| [hudson] exported empty packages cause compiler errors [message #518503] |
Thu, 04 March 2010 05:19  |
When building a project (RAP) from binary imported p2 site in Hudson, empty packages will cause compiler errors, e.g.:
Error: file C:\hudson\jobs\test-build\workspace\plugins\org.eclipse.rap. jface\META-INF\MANIFEST.MF, line 15: Package 'org.eclipse.jface.bindings.keys' does not exist in this plug-in
Manual builds (PDE) work.
Is there anything I can set (in hudson/buckminster) to ignore this?
| Re: [hudson] exported empty packages cause compiler errors [message #518549 is a reply to message #518541] |
Thu, 04 March 2010 03:04  |
On 03/04/2010 01:29 PM, Erdal Karaca wrote:
> Yes, the workspace is removed, first.
Are you issuing any commands prior to the import such as setpref? If you do, that won't work since it first creates a
workspace where it can store the preference.
> I am using this version:
> org.eclipse.buckminster.core_1.1.350.r10861.jar
> Do I have to use the latest buckminster?
No, there has been a couple of updates since then but none that is relevant to this problem.
- thomas
FUDForum. Page generated in 0.04640 seconds
