Home » Archived » B3 » In search of a good name...
In search of a good name... [message #518609] Thu, 04 March 2010 05:52 Go to next message
I am looking for a good name for a construct used in b3. It is currently
called BuildResult - but this name is not good as the same structure is
used as input to the logic that produces a build result.
The BuildResult is basically a set of URIs, and a set of named and typed
values.
The name AnnotadedURIGroup is one possibility, or even the shorter
URIGroup (as there is no unannotated group to confuse it with).
Other possible names (thinking about the role of the class) could be
BuildData, ResourceData, BuildResources.
So, does anyone have ideas what this "Bunch of URIs and stuff" should be
called? (I am leaning towards URIGroup)
- henrik
Re: In search of a good name... [message #518706 is a reply to message #518609] Thu, 04 March 2010 14:27 Go to previous messageGo to next message
On 03/04/2010 04:36 PM, Henrik Lindberg wrote:
> values.
I think URIGroup is too limiting but I like BuildResources. It keeps the door open if we want to add more attributes to
it later. I like the name because this is something that is passed between builders.
- thomas
Re: In search of a good name... [message #518796 is a reply to message #518706] Thu, 04 March 2010 16:30 Go to previous messageGo to next message
Thomas and I had a discussion, and we came to like the term 'BuildBag',
short and snappy, suggest a somewhat unordered collection of build
related stuff...
Unless someone else comes up with something better, I think it is the
winner...
- henrik
> > Hi,
> > currently
> > is
> > typed
> > values.
> > should be
> the door open if we want to add more attributes to it later. I like
> - thomas
- henrik
Re: In search of a good name... [message #518847 is a reply to message #518796] Thu, 04 March 2010 23:48 Go to previous messageGo to next message
--------------000100090800090706030905
Content-Type: text/plain; charset=UTF-8; format=flowed
Henrik,
How about BuildDescriptor?
> related stuff...
> winner...
> - henrik
>>> Hi,
>>> currently
>>> is
>>> typed
>>> values.
>>> should be
>> - thomas
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Henrik,<br>
<br>
How about BuildDescriptor? <br>
<br>
<br>
<blockquote
cite="mid:1597312897289447834.147318henrik.lindberg-cloudsmith.com@news.eclipse.org"
type="cite">
<pre wrap="">Thomas and I had a discussion, and we came to like the term 'BuildBag',
related stuff...
winner...
- henrik
Thomas Hallgren <a class="moz-txt-link-rfc2396E" href="mailto:thomas@tada.se">&lt;thomas@tada.se&gt;</a> wrote:
</pre>
<blockquote type="cite">
<pre wrap="">On 03/04/2010 04:36 PM, Henrik Lindberg wrote:
</pre>
<pre wrap="">Hi,
currently
is
typed
values.
should be
</pre>
</blockquote>
<pre wrap="">I think URIGroup is too limiting but I like BuildResources. It keeps
- thomas
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
</body>
</html>
--------------000100090800090706030905--
Re: In search of a good name... [message #518848 is a reply to message #518796] Thu, 04 March 2010 23:48 Go to previous messageGo to next message
Hi Henrik,
what do you think about BuildContext?
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 05.03.10 03:16, schrieb Henrik Lindberg:
> related stuff...
> winner...
> - henrik
>>> Hi,
>>> currently
>>> is
>>> typed
>>> values.
>>> should be
>> - thomas
Re: In search of a good name... [message #518858 is a reply to message #518796] Fri, 05 March 2010 05:19 Go to previous messageGo to next message
+1 for BuildBag
Re: In search of a good name... [message #518867 is a reply to message #518847] Fri, 05 March 2010 00:48 Go to previous messageGo to next message
Hi Ed,
We discarded BuildInfo on the grounds that this is a bag of built material passed from one builder to another. It's not
information about something concrete but rather the concrete thing. I think BuildDescriptor falls into the same category.
