Home » Eclipse Projects » Eclipse 4 » RCP can not say hello world
RCP can not say hello world [message #516202] Tue, 23 February 2010 03:14 Go to next message
I used the RCP Wizard to create a HelloWorld RCP Application.
But When I run it as a eclipse application, the eclipse say:
!SESSION Tue Feb 23 15:55:25 CST 2010 ------------------------------------------
!ENTRY org.eclipse.equinox.launcher 4 0 2010-02-23 15:55:25.100
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.ClassNotFoundException: org.eclipse.core.runtime.adaptor.EclipseStarter
at java.net.URLClassLoader$1.run(URLClassLoader.java:200)
at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 608)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:566)
at org.eclipse.equinox.launcher.Main.run(Main.java:1363)
at org.eclipse.equinox.launcher.Main.main(Main.java:1339)
The eclipse version is eclipse-e4-SDK-incubation-I20100218-2100-win32
[Updated on: Tue, 23 February 2010 03:15] by Moderator
Re: RCP can not say hello world [message #516289 is a reply to message #516202] Tue, 23 February 2010 09:14 Go to previous messageGo to next message
With what build? you might have to go to your launch config and add all
required plugins.
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: RCP can not say hello world [message #516308 is a reply to message #516202] Tue, 23 February 2010 10:10 Go to previous messageGo to next message
Try the manual way and see if it works:
http://www.vogella.de/articles/EclipseE4/article.html
Cheers, Lars
http://www.vogella.de/ - Eclipse plugin and Eclipse RCP Tutorials
http://www.twitter.com/vogella - vogella on Twitter
> !STACK
> at java.security.AccessController.doPrivileged(Native Method)
Re: RCP can not say hello world [message #516464 is a reply to message #516202] Wed, 24 February 2010 01:03 Go to previous messageGo to next message
The build is eclipse-e4-SDK-incubation-I20100218-2100-win32.
If I have to add all required plugins by mysely, I think the wizard shoud be update.
Re: RCP can not say hello world [message #516470 is a reply to message #516308] Wed, 24 February 2010 02:09 Go to previous messageGo to next message
I use the build eclipse-e4-SDK-incubation-I20100218-2100-win32 and following the article, the ClassNotFoundException still rise.
Lars Vogel wrote on Tue, 23 February 2010 10:10
Cheers, Lars
> !STACK
Re: RCP can not say hello world [message #516763 is a reply to message #516470] Wed, 24 February 2010 21:13 Go to previous messageGo to next message
Did you check you launch configuration? Press "Validated .... " on the
plugin tab.
>> Cheers, Lars
>> > !STACK
Re: RCP can not say hello world [message #520421 is a reply to message #516202] Fri, 12 March 2010 00:48 Go to previous messageGo to next message
Here is a screencast to help you getting started:
http://wiki.eclipse.org/E4/E4Designer
yves
"Jinshan" <jinshanl@gmail.com> wrote in message
news:hm02po$l4r$1@build.eclipse.org...
> !STACK
Re: RCP can not say hello world [message #569003 is a reply to message #516308] Wed, 24 February 2010 02:09 Go to previous messageGo to next message
> Cheers, Lars
> > !STACK
Re: RCP can not say hello world [message #569021 is a reply to message #569003] Wed, 24 February 2010 21:13 Go to previous messageGo to next message
plugin tab.
>> Cheers, Lars
>> > !STACK
Re: RCP can not say hello world [message #729125 is a reply to message #569021] Sun, 25 September 2011 02:11 Go to previous messageGo to next message
I am having the same problem...
I have tried to do Debug configuration > Plug-ins tab > Validate plug-ins
I have a lot of validations errors... Everything seems to be missing.
My Application
	Missing Constraint: Require-Bundle: javax.annotation;bundle-version="1.0.0"
	Missing Constraint: Require-Bundle: javax.inject;bundle-version="1.0.0"
	Missing Constraint: Require-Bundle: org.eclipse.core.runtime;bundle-version="3.7.0"
	Missing Constraint: Require-Bundle: org.eclipse.e4.core.contexts;bundle-version="0.10.0"
	Missing Constraint: Require-Bundle: org.eclipse.e4.core.di;bundle-version="0.10.0"
	Missing Constraint: Require-Bundle: org.eclipse.e4.ui.services;bundle-version="0.10.0"
	Missing Constraint: Require-Bundle: org.eclipse.e4.ui.css.swt.theme;bundle-version="0.9.1"
	Missing Constraint: Require-Bundle: org.eclipse.e4.core.services;bundle-version="0.10.0"
	Missing Constraint: Require-Bundle: org.eclipse.e4.ui.workbench;bundle-version="0.10.0"
	Missing Constraint: Require-Bundle: org.eclipse.e4.ui.workbench.renderers.swt;bundle-version="0.10.0"
	Missing Constraint: Require-Bundle: org.eclipse.e4.ui.workbench.swt;bundle-version="0.10.0"
	Missing Constraint: Require-Bundle: org.eclipse.equinox.ds;bundle-version="1.3.0"
	Missing Constraint: Require-Bundle: org.eclipse.equinox.event;bundle-version="1.2.100"
	Missing Constraint: Require-Bundle: org.eclipse.swt;bundle-version="3.7.0"
org.eclipse.e4.ui.worbench.swt is missing
I have tried with eclipse indigo 3.7 and eclipse-sdk-4.1 on a mac.
I probably missed something by the installation of e4... but what ?
Re: RCP can not say hello world [message #729142 is a reply to message #729125] Sun, 25 September 2011 03:34 Go to previous messageGo to next message
Well you are missing everything from Eclipse 4, when you are in 3.7
you'll have to set up a target-platform for the Eclipse 4 repos but when
running Eclipse 4 everything should be resolved.
Tom
Am 25.09.11 08:11, schrieb Jeremie Bresson:
> My Application
Re: RCP can not say hello world [message #804251 is a reply to message #516202] Wed, 22 February 2012 06:24 Go to previous message
I had this problem when I was using Helios. I downloaded and installed Eclipse from Indigo and the problem went away.
Google for this: eclipse-rcp-indigo-SR1-win32.zip
Previous Topic:Bug in org.eclipse.e4.core.di?
Next Topic:How to use IResourcePool
Current Time: Sun Sep 21 20:52:38 EDT 2025
Powered by FUDForum. Page generated in 0.06532 seconds
