Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Synchronizing EMF resources forever
Synchronizing EMF resources forever [message #517901] |
Tue, 02 March 2010 08:52  |
using the graphical EcoreTools editor with Eclise 3.5 I'm facing the
following problem:
Frequently the status line says
"Synchronizing EMF resources"
and a progress indicator keeps indicating progress.
The only thing I can do then is to kill the Eclipse process, sometimes
resulting in a corrupt workspace.
There are multiple diagram files for a single ecore-model each showing a
limited number of classes. Ed Merks suggested doing it this way and
demonstrated it with the ecore.ecore meta-model.
At the moment I'have no idea what actually triggers the synchronization.
Has somebody else experienced the same problems?
Has somebody any idea how to find the cause of the problem?
Searching for "Synchronizing EMF resources" I couldn't find anything.
If I find out more I'll tell you.
First thing I'm going to do is reinstalling Eclipse without Features
such as Mylyn.
Thanks and Regards,
Dirk
Re: Synchronizing EMF resources forever [message #517918 is a reply to message #517901] |
Tue, 02 March 2010 09:08   |
--------------020808030304090305030607
Dirk,
Comments below.
Dirk Hoffmann wrote:
> following problem:
I found this message in org.eclipse.emf.workspace.
> a limited number of classes. Ed Merks suggested doing it this way and
Likely a resource delta, i.e, when you save something.
Not yet, no.
Stack traces to see what all the threads are up to would be useful:
<http://wiki.eclipse.org/index.php/How_to_report_a_deadlock>
> such as Mylyn.
> Thanks and Regards,
> Dirk
<html>
<head>
http-equiv="Content-Type">
</head>
Dirk,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:hmj57j$97m$1@build.eclipse.org" type="cite">Hi,
<br>
<br>
following problem:
<br>
<br>
<br>
<br>
<br>
</blockquote>
I found this message in org.eclipse.emf.workspace.<br>
<blockquote cite="mid:hmj57j$97m$1@build.eclipse.org" type="cite"><br>
<br>
<br>
<br>
<br>
<br>
<br>
synchronization.
<br>
</blockquote>
Likely a resource delta, i.e, when you save something.<br>
<br>
</blockquote>
Not yet, no.<br>
<br>
</blockquote>
Stack traces to see what all the threads are up to would be useful:<a
href="http://wiki.eclipse.org/index.php/How_to_report_a_deadlock"><br>
</a>
<blockquote><a
href="http://wiki.eclipse.org/index.php/How_to_report_a_deadlock">http://wiki.eclipse.org/index.php/How_to_report_a_deadlock</a><br>
</blockquote>
<br>
<br>
<br>
<br>
such as Mylyn.
<br>
<br>
Thanks and Regards,
<br>
Dirk
<br>
</blockquote>
</body>
</html>
--------------020808030304090305030607--
Re: Synchronizing EMF resources forever [message #518256 is a reply to message #517918] |
Wed, 03 March 2010 10:18   |
I found so many more problems with the EcoreTools editor that I even
don't feel like filing bugs for it.
For some model elements it is impossible to create diagram elements for
them by dragging their ecore counterparts from the outline view to the
canvas. Restarting Eclipse doesn't help. What helps however is to create
a new diagram from the ecore file and empty the diagram not deleting the
elements from the diagram, not the model. Although this does not seem to
do anything to the first diagram, afterwards the problem is gone. The
editor of the first diagram is marked dirty and diffing the diagram file
before and after saving it reveals that creating and emptying the new
diagram added some stuff. Strange. If I come across this again I might
After some time of editing diagrams it is impossible to select a type
for an operation from within the graphical editor. Restarting Eclipse
doesn't help. It is however possible to open the ecore file with the
tree-based sample ecore editor and set the type there and this is
reflected in the diagram as well. The Type selection dialog remains empy
however despite an attribute element which has no name.
Removing one diagram file caused elements to disappear in another diagram.
Changed to the Eclipse SR2 modeling edition but with no changes in behavior.
BTW: Validating the ecore file succeeded in all cases.
As restarting Eclipse or reopening a diagram does not help to recover
from some of the problems it seems that the diagrams can be brought into
an inconsistent state quite easily and there is no easy way to recover
from such.