- thomas
On 03/05/2010 10:35 AM, Ed Merks wrote:
> Henrik,
>> related stuff...
>> winner...
>> - henrik
>>>> Hi,
>>>> currently
>>>> is
>>>> typed
>>>> values.
>>>> should be
>>> - thomas
Re: In search of a good name... [message #518878 is a reply to message #518848] Fri, 05 March 2010 01:14 Go to previous messageGo to next message
Hi Sebastian,
To me, the term context denotes something that encompasses a process of some sort. Like an evaluation context, query
context, naming context, etc. The BuildBag contains data passed between builders. There might be many instances of such
bags depending on how many builders that are involved.
There is a context already, it contains things needed for the evaluation and we need to reference this when we explain
how a concern is applied (in what context).
- thomas
On 03/05/2010 10:38 AM, Sebastian Zarnekow wrote:
> Hi Henrik,
> Sebastian
Re: In search of a good name... [message #518879 is a reply to message #518878] Fri, 05 March 2010 01:14 Go to previous messageGo to next message
Am 05.03.2010 11:44, schrieb Thomas Hallgren:
> Hi Sebastian,
> of some sort. Like an evaluation context, query context, naming
BuildData?!
Cheers
/Eike
> passed between builders. There might be many instances of such bags
> evaluation and we need to reference this when we explain how a concern
> - thomas
>> Hi Henrik,
>> Regards,
>> Sebastian
Re: In search of a good name... [message #518880 is a reply to message #518879] Fri, 05 March 2010 01:14 Go to previous messageGo to next message
>> Hi Sebastian,
> BuildData?!
Yes, Henrik suggested that too and I think it's OK. I like BuildBag better though. It's shorter and more about handing
things over :-)
- thomas
Re: In search of a good name... [message #518881 is a reply to message #518880] Fri, 05 March 2010 01:14 Go to previous messageGo to next message
Am 05.03.2010 11:50, schrieb Thomas Hallgren:
>>> Hi Sebastian,
>> BuildData?!
You're kidding :P
Cheers
/Eike
> and more about handing things over :-)
> - thomas
Re: In search of a good name... [message #518882 is a reply to message #518867] Fri, 05 March 2010 01:14 Go to previous messageGo to next message
Thomas,
I don't think it's actually the built material though right? A build
bag seems to imply a bag that contains a build, i.e., all the binaries
and other stuff that builds pump out the other end. If I understand
correctly it really is information/data about a build, i.e., a
description of a build, of where to find it, of what's there. I
personally rather dislike the term Bag. We might as well call it a
BuildSack. :-P
Thomas Hallgren wrote:
> Hi Ed,
> material passed from one builder to another. It's not information
> - thomas
>> Henrik,
>>> related stuff...
>>> winner...
>>> - henrik
>>>>> Hi,
>>>>> currently
>>>>> is
>>>>> typed
>>>>> values.
>>>>> should be
>>>> - thomas
Re: In search of a good name... [message #518883 is a reply to message #518847] Fri, 05 March 2010 01:14 Go to previous messageGo to next message
Ed, Assume you had an allergic reaction to 'BuildBag' :)
'BuildDescriptor' could work, but to me it sounds like it describes an
action, rather than the input and output of such an action.
How about "BuildMaterial" ?
- henrik
Re: In search of a good name... [message #518893 is a reply to message #518883] Fri, 05 March 2010 06:24 Go to previous messageGo to next message
I had not read all of the responses before my last reply...
I am actually not so hot on BuildBag, prefer BuildData or BuildMaterial.
- henrik
- henrik
Re: In search of a good name... [message #518894 is a reply to message #518893] Fri, 05 March 2010 06:35 Go to previous messageGo to next message
--------------090705080209090403040404
Henrik,
I think build data gets across the notion that it's information about a
build better than does build material, which again seems more to imply
the actual material results of a build.
