InvalidRegistryObjectException [message #516358] |
Tue, 23 February 2010 17:11 |
Xavier Maysonnave Messages: 30 Registered: July 2009 |
Member |
To day I got this exception on Eclipse Modeling 3.5.1
org.eclipse.core.runtime.InvalidRegistryObjectException: Invalid
registry object
at
org.eclipse.core.internal.registry.TemporaryObjectManager.ge tObject(TemporaryObjectManager.java:98)
at
org.eclipse.core.internal.registry.BaseExtensionPointHandle. getExtensionPoint(BaseExtensionPointHandle.java:98)
at
org.eclipse.core.internal.registry.BaseExtensionPointHandle. getUniqueIdentifier(BaseExtensionPointHandle.java:90)
at
org.eclipse.emf.ecore.plugin.RegistryReader$1.registryChange d(RegistryReader.java:106)
at
org.eclipse.core.internal.registry.ExtensionRegistry$2.run(E xtensionRegistry.java:891)
at
org.eclipse.core.internal.registry.ExtensionRegistry.process ChangeEvent(ExtensionRegistry.java:889)
at
org.eclipse.core.runtime.spi.RegistryStrategy.processChangeE vent(RegistryStrategy.java:267)
at
org.eclipse.core.internal.registry.osgi.ExtensionEventDispat cherJob.run(ExtensionEventDispatcherJob.java:50)
As you can notice there is a registry listener on EMF who listen the
registry. As far as I debugged, the extension is not valid in this code.
However I'm responsible of such behaviour as I'm playing with dynamic
bundle. Here is where I'm.
I uninstall a bundle with bundle.uninstall() then I take the
PackageAdmin osgi service to refreshPackages of such bundle.
I tried various scenario to understand what's going on and I noticed the
following. The exception occur when I try to refreshPackages.
However while debugging I noticed that no crash occured. (some race
condition somewhere then) I also tried between the uninstall and the
resfresh a Thread.sleep(1000) and one again no problem at all.
Could you provide some guidance to have a better understanding and why
not a fix for such exception ?
Cheers.
Re: InvalidRegistryObjectException [message #516405 is a reply to message #516358] |
Tue, 23 February 2010 15:46 |
Oleg Besedin Messages: 41 Registered: July 2009 |
Member |
This exception typically occurs when some code caches IExtensionPoint /
IExtension / IConfigurationElement. Those are handles for internal registry
objects. When bundle that contained, say, IExtension, is removed, such
IExtension becomes invalid. An attempt to use such invalid handle produces
the exception.
To avoid this, either don't cache handles to registry objects, or create a
listener on registry events and process them to remove invalid handles from
the local cache.
Sincerely,
Oleg Besedin
"Xavier Maysonnave" <xavier.maysonnave@soyatec.com> wrote in message
news:hm1280$cnd$1@build.eclipse.org...
> org.eclipse.core.runtime.InvalidRegistryObjectException: Invalid registry
> object
> at
> at
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> I uninstall a bundle with bundle.uninstall() then I take the PackageAdmin
> Could you provide some guidance to have a better understanding and why not
> Cheers.
FUDForum. Page generated in 0.07576 seconds
