Re: File org.eclipse.wst.common.component modified [message #517772 is a reply to message #517041] |
Tue, 02 March 2010 00:17 |
Carlos Sanchez Messages: 114 Registered: July 2009 |
mmm, really? I tested it and worked. The file doesn't grow anymore,
lines added previously dont get deleted though, but you can delete all
but one by hand, or delete the eclipse config and reimport the project
On 3/1/10 1:58 PM, glandon@piti.pf wrote:
> Hi Carlos,
> I've tried with the latest version from
> http://q4e.googlecode.com/svn/trunk/updatesite-dev/ :
> Eclipse IAM *0.12.0.201002111708* org.eclipse.iam.feature.feature.group
> And I still have this problem.
> Regards,
> Gabriel LANDON
> /Pacifique Informatique et Télécommunications autour d'Internet/
> Tél : 45 43 82 / Fax : 45 43 82 / Mobile : 28 82 62
> Site : _www.piti.pf/_ <http://www.piti.pf/> - Mail : _info@piti.pf_
> <mailto:info@piti.pf>
> De : Carlos Sanchez <csanchez@exist.com>
> A : Gabriel LANDON <glandon@piti.pf>
> Date : 25/02/2010 11:16
> Objet : Re: File org.eclipsewst.common.component modified
> I noticed that too and fixed it already in the last 0.12 development
build.
> If you want to try the new build, it's available at
> http://code.google.com/p/q4e/wiki/Installation
> On 2/24/10 5:44 PM, Gabriel LANDON wrote:
> > Since i've upgraded to 0.11, the file
"org.eclipse.wst.common.component"
> > is modified each time I clean a web project.
> > Each time the folowing line is added to the file :
> > <wb-resource deploy-path="/WEB-INF/classes"
> source-path="/target/classes"/>
> > So after a couple of days, I end up with a file like that :
> > <?xml version="1.0" encoding="UTF-8"?>
> > <project-modules id="moduleCoreId" project-version="1.5.0">
> > <wb-module deploy-name="TSPBnC">
> > <dependent-module deploy-path="/WEB-INF/lib"
> > handle="module:/resource/Util/Util">
> > <dependency-type>uses</dependency-type>
> > </dependent-module>
> > handle="module:/resource/AccesTSP/AccesTSP">
> > </dependent-module>
> > handle="module:/resource/AccesGPS/AccesGPS">
> > </dependent-module>
> > <property name="context-root" value="TSPBnC"/>
> > <wb-resource deploy-path="/" source-path="src/main/webapp"/>
> > <property name="java-output-path" value="/target/classes"/>
source-path="src/main/java"/>
> > source-path="src/main/resources"/>
> > </wb-module>
> > </project-modules>
> > Does anyone have the same behavior?
> > Regards,
> > Gabriel.
Re: File org.eclipse.wst.common.component modified [message #518693 is a reply to message #517772] |
Thu, 04 March 2010 14:04 |
Eclipse config is
..project
..classpath
..settings (directory)
Yes, I have 201002111708 installed
On 3/4/10 10:35 AM, glandon@piti.pf wrote:
> Hi Carlos,
> What do you mean with "delete eclipse" config?
> Which directories or files shall I delete?
> I've tried with a fresh eclipse galileo SR2 and I still have the problem.
> Are you using : Eclipse IAM *0.12.0.201002111708* ?
> Regards,
> Gabriel LANDON
> A :
> Cc : Gabriel LANDON <glandon@piti.pf>
> Date : 01/03/2010 14:21
> > Hi Carlos,
> > Regards,
> > Gabriel LANDON
> build.
> > > </dependent-module>
> > > </dependent-module>
> > > </dependent-module>
> > > </wb-module>
> > > </project-modules>
> > > Regards,
> > > Gabriel.
Re: File org.eclipse.wst.common.component modified [message #572465 is a reply to message #517041] |
> Hi Carlos,
> Regards,
> Gabriel LANDON
build.
> > </dependent-module>
> > </dependent-module>
> > </dependent-module>
> > </wb-module>
> > </project-modules>
> > Regards,
> > Gabriel.
Re: File org.eclipse.wst.common.component modified [message #572513 is a reply to message #517772] |
Thu, 04 March 2010 18:57 |
Eclipse config is
..project
..classpath
> Hi Carlos,
> Regards,
> Gabriel LANDON
> A :
> > Hi Carlos,
> > Regards,
> > Gabriel LANDON
> build.
> > > </dependent-module>
> > > </dependent-module>
> > > </dependent-module>
> > > </wb-module>
> > > </project-modules>
> > > Regards,
> > > Gabriel.
FUDForum. Page generated in 0.04468 seconds