> - henrik
<html>
<head>
</head>
Henrik,<br>
<br>
the actual material results of a build.<br>
<br>
<br>
<blockquote
cite="mid:1387245646289480598.815361henrik.lindberg-cloudsmith.com@news.eclipse.org"
type="cite">
<pre wrap="">I had not read all of the responses before my last reply...
- henrik
Henrik Lindberg <a class="moz-txt-link-rfc2396E" href="mailto:henrik.lindberg@cloudsmith.com">&lt;henrik.lindberg@cloudsmith.com&gt;</a> wrote:
</pre>
<pre wrap="">Ed, Assume you had an allergic reaction to 'BuildBag' :)
</pre>
</blockquote>
</pre>
</blockquote>
</body>
</html>
--------------090705080209090403040404--
Re: In search of a good name... [message #518903 is a reply to message #518894] Fri, 05 March 2010 02:12 Go to previous messageGo to next message
Ed,
It *is* the actual material results.
That's why BuildBag is my favorite. A builder produces something, puts in in a bag for another builder to pick up.
- thomas
On 03/05/2010 12:35 PM, Ed Merks wrote:
> Henrik,
>> - henrik
Re: In search of a good name... [message #519456 is a reply to message #518903] Mon, 08 March 2010 16:15 Go to previous messageGo to next message
You may also want to consider the mathematical definition of a 'bag' used as a data structure: http://en.wikipedia.org/wiki/Multiset
Actually, what about "BuiltSet"? (Past not present)
[Updated on: Mon, 08 March 2010 16:19] by Moderator
Re: In search of a good name... [message #519471 is a reply to message #519456] Mon, 08 March 2010 12:38 Go to previous messageGo to next message
I was thinking about that when I suggested "Bag" (a 'multiset').
Thinking a bit more about this, what it contains is really not a
multiset/bag, as each URI would only be represented once (not meaningful
to say that a particular source file, or output file is included more
than once (and the same with annotations/properties)).
So, it is really a Set rather than a Bag, with the logical consequence
of naming the thing "BuildSet". Which I think is the best name so far -
it is a set of things, it is about build data/material/resources, and it
is similar to a corresponding FileSet structure found in other build
technologies.
The only problem with the name BuildSet, is that it probably does not
implement Java Set interface :) because it is a set of two disjunct
types of things (URIs and "variables") - but I can live with that.
- henrik
Re: In search of a good name... [message #519577 is a reply to message #519471] Tue, 09 March 2010 06:14 Go to previous messageGo to next message
Just some more theory:
You could 'normalize' variable names to be mapped to URIs:
variable://path/to/scope/var-name
Then, there would be no problem at all Smile
Re: In search of a good name... [message #519585 is a reply to message #519577] Tue, 09 March 2010 01:46 Go to previous messageGo to next message
True, and i thought of that, but rejected the idea because I think the
annotations are conceptually different and used differently.
- henrik
> Then, there would be no problem at all :)
- henrik
Re: In search of a good name... [message #602146 is a reply to message #518706] Thu, 04 March 2010 21:16 Go to previous messageGo to next message
related stuff...
winner...
- henrik
> > Hi,
> > currently
> > is
> > typed
> > values.
> > should be
> - thomas
- henrik
Re: In search of a good name... [message #602151 is a reply to message #602146] Fri, 05 March 2010 04:35 Go to previous messageGo to next message
Henrik,
> related stuff...
> winner...
> - henrik
>>> Hi,
>>> currently
>>> is
>>> typed
>>> values.
>>> should be
>> - thomas
<html>
<head>
</head>
Henrik,<br>
<br>
<br>
<br>
<blockquote
type="cite">
related stuff...
winner...
- henrik
</pre>
</pre>
<pre wrap="">Hi,
currently
is
typed
values.
should be
</pre>
</blockquote>
- thomas
</pre>
</blockquote>
</pre>
</blockquote>
</body>
</html>
Re: In search of a good name... [message #602162 is a reply to message #602146] Fri, 05 March 2010 04:38 Go to previous messageGo to next message
Hi Henrik,
Sebastian
> related stuff...
