Home » Eclipse Projects » Nebula » Using org.eclipse.swt.accessibility.Accessible in class extending GalleryItem
Re: Using org.eclipse.swt.accessibility.Accessible in class extending GalleryItem [message #519651 is a reply to message #519646] |
Tue, 09 March 2010 10:28 |
Nicolas Richeton Messages: 179 Registered: July 2009 |
Thanks Grant, I'll look at 3.6 API.
Tom Schindl gave me a good pointer to CTabFolder#initAccessible() as an
example.
Mahesh, if you need this ASAP, could you try to implement it, based on
CTabFolder and submit a patch ?
I'll try to look at this when I get some free time but no garantee on
the schedule at all.
Nicolas
Le 09/03/10 15:58, Grant Gayed a écrit :
> I'm surprised to see that an Eclipse Corner article was never written about
> using SWT's accessibility API. There are a few examples at
> http://www.eclipse.org/swt/snippets/#accessibility . The two most common
> listeners to hook are AccessibleListener and AccessibleControlListener.
> Also note that SWT's accessibility API has grown significantly in the
> eclipse 3.6 stream, so the potential for making accessible custom controls
> is greatly improved (worth looking into once 3.6M6 is declared this week).
> Grant
> "Nicolas Richeton"<nicolas.richeton@gmail.com> wrote in message
> news:hn55ui$8as$1@build.eclipse.org...
>> Hi Mahesh,
>> Gallery does not currently implement accessibility, but this would be a
>> great addition to the widget.
>> Could you open a bug for this ?
>> I took a quick look to accessibility API. It seems we need to add a
>> custom accessibility listener using :
>> getAccessible().addAccessibleControlListener( IAccessibleControlListener )
>> Do you have any experience with this API ?
>> Could you provide a snippet showing the issue or does this need to be
>> tested with your automation tool ?
>> Is accessibility support something you could contribute to the widget ?
>> Thanks,
>> Nicolas
>> Le 04/03/10 10:50, Mahesh a écrit :
>>> Hi I have a requirement where I want to use test automation tools and
>>> run some test scripts. The tool recognizes the controls like table,
>>> table item, tree item, etc.
>>> However I have an application where I am using GalleryItem which extends
>>> from org.eclipse.swt.widgets.Item. The automation tool fails to
>>> understand these items.
>>> Is accessibility (org.eclipse.swt.accessibility.Accessible) is supported
>>> for org.eclipse.swt.widgets.Item class hierarchy. If this is not
>>> supported how can I achieve the support?
>>> Any help regarding this is appreciated.
>>> Thanks and Regards,
>>> Mahesh
Re: Using org.eclipse.swt.accessibility.Accessible in class extending GalleryItem [message #599208 is a reply to message #519646] |
Tue, 09 March 2010 15:19 |
example.
Nicolas
> Grant
>> Hi Mahesh,
>> Thanks,
>> Nicolas
>>> Thanks and Regards,
>>> Mahesh
Current Time: Sat Apr 27 03:49:57 GMT 2024
Powered by FUDForum. Page generated in 0.03541 seconds
