windows
(64 and 32 bit) and everything seems to work OK. Are you starting with a clean installation or updating an existing one?
Perhaps installing subclipse on top of subversive?
- thomas
> - thomas
>> Carsten
>>> Hi Patrick,
>>> - thomas
>>>> ERROR [0001] :
>>>> at:
>>>> resourceMap
>>>> searchPath aranea
>>>> was found
>>>> projects from SVN.
FUDForum. Page generated in 0.04231 seconds