> winner...
> - henrik
>>> Hi,
>>> currently
>>> is
>>> typed
>>> values.
>>> should be
>> - thomas
Re: In search of a good name... [message #602169 is a reply to message #602146] Fri, 05 March 2010 05:19 Go to previous messageGo to next message
+1 for BuildBag
Re: In search of a good name... [message #602174 is a reply to message #602151] Fri, 05 March 2010 05:38 Go to previous messageGo to next message
Hi Ed,
- thomas
> Henrik,
>> related stuff...
>> winner...
>> - henrik
>>>> Hi,
>>>> currently
>>>> is
>>>> typed
>>>> values.
>>>> should be
>>> - thomas
Re: In search of a good name... [message #602182 is a reply to message #602162] Fri, 05 March 2010 05:44 Go to previous messageGo to next message
Hi Sebastian,
- thomas
> Hi Henrik,
> Sebastian
Re: In search of a good name... [message #602189 is a reply to message #602182] Fri, 05 March 2010 05:46 Go to previous messageGo to next message
> Hi Sebastian,
BuildData?!
Cheers
/Eike
> - thomas
>> Hi Henrik,
>> Regards,
>> Sebastian
Re: In search of a good name... [message #602196 is a reply to message #602189] Fri, 05 March 2010 05:50 Go to previous messageGo to next message
>> Hi Sebastian,
> BuildData?!
things over :-)
- thomas
Re: In search of a good name... [message #602202 is a reply to message #602196] Fri, 05 March 2010 05:54 Go to previous messageGo to next message
>>> Hi Sebastian,
>> BuildData?!
You're kidding :P
Cheers
/Eike
> - thomas
Re: In search of a good name... [message #602209 is a reply to message #602174] Fri, 05 March 2010 05:54 Go to previous messageGo to next message
Thomas,
BuildSack. :-P
> Hi Ed,
> - thomas
>> Henrik,
>>> related stuff...
>>> winner...
>>> - henrik
>>>>> Hi,
>>>>> currently
>>>>> is
>>>>> typed
>>>>> values.
>>>>> should be
>>>> - thomas
Re: In search of a good name... [message #602217 is a reply to message #602151] Fri, 05 March 2010 06:03 Go to previous messageGo to next message
- henrik
Re: In search of a good name... [message #602588 is a reply to message #602217] Fri, 05 March 2010 06:24 Go to previous messageGo to next message
- henrik
- henrik
Re: In search of a good name... [message #602589 is a reply to message #518893] Fri, 05 March 2010 06:35 Go to previous messageGo to next message
Henrik,
> - henrik
<html>
<head>
</head>
Henrik,<br>
<br>
<br>
<br>
<blockquote
type="cite">
- henrik
</pre>
</pre>
</blockquote>
</pre>
</blockquote>
</body>
</html>
Re: In search of a good name... [message #602592 is a reply to message #518894] Fri, 05 March 2010 07:05 Go to previous messageGo to next message
Ed,
- thomas
> Henrik,
>> - henrik
Re: In search of a good name... [message #602594 is a reply to message #602592] Mon, 08 March 2010 16:15 Go to previous messageGo to next message
Re: In search of a good name... [message #602602 is a reply to message #519456] Mon, 08 March 2010 17:24 Go to previous messageGo to next message
technologies.
- henrik
Re: In search of a good name... [message #602612 is a reply to message #602602] Tue, 09 March 2010 06:14 Go to previous messageGo to next message
Re: In search of a good name... [message #602614 is a reply to message #519577] Tue, 09 March 2010 06:36 Go to previous message
- henrik
- henrik
Previous Topic:BuildResult renamed to BuildSet
Next Topic:b3 website and documentation available
Current Time: Fri Sep 26 22:13:23 EDT 2025
Powered by FUDForum. Page generated in 0.09666 seconds
