Home » Archived » Pulsar » Launch configuration EclipseStarter
icon8.gif  Launch configuration EclipseStarter [message #516709] Wed, 24 February 2010 16:28 Go to next message
Something happened to Eclipse Pulsar. I have a glitch that when I open Eclipse Run>Run I get a
"Launch configuration EclipseStarter references a non-existing project org.eclipse.ui.examples.multipageeditor"
also it says:
C:\eclipse-pulsar-galileo-SR1-win32\intro\sample.xml
(The system cannot find the path specified)
probally because it doesn't exist and don't know why it would even want to look for it.
I can open AVD if I go to it directly, but my program does not show up in the menu.
tried deleting eclipse and sdk files and reinstalling but it did not work.
new user
[Updated on: Wed, 24 February 2010 20:29] by Moderator
Re: Launch configuration EclipseStarter [message #639452 is a reply to message #516709] Tue, 16 November 2010 11:07 Go to previous messageGo to next message
Hi skittle
I received the same message.
Using the win 64 bit version
Version: Helios Service Release 1
Build id: 20100917-0705
Did you resolve your issue
Re: Launch configuration EclipseStarter [message #639587 is a reply to message #639452] Tue, 16 November 2010 23:00 Go to previous message
It has been awhile, so I will try and remember. I believe I just unistalled everything, I mean everything, that had to do with eclipse, including the SDK and started from scratch. This seemed to work. I think it had something to do with the workspace folder. I'm new at this and not much of a geek yet, so I'm not able to give much detail. I really don't remember exactly what was causing the proplem. Hope this helps.
Previous Topic:Galileo- Pulsar: I'm confused
Next Topic:javax.microedition.pim.ContactList.read lack
Current Time: Wed Sep 17 12:43:39 EDT 2025
Powered by FUDForum. Page generated in 0.02453 seconds