Shouldn't we expect too much from the EcoreTools Editor because its free?
Is it still under active development so it is worth checking out a more
recent version and possibly putting effort into debugging it?
Does anybody know another graphical tool, not too expensive?
We used to use the graphical ecore editor that comes as an example with
GMF but diagrams created with it are not of the appealing kind and
connection labels behave strangely when moving elements. Also I don't
know if it is possible to share the same ecore file among multiple diagrams.
A bit frustrated,
Dirk
Ed Merks schrieb:
> Dirk,
> Comments below.
>> following problem:
> Not yet, no.
>> such as Mylyn.
>> Thanks and Regards,
>> Dirk
Re: Synchronizing EMF resources forever [message #518285 is a reply to message #518256] |
Wed, 03 March 2010 06:54   |
Dirk,
Comments below.
There's no one actively working on it right now, which is a big bummer. :-(
> for them by dragging their ecore counterparts from the outline view to
> the canvas. Restarting Eclipse doesn't help. What helps however is to
> create a new diagram from the ecore file and empty the diagram not
> deleting the elements from the diagram, not the model. Although this
> does not seem to do anything to the first diagram, afterwards the
> problem is gone. The editor of the first diagram is marked dirty and
> diffing the diagram file before and after saving it reveals that
> creating and emptying the new diagram added some stuff. Strange. If I
Unreported problems are likely never to be fixed...
> empy however despite an attribute element which has no name.
> diagram.
> behavior.
> into an inconsistent state quite easily and there is no easy way to
> recover from such.
Well, all of Eclipse is free and things like JDT are excellent...
> more recent version and possibly putting effort into debugging it?
The committers aren't so active, so I'm trying to find new ones.
None that operate directly on Ecore.
> with GMF but diagrams created with it are not of the appealing kind
> and connection labels behave strangely when moving elements. Also I
> don't know if it is possible to share the same ecore file among
> multiple diagrams.
Yes, it's possible, but not so convenient. You have to rename the
diagram and then you can create a new one.
> A bit frustrated,
Yes, me too, because it's the only tool I have to draw nice diagrams.
> Dirk
> Ed Merks schrieb:
>> Dirk,
>> Comments below.
>>> Hi,
>>> following problem:
>>> sometimes resulting in a corrupt workspace.
>>> showing a limited number of classes. Ed Merks suggested doing it
>>> this way and demonstrated it with the ecore.ecore meta-model.
>>> synchronization.
>> Not yet, no.
>>> such as Mylyn.
>>> Thanks and Regards,
>>> Dirk
Re: Synchronizing EMF resources forever [message #622256 is a reply to message #517901] |
Dirk,
Comments below.
> following problem:
Not yet, no.
> such as Mylyn.
> Thanks and Regards,
> Dirk
<html>
<head>
</head>
Dirk,<br>
<br>
Comments below.<br>
<br>
<br>
<br>
following problem:
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
<br>
synchronization.
<br>
</blockquote>
<br>
</blockquote>
Not yet, no.<br>
<br>
</blockquote>
</a>
<blockquote><a
</blockquote>
<br>
<br>
<br>
<br>
such as Mylyn.
<br>
<br>
Thanks and Regards,
<br>
Dirk
<br>
</blockquote>
</body>
</html>
Re: Synchronizing EMF resources forever [message #622260 is a reply to message #517918] |
from such.
A bit frustrated,
Dirk
Ed Merks schrieb:
> Dirk,
> Comments below.
>> following problem:
> Not yet, no.
>> such as Mylyn.
>> Thanks and Regards,
>> Dirk
Re: Synchronizing EMF resources forever [message #622262 is a reply to message #518256] |
Wed, 03 March 2010 11:31  |
Dirk,
Comments below.
> diagram.
> behavior.
> recover from such.
> multiple diagrams.
> A bit frustrated,
> Dirk
> Ed Merks schrieb:
>> Dirk,
>> Comments below.
>>> Hi,
>>> following problem:
>>> synchronization.
>> Not yet, no.
>>> such as Mylyn.
>>> Thanks and Regards,
>>> Dirk
Current Time: Tue Sep 23 09:30:08 EDT 2025
Powered by FUDForum. Page generated in 0.29779 seconds
