problem executing .eol with ant [message #515970] |
Mon, 22 February 2010 11:34 |
m kranz Messages: 69 Registered: January 2010 |
Member |
hi all
i tried to run an .eol file from ant (as shown in the epsilon book, page 165), but it seems it could not find the epsilon.eol task.
autocompletion of 'epsilon.eol' works in the editor, so i'm not sure what's the problem.
my .ant file:
<project name="MyProject" default="main">
<target name="main">
<epsilon.eol src="test.eol"/>
</target>
</project>
error message:
BUILD FAILED
C:\workspace\test\build.xml:3: Problem: failed to create task or type epsilon.eol
Cause: The name is undefined.
thx for your help
marco
[Updated on: Mon, 22 February 2010 11:37] Report message to a moderator
Re: problem executing .eol with ant [message #516004 is a reply to message #515973] |
Mon, 22 February 2010 13:10 |
Member |
thanks dimitris
now i have another question, that is...
if i want to work on an ecore file within my .eol file, do i have
to load this model via 'epsilon.loadmodel', or can i just use it?
(they're both in the same folder)
i get
EXCEPTION: Type 'Ecore!EPackage' not found...
but maybe it's just that i try to access the .ecore in the wrong way?
i'm not sure
thanks again...
marco
[Updated on: Mon, 22 February 2010 13:10] Report message to a moderator
FUDForum. Page generated in 0.03766 seconds
